CHESHIRECAT
- Joined
- 27 Jul 2010
- Messages
- 259
A fish rots from the head down...
No, I can't see a contradiction. WCRC is a viable business - they've operated successfully since 1998 as a TOC so how you can say they "had a business that didn't work" is a bit of a mystery to me.
Because people want to see them fail.
WCRC is only a viable business if they are able to run trains. If they can't run trains there is no income.
Even if they are allowed to run trains, there is the question of whether anyone (stand fast steam buffs) wants to buy tickets with an operator that has been banned from running trains and prosecuted because they are unsafe.
Based on what we know, the corners they cut weren't actually things that cost a lot (or any) money. How much money does it cost to actually have the tamper-seal on a TPWS isolation switch/valve?There's also the question of whether the business is viable without the previous cutting of corners on safety...
Not quite true, their locomotive and rolling stock fleet is available to be hired by people using other operators to operate trains. This appears to be the case with this Saturday's "Midday Scot" tour.WCRC is only a viable business if they are able to run trains. If they can't run trains there is no income.
46233 does not belong to WCRC
I can't say from where the stock is being sourced - but the fact it is going back to Crewe strongly supports conjecture that it is not WCRC stock either.
Indications are that there was no need to break it, but that's the subject of an ongoing court action.Depends why the seal was broken. If every thing was working properly there was no need to break that seal, so something was wrong.
I saw a pack of 100 seals on amazon.co.uk for £12.99. Soooooooooooo that's about £300 per seal in railway money.
Which comes back to the idea that the issue isn't with their business strategy, but rather with their day-to-day operating model.Depending on their performance penalty regime, presumably the bigger cost, either financial or reputational, could be the cost of delay minutes whilst an AWS or TPWS activation is correctly followed up.
There are plenty of individuals in railway management positions who are prepared to cut corners if it gets a train moving quicker for the benefit of their own performance figures.
Thinking more of how much it might cost to maintain proper traction and particularly route knowledge if your drivers are on zero hours contracts.
Have there been any actual incidents caused by a lack of route knowledge on the part of their drivers? Yes I know the potential is there, but have there been any actual incidents?Which is also two of the ORR's issues, namely lack of a system to regularly update route knowledge and move staff off zero hours contracts
If you mean am I trying to defend them then the answer is no, they have lawyers to do that. I was thinking more of the wider issue of train crew on zero hours contracts, and how that can or can't be managed safely. An issue I suspect not unique to WCRC.I take it you're a supporter of WCRC - you can carve up the prohibition notice into small chunks and try and justify a defence in isolation, but the sum of the prohibition notice is greater than it's parts, and hence the ban.
Impossible to answer for sure, but lack of route knowledge may well have been behind the Stafford incident. I'm sure that is one of the things the court will be seeking to determine.Have there been any actual incidents caused by a lack of route knowledge on the part of their drivers?
Sorry. I meant the incident at Wootton Bassett, but had a brainfart.If you mean the class 47 SPAD it didn't involve West Coast.
The Royal Scotsman is an extremely prestigious train that TOCs would love to be associated with and if the rumours are correct GBRf have won the contract to operate it.
