Why can’t modern rolling stock be as spacious and comfortable as Mk 1 coaches?
Ethano92
26 Jun 2017
As someone born in the 90s, I only have traveled in MK3s. However on the Southern Region slam doors I would travel on in school summer holidays I don’t remember the noise being particularly bothersome. Then again, I was a child.
This thread raises a good question. Why are the 1972 Bakerloo Line tube stock such a pleasure to sit on, but the 2009 Victoria Line stock hard and unwelcoming? Why are modern EMUs so garish and the seats so hard? I wish they could build trains’ interiors like how they used to.
It's completely opinion isn't it though. I can't say I find the jaulty acceleration of the 72 stock comfortable, or the more cramped,dimmer feeling of them although I'm not old enough to know what they were like when new. The brightly lit 09 stock with proper dividers between seats and smooth, consistently rapid acceleration is much nicer, alongside the better standing provision. As much as the 72 interior would generally be considered dated in its colour choices, others will prefer it; very opinion-based.
23 Nov 2015
Mk1 or EPB type suburban stock is not really, in my view more comfortable than modern equivalent - apart from softness of cushions maybe.
Mark 1 suburban stock (the likes of the VEPs) was utterly appalling and outdated before they were built thanks to the Southern's inability to grasp any sort of modern thinking. Their replacement by the various Junipers, Desiros and Electrostars represented the same step-change in quality for SR passengers that the Mark 3 had for Inter-City passengers 25 years before.
xotGD
4 Feb 2017
The ridiculous fixed armrests to make it difficult getting in and out of the seats, the constant squeaking from the corridor connections and the stench of the brakes. Yes, Mark 3s were truly a step change from Mark 2 air con stock.
The seat dividers on the 72 stock were removed due to vandalism, something which is much less of a problem on the Victoria Line, indeed the similar 67 stock retained theirs to the end.
It’s also worth remembering that the 09 stock is built to slightly more generous dimensions than any other Tube stock, allowing it to be more spacious. The brown colour scheme on the 72 stock also relates to the Bakerloo Line.
43096
23 Nov 2015
Constant? Not a squeak from the last Mark 3 I was on. Mark 2 aircons: noisy brakes, aircon that was more "con" than "on", no air suspension and 20% slower than a Mark 3.
WesternLancer
12 Apr 2019
Good point ref VEPs. I had inner suburban stock in mind in my comment (though I recall thinking PEP suburban units being a revolutionary step change for the southern, at the time). Outer SR mainline stock (eg CIGs BIGs REPs and Kent Coast stuff) I always found very nice - as mentioned above by others.
Apart from the physical seats (which is a matter of opinion), does the Class 397 not tick that box? Mostly tables, decent spacing, window alignment good.
hexagon789
2 Sep 2016
To be honest mk1 MU stock rode pretty well at 90mph. Remember the sprung seats were a secondary suspension as without them it would be a pretty rough ride
It could well be the jointed track, but you don't feel crossings in a Mk3 whereas you feel the joints in a Mk1
hexagon789
2 Sep 2016
Your last part amuses me no end... a Mk3 beats a mk4 by a country mile and then some: mk4s have always struck me as a backwards step in terms of ride quality, particularly at speed.
I never had issue with Mk4 ride in GNER days, but I will concede it's poorer currently. A Mk3 is superior in terms of ride, internally though I think Mk4s are generally nicer presently
hexagon789
2 Sep 2016
I remember going on a Merrymaker from Huntingdon to Edinburgh back in the 70's. Waiting on the platform at Huntingdon for expected FP 47 when a LA 46 (4600?) with Mk1's turns up. To cut a long story short, we got held up somewhere between PBO and DON for quite a while which the crew tried to make up for the rest of the journey and I swear we were doing in excess of a ton at times. We were in the last coach which at times which seemed quite hair raising at times and to be almost floating. Eventually got into Waverly about 60 late.
Quite possible, my understanding is that 40s struggled to achieve their rated 90mph on level track while 45s and 46s could outperform 47s if driven well - 100mph being perfectly feasible. After all I've seen a log of a 47/7 manage 109mph on a E&G shuttle in the 1980s, and they are similarly powerful locos - 2500hp (Cl. 46) vs 2580hp (Cl. 46)
High Dyke
1 Jan 2013
Yellabelly Country
Agree on both counts. My thinking was if they ride that roughly at only 20-25mph, what on earth are they like at 90-100mph?
Probably better than a modern Azuma set. They don't give a good ride IMO. However, how much is that actually down to the different seating style? As an aside I find a Mk3 HST, on the Midland Main Line, gives a rougher ride than a Meridian.
Bikeman78
26 Apr 2018
I used to blast around the Southern quite happily on them. I remember when Connex replaced the VEPs on the Horsham line with 319s. The latter found bumps in the track I never knew existed.
Geoff DC
27 Jan 2018
Penzance
My last regular MK1 ride was a weekly commute from Bristol to catch the Southampton/Cowes Ferry in 80/81.
Mainly 33 hauled compartment stock & I remember them as very comfortable
A lot of the stock was re-upholstered with the armrests sown in - but it didn't take long for the regulars to unpick them and make them even more comfortable.
I've been travelling by train since around the mid-50s & have travelled on some superbly comfortable stock up until & including MK3 HSTs - a GWR IET is light-years away from anything in the comfort stakes even in 1st Class
Bikeman78
26 Apr 2018
As someone born in the 90s, I only have travelled in MK3s. However on the Southern Region slam doors I would travel on in school summer holidays I don’t remember the noise being particularly bothersome. Then again, I was a child.
I find modern train interiors far too bright. It started with the Great Western HST refurbs. I also find car headlights far too bright these days.
xotGD
4 Feb 2017
We could go on all week failing to convince each other!
I'll call it a day.
WesternLancer
12 Apr 2019
I have found Mk3 HSTs on MML rougher riding than LNER Mk 3HSTs on ECML when on recent trips on the HST LNER final weeks. I wonder how those LNER HSTs will perform when they mover over to MML ride wise.
hexagon789
2 Sep 2016
Dampers? The originals for the Mk3s are no longer manufactured.
hexagon789
2 Sep 2016
I've generally found the T-3 bogies (and similar versions) give quite high levels of ride comfort. C
paul1609
28 Jan 2006
Wittersham Kent
In the early 1980s Portsmouth FC (my team) in conjunction with BR used to run football specials to many places up north. The stock used to be a set of MK1 coaches that were during the week used on the Portsmouth to Cardiff service. These were to say the least somewhat in need of refurbishment. Haulage was normally a 33 or two from Portsmouth until you got to either north of London or Bescot Yard in Birmingham when the appropriate regions loco wouldtake charge. The ride up to about 70 mph was okay but beyond that would be horrendous. I remember one particular trip to Carlisle where a class 86 was used was a real white knuckle ride the bogies would sway sideways violently. As all the batteries on the sets were knackered the lights normally went out when speed dropped below 25 mph by the end of the day. Happy days
071
24 Mar 2019
Chester
Not a lot of love going on for the Mk.2. I thought the air-conditioned stock - the Mk.2F in particular, was excellent. Still remember my last trip on one, a VXC service from Reading to Manchester in around 2001/2002. Although I like the Mk.3 they're not as good as a decent Mk.2 in my book. Have always been underwhelmed by the Mk.4s.
Speed43125
20 Jul 2019
Dunblane
When these carriages were introduced, photographs from the era also suggest many trains were a lot longer than today. Sometimes 12-14 coaches.
While, as has been said, many intercity trains today are in fact of similar length. Train lengths on regional routes have decreased, for example many scottish services went from 47 + mk2s.(dbso) to 2 car 158s, similarly, on introduction, HSTs were 7-8 carriages, compared to the prior trains of up to 16. (they were nicknamed 'half-trains' by enthusiasts of the day due to their short length.)
The thinking here was, to attract more people to the railways services would run more frequently, but be shorter. So as an example what may have been a once daily XC service would be upgraded to many more frequencies with less capacity. Of course, the issue was, that worked, and then the short trains have become completely unsuitable for the increasing passenger numbers (check Scotrail HST thread for peoples opinion if a 2 car 158 is subbed in for a HML service now!)
20 Nov 2019
Merthyr Tydfil
By the time I was born I think most if not all the mark 1s had left mainline duties, so my only experience of them is on heritage railways.
They have amazingly comfortable seats compared to modern stock, although it seems like all new trains are less comfortable than their predecessors. I do think they ride quite poorly though, no where near as smooth as a mark 3.
And that's the ride at preserved line speeds (no quicker than about 40mph). I've no clue what it's like at higher speeds. The fastest I will have done on them is about 70 when I was on a rail tour hauled by Leander, however I was only 8 and so remember very little of it.
I'd take the mark 3s and 4s over them, as unlike many others who may be reading this, it's those that I have nostalgia for, whereas I have no attachment at all to the mark 1s (or the mark 2s, which I have even less experience of).
TRAX
2 Dec 2015
France
Why can’t modern rolling stock be as sweating hot in the summer, as icy cold in the winter, as crash-vulnerable, as noisy, as old coaches, you mean ?
aah, rose-tinted nostalgia.
Aictos
28 Apr 2009
Yet some here think that those same type seats on the EMR HSTs are better then the Mallard type seating that GWR, XC and LNER have....
WesternLancer
12 Apr 2019
well, I think they are in terms of seat layout, but not so much in terms or say...arm rest design!
I wonder what the design process was when the original HST seats were designed, as they were of course obviously awkward from day one. Does anyone know how that seat design emerged? And at the start they had more tables, which adds to the difficulty of getting in and out of one.
It's reassuring to hear the usual bluster and nonsense from the anti-mk1 brigade.
I regularly used Mk1 hauled and emu stock in the 1970s. Generally pretty smart and kept clean, so not worn condition. Admittedly some issues in compartments with vandalism commensurate with the general increase in vandalism in the public realm during the 70s I would say. Obv plenty of Mk1 stock was not compartment.
This is very much my experience of mk1 stock in the late 1980's and 90's on the Southern. NSE had done an extensive refurbishment programme which helped in this respect, but other than the EPB's, which suffered some vandalism on account of the areas they served, things were generally tidy and well maintained. This includes DEMU's which generally received the NSE treatment later than the electric units.
Aictos
28 Apr 2009
What bluster? The Mk1s with their interior layouts eg compartments are totally unsuitable for the modern railway as trains would be overcrowded.
The best place for Mk1s are on a heritage line trundling along at a sedate 25mph.
Finally not everybody insists on wearing rose tinted specs and seeing it only their way as is the case for those who are stuck in the past.
WesternLancer
12 Apr 2019
Yes, I recall being very impressed with the 'heavy' refurbs of the CEP and BEP Mk1 units (and I think Clacton EMUs also got this) - hopper windows, brand new formica panels, new seats etc when they appeared - pic here
http://www.semgonline.com/gallery/class411_5.html
tho I think this was also driven by the complete re-build they needed to remove asbestos, but being a bit disappointed when the CIG refurb programme was more just heavy cleaning and re-upholstery - yet they benefited enormously from that. In time, when I became more interested in interior carriage design, I came to appreciate the retention of the older formica paneling etc, with it's more muted quality of design. As mentioned above though, I did find VEPs a strange design choice - one heck of a lot of doors to maintain!
As you say DMUs were kept smart too - though the vandalism problem is illustrated in one of the pics here
http://www.semgonline.com/gallery/class207_4.html
It was really in Connex days that things started to get bad pretty fast - they must have decided that the way to run the franchise with reduced costs was a massive reduction in carriage cleaning and maintenance. It was depressing how bad they got and how quickly that happened. A real indictment of privatisation were one needed. I think SWT did a better job with the Mk1 stock they were responsible for.
WesternLancer
12 Apr 2019
But most mark 1 stock you came across, esp by the mid 1970s was not compartment stock (unless it was on some lines?) - however, obviously by then they were getting 'old fashioned'.
But I think the jist of the OP's post was why can not modern stock have some of the basics of the design advantages from that era - window alignment, comfy seats, leg room etc - which of course it could. Combine best of the past with best of the present.
