But what's the point of improving the station if you can't improve the services?
Plenty of point, if that station suffers from passenger circulation issues at busy times of day.
One interesting thing about HS2 is the paths that Virgin Trains currently use, now as I understand it HS2 means some IC services being diverted/converted to HS2 operation however if Virgin Trains did go ahead and ran HS2 would they be willing to give up those former IC paths on the WCML to another operator such as LNR?
I say this because although it would mean the return of regular IC services to stations not served on a frequent basis since the VHF timetable came into play, would those services be better off with 9 or 11 car Class 390s as a IC service or would they be better off with 10 or 12 car EMUs as a Regio service but with a Class 444 type refurb?
Just wondering because although I think HS2 will benefit the country on a whole, the future use of those current IC paths is interesting.
Equally I have a question about the LNR timetable when HS2 opens, would it be possible for the existing Tring stoppers to be extended to Bletchley/Milton Keynes and the Northampton terminators to be extended to Rugby if and when the paths to do this become available via the introduction of HS2.
Given that a 10 coach train formed of two 444's has 79 more seats than an 11 coach 390, is be surprised if the 390's were used a lot on the remaining WCML services.
Then of course there's scope that there could be scope to have 6 coach 444's, which could increase capacity further, whilst giving the flexibility to run short trains on quieter services or being able to run to serve two locations from one path.
Agreed 110mph max units don't wast lots of crumple zone space too and dwell times will become more important with more stops.Given that a 10 coach train formed of two 444's has 79 more seats than an 11 coach 390, is be surprised if the 390's were used a lot on the remaining WCML services.
DfT will almost certainly decide which TOC gets the paths and rolling stock, if any are thought to be spareable. Assuming it is Virgin’s sole decision to make is quite wrong. The reason the West Midlands franchise had to separate out into two business units is all about their being a probable post-HS2 rearrangement of WCML responsibilities.One interesting thing about HS2 is the paths that Virgin Trains currently use, now as I understand it HS2 means some IC services being diverted/converted to HS2 operation however if Virgin Trains did go ahead and ran HS2 would they be willing to give up those former IC paths on the WCML to another operator such as LNR?
That's what I'm wondering as could LNR for example run more IC type services aka services with limited stops for example could we see a Birmingham service on a hourly basis run fast between London Euston and Milton Keynes then call Rugby and all stops to Birmingham or even give the 3rd path that Virgin Trains currently enjoys to LNR so LNR calls (Watford Jcn, Milton Keynes, Rugby, Coventry, Birmingham Int then Birmingham New Street) and return the remaining IC services to a half hourly service seeing as HS2 will take a lot of IC traffic.
The existing LNR services could keep their existing stops but the 3rd service could be a express?
For those who don't believe the extra capacity that HS2 will provide is required. This article shows what happens when you run more trains.
https://www.railjournal.com/passenger/main-line/virgin-trains-sets-ridership-record/
And they've achieved all that on the so-called congested WCML.For those who don't believe the extra capacity that HS2 will provide is required. This article shows what happens when you run more trains.
It does no such thing.Thank you, the figures make interesting reading especially as it blows the case for not doing HS2 out of the water!
I am relatively pro HS2 but I am concerned that the London end is OTT. Specifically the section between Old Oak Common and Euston and the size of the rebuilt station. It does seem unnecessary to keep Watford DC line services and Tring stoppers running into the station when the former could become an extension of the Bakerloo Line and the latter an extension of Crossrail. The choice to put the tunnel portal near Mornington Crescent rather than south east of Camden Junction does seem to be motivated by keeping 6 NR tracks on the approach to Euston. If there were only 15tph of NR services instead of 20tph then 4 tracks would be adequate and fewer than 13 NR platforms necessary. That might push costs elsewhere but would be a more realistic station size considering the capacity of the underground lines. It does appear that there is an assumption that Crossrail 2 will be built and if its not then the merged Euston and Euston Square underground station will become a mess.
<<SMART TIMETABLING KLAXON>> Take cover...And they've achieved all that on the so-called congested WCML.
The tunnel portal is more about the gradient coming out of it and in to and out of the platforms, Id like to see some proof that you could do 15tph with 4 tracks, especially if you chose to remove line X. Crossrail to Tring has been discussed before, that is more Old Oak Common related than Euston. Why will Euston and Euston Sq become a mess?I am relatively pro HS2 but I am concerned that the London end is OTT. Specifically the section between Old Oak Common and Euston and the size of the rebuilt station. It does seem unnecessary to keep Watford DC line services and Tring stoppers running into the station when the former could become an extension of the Bakerloo Line and the latter an extension of Crossrail. The choice to put the tunnel portal near Mornington Crescent rather than south east of Camden Junction does seem to be motivated by keeping 6 NR tracks on the approach to Euston. If there were only 15tph of NR services instead of 20tph then 4 tracks would be adequate and fewer than 13 NR platforms necessary. That might push costs elsewhere but would be a more realistic station size considering the capacity of the underground lines. It does appear that there is an assumption that Crossrail 2 will be built and if its not then the merged Euston and Euston Square underground station will become a mess.
There is literally no evidence that will convince you HS2 is necessary, is there?And they've achieved all that on the so-called congested WCML.
They'd have no choice but to give most of them up. Scotland & Liverpool services will still need their paths north of Crewe however.One interesting thing about HS2 is the paths that Virgin Trains currently use, now as I understand it HS2 means some IC services being diverted/converted to HS2 operation however if Virgin Trains did go ahead and ran HS2 would they be willing to give up those former IC paths on the WCML to another operator such as LNR?
Given that an 11 car Pendolino is 32 meters longer than a 10 car 444, 12 cars will be a squeeze. 2 express Desiro carriages are 46 meters long.Then of course there's scope that there could be scope to have 6 coach 444's, which could increase capacity further, whilst giving the flexibility to run short trains on quieter services or being able to run to serve two locations from one path.
Is there any data that has demonstrated a reduction in car journeys as rail journeys have increased? Or has the total number of journeys by car and rail both increased? Clearly if HS2 can demonstrate a link between train higher frequencies between major urban centres and reduced car usage in those corridors, it would be a further reason to speed up the later phases of HS2 and support extra capacity lines say a HS3 from London to Bristol/Penzance and a HS4 from Brighton/Gatwick
Probably both have increased, but there can be a common factor(s) in that case (e.g. rising population). A better question to ask is whether increased rail use has made increases in road transport lower that they otherwise would be without the investment and growth in rail. I would think logically it must have done, since it is extremely unlikely that all these extra rail journeys are being done for fun or because people are bored, rather than being standard essential utility journeys.
