Will this service run...?
Boothby97
24 Apr 2011
Grimsby
Well its timetabled to run from
16/02/2015 to 15/05/2015
so it may a bit unpredictable as to when it runs. I would assume its a transfer move for 66s coming off maintenance at Longport for Freightliner.
2030720310
20 Jan 2009
With some trains on realtimetrains you only know if it will run after its departure time from the origin place. If it is on the system it will run, if it isn't then you can usually, I think, presume it isn't. With many trains that's the only surefire method you have to know if a working is happening. Feel free to correct me if I am wrong!
Freightmaster
7 Jul 2009
Correct - that especially applies to WTT freight services,
but even STP workings are by no means certain to run;
some are just speculative paths which end up not being
needed on the day.
However, many non-passenger services are reliable, regular runners,
which I presume are the trains this topic is intended for?
MARK
Trainfan344
13 Oct 2012
needed on the day.
MARK
Yes, a thread for posting non-passenger services to see if anyone has any idea if it is likely to run on the day.
