Werrington grade separation updates
Rick1984
23 Aug 2012
Thanks I was wondering how they actually side the bit under the ECML, that article has explained it
Crun
30 Dec 2014
Werrington, Peterborough, England
A website article worth reading from New Civil Engineer:
Future of Rail | Curved box jack under East Coast Main Line junction
https://www.newcivilengineer.com/th...out-east-coast-main-line-junction-19-02-2020/
"Bauer Technologies is currently installing the first 84 of 142, 600mm diameter minipiles to 7.5m depth below the A15 bridge to allow the track level to be lowered below the original road level to make space for the overhead line electrification equipment."
An interesting point for possible, future electrification of the GNGE line.
“Slide into a curved slot in the embankment”, is how I’d summarise it. But being controlled by a rail system in pre-bored tunnels is the novel aspect.
I think some early descriptions used the term “jacked under” the ECML, implying the track formation was left in situ, but the detailed procedure now reveals that they will dig away the embankment ahead of the box as it is moved.
By the way, the latest article basically repeats what was explained in the Rail Engineer online magazine a couple of weeks back, linked in post #325. It’s a much more detailed 6 page article compared to the latest info.
24 Mar 2016
South Lanarkshire
Thanks for the brilliant compilation Crun! The music is soothing too 8-). I noticed that some of the pantographs are almost vertical on the mainline in places; does the OHLE have to be high there for a particular reason?
Will it be for a level crossing?
A former level crossing, yes. Hurn Road LC closed in the early 1990s, and the wire heights haven't been readjusted to reflect the closure.
Is that because there’s another crossing a bit further north? It may be sensible not to change it, assuming a pantograph still works efficiently at any height within its designed scope?
Apologies if off topic for the diveunder works.
92042
24 Mar 2016
South Lanarkshire
Many thanks for the explanation 59CosG95! I'm very interested in electrification and improvement projects but not too savvy with the technical/engineering side of things.
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
Yes, there are several crossing north of Hurn Rd; they are (in order): Woodcroft, Helpston, Maxey, Lolham & Tallington. I'm not sure if the wire height is constant between them though!
As am I, and after several years' hard graft at uni, it's the industry I'm now a part of :D
Crun
30 Dec 2014
Thanks to Mick aka 'werrington junction'... I just add them to this forum. He has had his viewing figures on YouTube boosted since I started doing this ;) :)
Crun
30 Dec 2014
Crossing The Stamford Lines 6th March 2020
Movement of personnel and consumables using the temporary crossing over the Stamford lines. A YouTube video courtesy of werrington junction:
59CosG95
18 Aug 2013
On an access related note, the overpumping system of pipes allowing the Marholm Brook to temporarily bypass the new box culvert has now been removed, with the culvert now in full operation.
This means Cock Lane Footbridge is now fully accessible to wheelchairs.
Crun
30 Dec 2014
In the late 1980's I used to cycle across the ECML in the evenings to get from the Bretton side to my then girlfriend's flat in Werrington. It was a question of opening a gate, looking left and right, listening all the time and riding quickly to the gate on the eastern side of the ECML. I used to also cross the ECML by bike heading to Glinton and Arthur Mellows Village School where the Peterborough Cycling Club used to meet once a month. It is now a manned crossing with a barrier.
59CosG95
18 Aug 2013
I think we're thinking of different crossings! Hurn Road is here:
The one which most closely matches your description of a manned crossing with a barrier en route to Glinton is Woodcroft Rd LC, which is here:
Woodcroft still has manual barriers.
Aictos
28 Apr 2009
I remember when Hurn Road was a manned crossing and you had to ring the doorbell mounted on a post to get the attention of the crossing keeper who would open the gates to let you though.
Then once they decided to close the crossing, they put the foot bridge in to replace the crossing.
Crun
30 Dec 2014
I used the old, gated crossing on Hurn Road to get to Werrington and the Woodcroft Crossing with the barriers to get to Glinton. Both would have been around the mid to late 80's.
Aictos
28 Apr 2009
That's how I remember both crossings, back to the subject though I'm glad they've finally got a wheelchair accessible footbridge at Cock Lane.
Crun
30 Dec 2014
Apologies for causing a minor drift in this thread. The whole design of the footbridge is good and now that the obstacle to wheelchair access has been removed it is excellent. It is also much safer as it separates pedestrians and cyclists.
Class 170101
1 Mar 2014
Photographs of heavy machinery at a standstill taken from the Cock Lane bridge with no sign of any activity or workers on 28th March 2020:
The standstill will be due to coronavirus. However what impact would a potential 12 week stoppage have on the project in terms of the critical possessions where train are suspended or diverted via GE/GN Joint Line plus the proposed blockades and commissioning of said dive under.
A very significant effect, I would imagine. Unlikely to be the only job in a similar position either.
(I must stress that I don’t know!)
I’d have thought almost the entire possession programme (at least those for upgrades) will have to move right “across the board” by however many weeks they eventually decide?
