Wi-Fi
Simming
8 Jun 2005
Cornwall
How Good is it?
How Much is it?
How Fast Is It?
Is It Worth carting a laptop with me on trains to use it?
jd
9 Jun 2005
Depends on your needs. Depends on the location of the Wifi access point. If the access point is some way away, you will get a poorer quality signal and a lower speed - if it is closer, you will get a better speed. Though I can't *really* help you, I've never used public Wi-fi, nowhere I go regularly has it...
Mojo
7 Aug 2005
FGW seem to be installing at their stations, indeed, Bristol TM and Bristol PW have it. It's £4.50/hour :o
Techniquest
19 Jun 2005
Nowhere Heath
Not bad, about the same charge as GNER IIRC.
Don't forget, this is how we get such excellent new technologies, by paying for the installation and so forth through the useage charge.
Wi-Fi is also available in selected areas of Paddington, if not all of it, but whether a charge is implemented here I don't know.
I'm very interested in Wi-Fi, especially when I eventually get a laptop and Wi-Fi card to use. Nothing like being able to check connections at Edinburgh when you're still on the train passing through Chathill. Or like being able to post gen, news and comments/debates/rants on the forum whilst the gen/news/rant is still fresh.
jd
9 Jun 2005
Simming said:
sorry, I meant on trains, should have said that clearer
Yeah I know - still applies though. I don't know how the Wifi points are being installed on board, but if there is only one point, say, in the centre of the train, you might not get very good signal if you are at the extreme ends of the train. I don't *really* know much about Wi-fi, as I say, but I know my laptop, when in my room, about 5m from my access point, only gets 'Very Good' not 'Excellent' signal - walls do tend to block signal - I don't know how the walls within a train would affect it though.
If you are getting a laptop new, then its highly unlikely you'll need a card - all laptops (AFAIK - I'm 99% sure they all do) come with Wi-fi built in. If you are getting second hand, then you may or may not need a card.
