The problem is if you have more changes then people with luggage and/or (small) children are put off.Yes it would add 2 changes (for example OOC and Stratford),
That's the way its detractors, (having lost the argument when the project was debated and the bill approved/given royal assent, have since wanted to delay and ultimately stop it happening. Luckily this goverment actually pressed on, pushing these distrations aside. When it is operational, and the detractors start whingeing about it not doing everything the original approved project claimed, they will be reminded that their continual attacking it has devalued it, reduced it's scope, yet increased the cost for no gain even on their part.The problem is if you have more changes then people with luggage and/or (small) children are put off.
To be honest HS2 looks to be less and less useful. If the HS1 HS2 link and the original HS2 concept had happened then I could see that a Midlands/North cross channel link terminal might have worked, with maybe half the services starting from lets say Birmingham (but other places could also work) and calling at Stratford to pick up before going through the tunnel, and the other half starting at St Pancras as they do now, which would relieve pressure on St Pancras, but it looks like that bird has well and truly flown.
HS2 just feels like a lot of missed chances to make a step change improvement in the UK rail infrastructure, and to be honest the more its cut back and/or delayed the more it feels like a white elephant. It does beg the question of what could have been acheived with the same money applied to the 'classic' infrastructure.
or example the likely capacity from the 5 Leeds to near Europe flights it's going to be about 400,000 per year,
The issue with the idea of induced demand is that any Eurostar fares would be too expensive to put off speculative travellers. The Elizabeth line was integrated into TfL's ticketing from the off, and Ryanair generate profit by deliberate running the lowest fares on new routes to advertise the 'European getaways for £5' type stuff. But you're not going to be impulsive about a trip from Manchester to Paris when the fare will be north of £100 more often than not. An 8hr return trip isn't exactly something you do on a whim.I think it would be unpopular to say but I think Regional Eurostars would stimulate extra demand. Railway projects like Crossrail have shown to generate new travel demand just by the line or route existing. I daresay that modelling can predict as much as it can do but not predict the inherent eccentricities of human nature. i.e "Oh we can go from Manchester to Paris by train now, lets find a reason to do it" - but that's a far more philosophical debate.
Is that extra to the planefuls of people on cheap tickets?I think it would be unpopular to say but I think Regional Eurostars would stimulate extra demand.
Am I missing something here
Building such a line and its stations in tunnel underground (and it would be deep underground) would be extraordinarily expensive. It would also destroy whole swathes of wherever the stations were going, as they would need to have sufficient entrances at street level and all the relevant interchanges with LU etc. They would also need at least 4 and probably 6 platforms each for the High Speed services, and a deep mined station of that scale, that long, that deep and that busy has to my knowledge never been built anywhere.
The depth these platforms would be at means you'd need large departure lounges halfway between the street and the platform if you were doing something like this.Wouldn't 4 platforms suffice, with a much larger station in Ebbsfleet as a terminal station?
I'm wondering if you couldn't divide the platforms into smaller platforms with access from street level, so for instance, if you wanted carriage #4 at platform 2, then you'd have your own dedicated entrance/exit. This way, you'd never have large numbers of people milling about: access would only be permitted 10 minutes before departure, for instance.
Does remind me of the Chicago Red Line State St Subway, - one long platform with three (formerly four) stations along it's length. It's a bit strange seeing a train 1/4 mile away arrive see passengers dis/embarking and then meving a bit nearer.Probably worth thinking that through a bit.
“This is a platform alteration….”
No, there is no connection between the classic networks south of Handsacre, north of Lichfield (other than the engineering access at Calvert, where EWR crosses it).Could cross Country use HS2 for the Birmingham to Old Oak Common section of long distance trains, then go to south west destinations. Would that be quicker than existing lines?
Moor Street and Curzon St won't be across the road from each other, they will be adjacent to each other, divided by the existing lines into New Street.There is no link between HS2 and the conventional network in Birmingham. CrossCountry could switch some services to Moor Street if the Bordesley chords are built. Moor Street and Curzon Street stations will be across a road from each other and linked by an elevated walkway.
HS2 has to terminate at Euston and enough HS2 terminating platforms at Euston need to completed for HS2 Phase One to be usable when it is completed and opened. There is no point in discussing any alternatives to terminating HS2 services at Euston as there are no workable alternatives.It is going to Euston, end of.
And it is buildable - I watched the team building some of it today!
To be honest, I think there's an element of 'any delay in HS2 is a potential step towards cancellation' amongst some politicians. So far, the project has fortunately kept marching forward, - doggedly.HS2 has to terminate at Euston and enough HS2 terminating platforms at Euston need to completed for HS2 Phase One to be usable when it is completed and opened. There is no point in discussing any alternatives to terminating HS2 services at Euston as there are no workable alternatives.
It is very useful to have Old Oak Common as a additional through station for interchanges to the Elizabeth Line and the Great Western Main Line but it can be no more than that, it cannot be the station where HS2 train services are terminated.
They clearly need to build the grade separated throat at HS2 Euston.
I do not know why the cost has increased so much, if it is a result of the DfT's insistence on oversite development they should just abandon the oversite development to keep the cost down. The benefit to the country of opening HS2 is to provide a big increase in capacity on the railway in general and the West Coast Main Line in particular by removing long distance passenger trains from the West Coast Main Line. The main purpose of building HS2 Euston is to enable HS2 to provide this benefit of a big increase in capacity on the railway which must be much more important that the value of any oversite development at Euston.
I do not know what the problem is with building 10 HS2 platforms on the site West of the current Euston Station to complete the building in one phase instead of building 11 platforms in two phases apart from the platforms being narrower and HS2 services being limited to 16 per hour instead of 18 per hour. Do these two issues mean it is not worth the benefit of completing the building of HS2 Euston in one phase?
