Personally speaking, I would probably be in favour of the following
- Liverpool - Manchester - Leeds - Newcastle/Hull (using upgraded ECML for York to Newcastle)
- Toton (or wherever HS2 stops around Nottingham) - Leicester - London. This assumes that passenger increase continues, and that at some point relief is needed on the Birmingham-London portion of HS2. London terminus would most likely be near KX/St P, as by this point Euston would already be struggling.
- Something for the West of England. I'm not sure how this would work though. Maybe a London - Reading section. I'm not as familiar with the geography of that area, though, so would leave it to others.
However, I think that HS3 should actually be the section from Birmingham to Leeds. I'm not a fan of the current design for this leg, and I think that this section should be sent back to the drawing board. It can be added later if necessary.
I also think that a bit more money spent on small scale incremental improvements after HS2 would probably yield better results. Note, I said "After", not "Instead of"!
