It's absolutely both.
Then why do they only wear them when they have a cold?
Yes all valid points, tubes with air conditioning and windows that don't open show significantly less pollution - the problem then comes from the doors opening every 5 minutes re-introducing pollution to the carriages in a car you can keep your windows and doors closed for the duration of the journey.But once aircon trains are introduced then won't the risk diminish to the same as those in air conditioned cars ? Yes you still have the getting to/from station and waiting for trains. But the same could be said about getting to/from your car/waiting for a taxi.
Just cannot see how masks are going to help. Especially as others have pointed out that unless worn absolutely correctly they are not effective. Cannot see commuters taking a couple of minutes to don their masks at the start and end of their day. (Especially seeing how annoyed many get at just missing their tube train even though the next one is normally less than 2 minutes away)
They don't.
The study may prove that masks are not going to help due to the myriad of problems associated with correct use and therefore other methods of reducing the amount of pollution inhaled will have to be looked into.
Wouldn't the problem of re-introducing pollutants on opening doors be solved by a small positive pressure gradient causing air to flow out of the carriage ?
Bakerloo Line trains suck air out from the carriage through the circular fan in the ceiling, drawing in air from the vents above the windows.They do work like that, don't they? All Tube trains I've been on recently use pressure ventilation, i.e. blow in, naturally flows out.
I can't speak to Japanese but Chinese people definitely do wear them all the time, not just when they have a cold.My experience is that they mostly do.
for air conditioning on trains to be effective at reducing exposure to pollutants (especially PM 2.5) the filters would have to be substantially better than eg those fitted to cars, which are pretty hopeless- of all modes of transport, those exposed to the most directly harmful pollution are drivers and passengers in congestion.
(re the surgical mask thing- saw someone, of east asian ethnicity, the other day that was wearing one. But only covering her mouth, her nose was exposed)
And therefore underground tunnels are naturally going to have much higher concentrations of pollutants than you'll find at street level.
If I'm right, any ideas what can be done to avoid that problem?
