Techie help needed!
We have a Dell Inspiron laptop, that we upgraded from Windows 7 to 10. It worked fine for a month or so, then, after a forced upgrade, it has stopped. Turn on, Windows flash screen with whirling dots, then.......a totally blank screen
Googling any combination of the hardware/software/symptoms brings up a plethora of solutions, ranging from upgrading the bios to turning the thing on without the battery, all claiming to fix the problem, but none does. Particularly useless are those that start "Open Task Manager..." (Hint - blank screen = no Windows available). I suspect the experts are baffled.
I can get into Windows in "Safe" mode, but with very limited connectivity or ability to do much - not that I would have much idea what I should be doing at that stage.
Any ideas? Helpful if possible, and none along the lines of "Ubuntu would save you the trouble". We are where we are. Thanks
