I’ve just done a two week family holiday using interrail to travel across Europe to Scandinavia and back. We chose rail because it felt more adventurous and to be more climate conscious in our travel.
Obviously there’s no direct train from my home city to Sweden, so we embraced the fact you have to have lots of connections and built a holiday around that, with mini breaks in different cities.
Had I just wanted to go to Sweden directly and not cared about my emissions so much, I would have chosen to fly. That’s not so much because of what happens in London, but more the fact you have to go Brussels, then Köln, then Hamburg, then Fredericia, then København, etc etc.
When we think of the UK high speed system and the lack of connection between HS1 and HS2 we imagine that this will be a fatal flaw in its ability to compete with flying.
My feeling is that if you’re comparing the two methods, then this lack of connection is perhaps less of a flaw than others further afield - even if you joined these two railways up, what about the next node in Paris? Or if the train terminates in Brussels, Amsterdam etc?
It might eventually make sense to create a physical connection, but the way it works right now is that you travel slowish to the main hub, then fast to the next hub, then continue going fast, until the final hub, then slow again to your destination.
As such, design measures to make Euston feel like part of the same hub as St Pancras (eg clear signage, a dedicated walking route / travelator etc) would be enough.
What I think we should focus on instead is the range of connectivity options available from St Pancras - it would be more impactful if there was a much greater diversity of destinations available from here, rather than trying to create direct links from other cities in the UK just to Paris / Brussels.
Imagine if from St Pancras you can travel to…
Paris
Brussels
Amsterdam
Hamburg
Berlin
Munich
Marseille
Barcelona
Madrid
(or further by sleeper)
With that list of destinations available from St Pancras, you’d probably be happy to arrive at Euston and then make a short hop, knowing that your main train is going to take you a long way.
Most foreign holidays tend to start with a long drive across the UK and then a few of hours waiting for your main transport whether it be ferry or flight. If St Pancras offered real direct connectivity to Europe then I would say that would really open up rail’s competitiveness with European flights.
