Prodigy
- Joined
- 30 May 2011
- Messages
- 225
I really think TPE could lay on more services to Edinburgh but most will probably disagree.
TPE didn't even have enough stock to run an Edinburgh service in the first place. Really Virgin should have kept that service and if a VHF timetable was required then more stock should have been ordered instead of making overcrowding on TPE routes worse than it already was.
Anyway, I would suggest that the poor relation with GE is basically everything around Colchester! None of Sudbury, Walton, Harwich and Clacton get what they should do. I would suggest electrifying Sudbury (eliminating the island in the area) and running through trains to Walton, using the fast stopping pattern, giving Harwich a through service to Londion (again), and giving Clacton a second service every hour (using the slow stopping pattern). Thus, Sudbury has a link to Colchester, walton has a faster link to Colchester, Harwich has a through service to London and Clacton has 2tph.
The Great Eastern Mainline is currently very busy south of Colchester, especially with many trains of differing stopping patterns, so it may not be technically possible to introduce extra trains for Harwich and Clacton. Before, Harwich had an hourly direct service but there were lots of intermediate stops. Now, Harwich still has an hourly service as far as Manningtree but there it connects to a fast intercity service with a net decrease in journey time, so as long as you don't mind changing, this is a good thing! Also, does Clacton really need 2tph?
I think TPEs has to be Scarborough. Sole TOC operating Westwards and 1tph. I can't think there can be many places the size of Scarborough with 1tph and 1tp2h as their total service.
Inverness, perhaps?
Also the first area to get cut when the driver's strikes were on leaving people in Malton with no rail service and those from Scarborough and Seemer having to travel via Hull to get to York!
I think that "first one to get scrapped in a strike" is a good definition of where a route is in the TOC's priorities.
If your service is usually the one to be scrapped when there's a driver shortage/ poor weather/ strike/ unit failures then you know you aren't a "flagship"
Whenever bad weather hits, SWT ditch the Ascot-Aldershot trains.
Amazingly, many residents of Camberley do their commuting from Farnborough Main, Woking or Sunningdale instead of their local station. I wonder why that is?
Felixstowe aswell
Direct trains to where they need to go (i.e. Clapham Junction, London Waterloo, Basingstoke etc)?
does anyone think picking northerns is difficult? so many can come under catagories mentioned in previous posts.
Having thought about this, may I recommend Lincoln - Sheffield as a "poor relation" of Northern routes?
I knows its cliched to submit a local route but...
- A service between two cities, 45 miles apart
- Some reasonable populations en route - Worksop. Retford/ Gainsborough
- Takes almost an hour and a half
- Vast majority of trains on this are (single) 142s or (single coach) 153s
- No "faster" alternative (unlike some other routes, which have faster "end to end" services, so its an hour and a half on a Pacer/153 or nothing...)
- Just an hourly service at suburban Sheffield stations (Darnall/ Woodhouse), pretty poor compared to inner-city services in other conurbations
- This route could be Sheffield's fastest way to London (via the chord at Retford), yet only gets all-stops services
- Scope for connection to Supertram at Nunnery Square P&R, but no station
- No through services to Mansfield (etc)
With a bit of TLC, this route could have a number of improvements- its out on a "limb" for Northern though, so easy for them to ignore.
It could be sped up by axing stations like Kiveton Bridge/Park, as let's be honest, they serve nowhere important. Run them fast to Worksop and stopping from there to Lincoln. Then introduce a two-hourly stopper to terminate at Retford calling at the minor stations.
Ive always thought an extra stopper to worksop/retford and a semi fast to lincoln could probably be held on the line (i think there should be capcity?) Like you say relatively inner city stations barely served by train at all. Although 150s do appear on the line now and again![]()
I think there's definitely scope for running the Lincoln services non-stop from Sheffield to Worksop (with something more suitable like a 156) with stations like Kiveton Park served by Sheffield - Worksop - Mansfield - Nottingham services (an extension of the current EMT service), but thats going across both TOC boundaries and political ones, so probably won't happen any time soon.
They'rell be no short tripping of the replacment unit, as that might (shock/horror) but 2 minutes on a Stansted train.
I was (honestly) thinking Hertford but I didn't want to risk saying so, only for someone to jump out and berate me on the importance of Herford connections!![]()
