Central Trains
- Joined
- 21 Nov 2010
- Messages
- 199
Any chance anyone could give me the several routing ways an any permitted York to Birmingham ticket is valid please?
Thanks in advance.
Thanks in advance.
You can take a through train.
You can take the shortest route (using the mileages given in the National Rail timetables).
You can take a route up to 3 miles longer than the shortest route.
You can take up a route permitted by ATOC's routeing guide. That means:
a route drawn between York and Birmingham on map BY without doubling back;
a route drawn (without doubling back) by starting from York on map MN, getting as far as a point common to maps MN and and BM, and then continuing on map BM from that common point to Birmingham; and
a route drawn by starting from York on map MN, getting as far as a point common to maps MN and TM, continuing on map TM from that common point to a point common to maps TM and BP, and then continuing on map BP from that second common point to Birmingham.
Listing all the mapped routes would be a long job. Taking just map BY on its own, a mapped route has to go via Meadowhall, Sheffield, Chesterfield and Derby. But as there are 8 possible routes between York & Sheffield, and 5 possible routes between Derby and Birmingham, that means that there are 40 possible routes just from map BY. Add to those the various routes given by MN+BM and MN+TM+BP (which include routes via Manchester) ....
Leicester is, Nottingham is not (bizarrely).
York - Leeds - Manchester - Crewe or Stoke - Stafford - Nuneaton - Birmingham is also permitted if you fancy a spin on the Trent Valley services.
Thanks for your help.
So...York - Doncaster - Sheffield - Leicester - Nuneaton - Birmingham. Would be a permitted route?
The reason, of course, is that there are diversions this week and trains from Nuneaton are going via Walsall and Bescot into Birmingham instead of the direct route. So if you're travelling this week, it might make an interestingly different journey.
Yes, this week (only) you could go Derby-Birmingham via Sutton Coldfield, either High Level via Lichfield or Low Level via Coleshill.
This last one is recommended as a scenic route: it's surprisingly full of woodlands and golf courses!
And maybe even via Beighton if the landslip closes the direct line north of Chesterfield as threatened.
