sufian123
They aren't going yet, but they will be replaced by the new Aventras.
350/2 be staying London midland livery till they go?
So, First Capital Connect then?
It surprises me how slow this is all happening.
It's surely fairly easy to do these days, although I can see London Midland leaving the units to go bad nearer the end of the franchise so I understand a lot of work would need to be done first.
But I'm sure other franchise changes removed names pretty much overnight.
Good suggestion. The 365s are rather reliable that are too young to be stored in a middle of nowhere waiting to be scrapped.if theyre short of units then why dont they ask GN for their 21 spare 365s. You'd need training etc. but as a longer-term soloution I think it is viable
If that's true then what routes are they cleared to run on (excluding London midland)Unfortunately, as @D365 has explained about a million times, the 365s are a nuisance to clear for use anywhere due to their traction electronics, but if they're short of units, the sensible thing to do would be to hire more 319s, which they already operate, which is exactly what they've done...
Could they do testing on routes they're not cleared for or will that require some modifications?
The plan is for the /3's to receive full wrap at a rate of one every two weeks commencing shortly.
The mark 1's require corrosion repairs, mainly along the roofline before they get wrapped.
The mark 2's will not receive WM Livery as they will be departing these shores.
The mark 4's will also be wrapped when they arrive later next year.
All units are being applied with WM Branding when they are on depot exam.
Good news! always a mess when a new operator takes over in branding termsSo as soon as the program starts, all 350/3s will be done within 20 weeks. Sounds good.
Seems highly unlikely. I suspect more 350s will get put onto the WMR routes that share LNR routes, and convert them to LNR services then & there (in name only). I heard 323s may also be using the Chase Line, which makes more sense, given that the replacement stock is due to be 3-car Aventras.Will some of the 350s get repainted into West Midlands railway livery as they will be used on the chase line once electrified
I can see that, but feel free to quote/link your source.I heard on the grapevine (twitter) that WMT were not happy with the West Midlands Railway livery and that’s why no more have been repainted into the new scheme
Although I'm not sure I understand the "cleared for this or that" business.
Surely ALL trains are built to the UK loading gauge, and all line side equipment is at the same standard. Thus, any train, could go anywhere without banging into anything? I understand there is a lot of difference between coach lengths, but there aren't hundreds of different lengths, so surely they need to clear the route with any "23 metre" train and it'll be cleared for all?
I know I'm obviously being naive here, but I don't understand why it seems too complicated to clear trains for routes.
They do indeed; it's the AC traction equipment that causes the problem. In DC 3rd Rail land, all the track circuits have to be AC to avoid the live rail interfering with the running rail over which the circuits run. In AC OLE land, where track is continuously welded, AC circuits at varying frequencies are employed for the same reason.The issue with the 365s (I interpret it as) is that the onboard electronics have the potential to interfere with certain types of signalling equipment. I assume this will be frequency based track circuits. There will be lots of other issues to like platforms heights. Class 185s can’t use platform 5 at Scarborough due to clearance issues.
