Werrington grade separation updates
Peter Mugridge
8 Apr 2010
Epsom
If you click on the icons in the bottom right, the options appear in German!
Right... interesting... so they've obviously contracted the production of the video to a German company, so naturally they used the train images with which they are familiar?
apinnard
2 Aug 2017
Kettering
Popped out for a walk this evening. Admittedly only with my phone, and it was 9.30pm, so the light was terrible. Not much has changed since the last pictures just up-thread.
Rick1984
23 Aug 2012
What do they do when they get to the section under the bridge where the pilling machine can't fit under?
Geeves
6 Jan 2009
Rochdale
Crun
30 Dec 2014
Werrington, Peterborough, England
Here you go Crun and Rick.
Many thanks for the informative reply. Is there a more specific explanation as to how the piling under the Cock Lane footbridge will be done given the reduced headroom under the new bridge?
Crun
30 Dec 2014
I wonder if they will do the same as under the A15 and use an auger to drill down to create cast columns?
DelW
15 Jan 2015
Can they use shorter piling rigs or shorter piles and weld on extensions as they get driven in?
Both are feasible (I've used such techniques to work under HV power lines, for example), but both add considerably to the time and cost of installation.
Crun
30 Dec 2014
I've just learnt that the tunnel/portal installation under the main line has been put back from September until next February. This is because of the risk assessment for the tunnelling activity which required close working between more than one individual, i.e, less than 2 m.
