Welsh 50 operation
Demps
11 May 2006
York
what is goin on with arriva using the 50's on services? :o, surely i thought this would be a main topic due to the december cancelation of loco haulage.
ChrisCooper
7 Sep 2005
Loughborough
Least it runs on a Saturday. With that in mind I'll make a weekend of it, over on the friday, get a Freedom of South Wales 3in7 Rover for £19.80 (YP Railcard), then get as much milage as possible in, including the 50s before heading home on Sunday. Don't know when I'll get around to doing it though, but I must do it since 50s are one of the few locos I've not yet had on the mainline (and I've not done one in preservation since the Mid Norfolk Diesel Gala a few years ago).
16CSVT2700
4 Sep 2005
Gdansk
Indeed.
Pathfinder tours Orcadian Weekend. 0645 off Swindon on Friday and returning Monday. They ran light to OOC on Monday, with a possible return to Cardiff Canton earmarked for 21/22nd June. No times available as yet.
Demps
11 May 2006
York
so they will be traveling down the west coast mainline, from scotland, to cardiff, Just remember to post the times
thanks.
16CSVT2700
4 Sep 2005
Gdansk
thanks.
Not quite.
Inverness (or whereever) - Swindon, ECS to OOC on 19th. Then light engine to Canton on 21 or 22 June AFAIK
Zamracene749
11 Dec 2005
East Durham
The junction.org has these as running mon_fri and sat but the diagrams for both only say saturdays. Do they run during the week?
Confirmation much appreciated.
TicketMan
20 Nov 2005
50149 said:
Indeed.
Bugger almost missed this one - TM be off to the Lickley in't morning :)
matt
30 Jun 2005
Rugby
From 24th June till 22nd July it is Saturdays and from the 24th July it will run Monday to Saturday till the beginning of September
[EDIT]
joea1 said:
Why have they been re numbered???
To give some variety I expect. They are running as 50012 and 50028 with Highland Rail Stags
16CSVT2700
4 Sep 2005
Gdansk
Heh the return of Benbow and Tiger! Makes a change! Although one of them was 49 but never mind!
Common thing with locos. You can renumber em to pretty much any of the 49 examples (except 50050/D400 as you'll know its that cos of its missing grabrails above the tails).
TicketMan
20 Nov 2005
I'm hearing rumblings that they've been renumbered on one side only - can anyone confirm?
Also, which one is which?
Cheers, TM
16CSVT2700
4 Sep 2005
Gdansk
Cheers, TM
Not sure. If no-one confirms by Monday night I will when I get them at Swindon on the return!!
Hellfire Vacs!:cheers::cheers:
Hang on.. 50031 was leading the light move to OOC with 49 behind it..
The tour went from swindon-dr days jnc - bristol parkway - yate etc.. so 49 should have been leading!*
(this is because being diesels they don't need turning etc etc so they just ran em out backwards!)
87015
3 Mar 2006
GEML/WCML/SR
Cheers, TM
Confirmed as one-side only,was talking to another photter who had been at New St and didn't know what i was going on about 012/028 for!
I think 049 is running as 028?
16CSVT2700
4 Sep 2005
Gdansk
Depends if 49 was leading the tour northwards yesterday! If it was then just look at a pic of the renumbered side and then you have your answer!
