Class 88 UKDual & EuroDual
leomartin125
15 Nov 2015
North West
According to RTT, today's southbound run is cancelled - http://www.realtimetrains.co.uk/train/R00474/2017/04/05/advanced - as is the return - http://www.realtimetrains.co.uk/train/R00475/2017/04/05/advanced
The links to RTT in the earlier post are only for the Monday trips - you need to look on RTT for the equivalent trips on the other days this week.
However, it is running as a light engine test instead:
Outbound:
http://www.realtimetrains.co.uk/train/R00503/2017/04/05/advanced
Return:
http://www.realtimetrains.co.uk/train/R00504/2017/04/05/advanced
I haven't seen flashing headlights before, as shown in some of the videos.
Is this a new operational requirement?
Or is it just a "feature" (or a video artefact)?
Impressive that it's out in regular traffic; the traction package must be OK.
Darandio
24 Feb 2007
It's just the LED effect which is to do with the difference in frequency between LED light and the video capture. The lights aren't actually flashing if you view them at source.
TimboM
12 Apr 2016
The lights aren't actually flashing in 'real life' - it's something to do with the new-style LED(?) lights and the way cameras pick them up. I'm sure someone can explain the exact reason, but something to do with the different frequency/way the light is emitted and the frame speed of the camera used to film them.
Bit like when it appears wheels are moving backwards on a car driving forwards in a film, or rotor blades on a helicopter are moving very slowly...
Also, the 88 isn't in regular traffic just yet - this week it's on test runs usually to Crewe and back - some of these are 'loaded' test runs with a c.1,500 tonne rake of ballast wagons (plus a 68 tucked in behind as 'insurance' but not doing any of the hauling as far as I know). This is what's in the videos folk have posted.
Hope that clarifies a couple of things you've seen in the videos.
furnessvale
14 Jul 2015
Yes I believe that they can.
Sam
That would probably be the best end result.
In all but the most extreme conditions a single 88 could manage effectively on the northern fells but a 68 in tow could assist it out of trouble, say from a dead stand at Scout Green in a blizzard.
Yes, it did look very odd, but I see it's a digital artefact, like photographing PIS displays and getting next to nothing because of the flicker!
By normal traffic, I mean not under possession.
That means NR must be happy with the interference issues that have plagued many new electric types (including IEP), at least up to a certain level of power on the 88.
Class 345 is another one which seems to have appeared out on the network in short order.
I'd be interested to know which traction packages they are using.
3 Mar 2006
GEML/WCML/SR
Whilst I must emphasise the IF - Reported to have been sent to the rescue of yet another stricken GBRf 92 around Shap... If correct and it can get the China clay tanks, a dead 92 and possible a dead 66 moving from a standing start then that's not shabby - unless it was over the top and going downhill!!
37038
11 Apr 2014
took 6S94 back to Grayrigg loop. 88 returned KM light engine.
DRS 66 hired to take 6S94 to carlisle yard, dead 66 will run round 92 and continue forward
Sunbird24
26 Oct 2013
La Mont Ravana
LED lights do flicker but at a very high rate which the human eye cannot normally perceive due to the human eye's persistance of vision. LEDs operate by a very rapid pulsing of power. The same reason old cine films appear to flicker (hence the old term "going to the flicks") as the frame rate was only 16 fps, later 24 fps to reduce the flicker. Modern videos are in the order of 48 fps.
sonorguy
18 May 2011
It's very apparent if you watch any of the UK motoring shows, Top Gear, Grand Tour etc, especially if they show a car in slo-mo that has LED lights, the flashing is obvious. In that setting it's an effect utilised intentionally.
rebmcr
15 Nov 2011
St Neots
If you look very closely you can notice the frame tearing -- exhibited as horizontal boundaries within the flicker.
furnessvale
14 Jul 2015
As you say, possible IFs.
I doubt the conditions were the extremes that twin 68s or 86s have to be capable of handling before being let loose on the northern fells.
There is always the possibility the assisting 68 was fired up.
Nevertheless, I am sure the 88 will be a very capable machine, as long as it is not oversold.
TimboM
12 Apr 2016
I thought the 88 was running light engine today, in which case there wouldn't be the assisting 68? Appears the 88 was just used to pull the china clay train back into the Grayrigg loop (presumably it's downhill in that direction). Would be interesting to see if it could manage a nigh-on 2,000 tonne train up Shap, but we'll have to wait for it to complete acceptance tests before we find that out... :)
furnessvale
14 Jul 2015
It certainly has enough horses as an electric on a dry day. As always, my worry is the lack of axles laying all that power on the rails in poor adhesion conditions.
Similarly a single 86/90 has sufficient horses on a good day, but they run in pairs in case of bad conditions which has to be allowed for, if the job is not to grind to a halt on such days.
37038
11 Apr 2014
With modern traction systems in place, in won't have any issues. 68s are very well regarded in translating grunt to traction efficiently
Roast Veg
28 Oct 2016
I remember hearing that the same concerns about Bo-Bo arrangement were raised with Vossloh (as it was) over the 68s, and they demonstrated that their design was perfectly suitable in response.
Sunbird24
26 Oct 2013
La Mont Ravana
Some interesting information in the newly published franchise document regarding the use of 68s by TPE is that the number of locomotives could be increased up to 18, and that once electrification is completed some or all could be replaced by 88s, if they are available. Although the maximum speed of the 88 as specified for mixed traffic is 160 kmh (100 mph) the design speed for passenger use only is 200 kmh (125 mph). This could mean that if there is a requirement for more 68s in the future, then this could be achieved by building more 88s, perhaps geared for higher speed also. All depends on how far away the electrification is in reality.
On the 68 front in Valencia 68029 is now looking complete in plain blue livery and 68030 was out on the test track today, also in plain blue but far from complete in other respects.
Bornin1980s
4 Apr 2017
I have an elderly family friend who has found that video displays can give him migraines. Will LED lights have the same effect on sufferers?
Roast Veg
28 Oct 2016
Only if you were to stare directly at them for prolonged periods of time, which I don't recommend anyone does for any light source.
furnessvale
14 Jul 2015
Fair enough. I remain to be convinced that there is any alternative to extra axles laying the power on the rails when adhesion is a problem.
I have said before, give me the same number of horses and the same traction control package, with 2 extra axles I will move more tonnage in bad adhesion conditions.
I think this is the place to post the fact that Beacon Rail, owner of the Class 68/88 locos and CAF sleeper coaches amongst others, has been taken over by American bank JP Morgan.
This sounds like a more secure place to lease rolling stock from.
It is still relatively small by UK ROSCO standards.
http://www.railwaygazette.com/news/business/single-view/view/jp-morgan-buys-beacon-rail.html
An agreement has been signed for JP Morgan Asset Management to acquire the Beacon Rail rolling stock leasing business from Pamplona Capital Management for around €1bn.
Completion of the deal is expected shortly
CosherB
23 Feb 2007
Northwich
Reported elsewhere that there is likely to be minimal movement for the remainder of April for the 88s, as it stands. They've "jumped through all the hoops" asked of them, now just a case of waiting a formal sign off by NR for general use, and ongoing commissioning of 003-010.
TimboM
12 Apr 2016
Will they not be using the opportunity of the time waiting for NR paperwork to do some driver training runs? I guess there's a fair amount of similarity to a 68, but there must be some differences, and hours that need to be accumulated in the cab?
Also, we know 88001 and 88002 appear to be running fine, but you'd think as part of the commissioning of 003-010 it may be prudent to give each of them a decent test run at some point?
