13:10 Weymouth -> Gloucester
CC 72100
23 Jan 2012
Hi,
Does anyone know what DMU is usually booked for the above working? I am travelling home from Uni in Exeter on Friday, and just wondered if it is normally a 150 or a 158? I'd much rather have the latter - the class 150 is the only DMU I detest more than the voyager which I will have Exeter to Bristol! :p
Many Thanks,
AdamW
heart-of-wessex
11 Jun 2005
Trowbridge
The unit starts from Westbury at 0638 for Gloucester, then works to Weymouth for the 1310 to Gloucester. It's the 0644 from Trowbridge which I have done before, and once it was a Class 158 but often a Class 150 otherwise
TEW
16 May 2008
Only 158 booked to Weymouth Mondays-Fridays is the 1450 Great Malvern-Weymouth and 2021 Weymouth-Bristol Temple Meads.
PHILIPE
14 Nov 2011
Caerphilly
Booked 150 and attaches another at Bristol tm for strengthening, especially for the return 16 41 Gloucester to Weymouth.
CC 72100
23 Jan 2012
Look like I'll have the delights of a 150 to look forward to then! I dear God hope that at is a 150/2, a 150/1 on that run would be unappealing indeed! Will report back of course.
CC 72100
23 Jan 2012
It's ok Dan, I'm only on it Bristol to Glos, but feel sorry for the poor folks who do the whole 3 hours on it!
My ideal used to be when I had no lectures on a friday, so HST to Bristol, for 158 forwards. Voyager then 150 forward doesn't have the same appeal!
Schnellzug
22 Aug 2011
Evercreech Junction
I've seen two-car 158s on it fairly often recently, although, as usual with FGW, it could be anything including 150/1s on occasion.
ValleyLines142
25 Jul 2011
Gloucester
Voyagers all the way! I suppose you could go on another journey booked for a 158.
VTPreston_Tez
26 Jan 2012
Preston
FGW don't run 158s very often here. I've only rode 150s and if I'm not hallucinating I think a 152 one time? Maybe a 154? I remember a train that reminds me of 158s when Wessex ran this line though can I get clarification?
So basically the 150's lot that give you backache and have no tables. :P
MidnightFlyer
16 May 2010
152? The failed plan for 156s?!
Some FGW 150s have tables in bays of four...
VTPreston_Tez
26 Jan 2012
Preston
150's with tables? I've never seen them
So 152's do exist? I wasn't sure but think I've rode one from Weymouth to Bristol (terminus Gloucester)
MidnightFlyer
16 May 2010
sprinterguy
4 Mar 2010
Macclesfield
152s from what I can gather were some sort of failed plan for converted 156 units, but I'm not 100% clear on what it was about. Certainly to the best of my knowledge never existed in reality though.
Contemporary issues of Modern Railways report that in the early nineties Regional Railways were so pleased with their fancy newly-converted class 153s that they considered additionally splitting up as many as 25 class 156 units into up to fifty single car units. However, the sources I've seen report that they were provisionally titled as Class 154 (Also used for the sole class 158 testbed, 154002). Wikipedia notes that these units would have been class 152 though.
So no, there has never been a class 152. And only one, very short lived, class 154 for that matter. So something "a bit like a 158" operated by Wessex Trains would probably have been a 158.
TEW
16 May 2008
The 2-car 158s don't have diagrams at the moment, there's only two of them and they seem to turn up on pretty much any diagram, often instead of a Class 150 which can see them work to Weymouth.
150/1s are fairly common to Weymouth nowadays, the 150/1s often seen to end up on the most inappropriate services such as the long distance Weymouth, Cornwall and Southampton services. They do tend to move round though, so Cornwall will have lots of 150/1s for a while then Bristol will have lots of 150/1s for a while then Exeter.
Yeah, some of the 150/2s do, well, the one to Topsham the other day certianly did!
All the 150/2s have tables except for 202 and 216 which transferred from London Midland. Makes up around half of the overall 150 fleet.
CC 72100
23 Jan 2012
So it was as I assumed a voyager (still as bad as ever) to Bristol and I'm currently sat on a pair of 150/1s, 122 and 101 if you're interested, both looking very dated inside and out with the old central trains livery!
RobShipway
20 Sep 2009
Could have been worse, if FGW still had the class 142's doing the route which I believe happened from time to time in the past before they got moved back to Northern.
PHILIPE
14 Nov 2011
Caerphilly
142s have never worked the route as they were all confined to the Exeter area only. 143s have worked the route between Bristol and Gloucester but long past now.
RobShipway
20 Sep 2009
I remember being at Bristol Temple meads one Saturday afternoon, a couple of years back and the train for Weymouth was a class 142 but I cannot find the details at the moment of which of the class worked the route as I think it was used in place of the booked class 143.
PHILIPE
14 Nov 2011
Caerphilly
142s were confined to Exeter area and only Exeter Drivers had traction knowledge so they were restricted over the routes they would work. 143s, nor 142s for that matter, cannot work to Weymouth due to route availability (banned on Southern)
TEW
16 May 2008
143s never went to Weymouth either, pacers are banned on the Southern Region. 143s did used to work Westbury-Bristol, Bristol-Severn Beach, Bristol-Cardiff, Bristol-Taunton and Bristol-Gloucester though, in fact that was all they did before 2008 when they were transferred to the Exeter area. 142s have been in service in Bristol only a handful of times with FGW. Mainly on the Taunton-Cardiff corridor although one made it on a Bristol-Westbury service once. Crewing issues made it difficult to run one Bristol-Westbury and impossible to run one Yeovil Pen Mill-Weymouth. Only Exeter crews ever learnt Class 142s.
Drsatan
24 Aug 2009
Land of the Sprinters
I think in 2006 a 143 ran to Eastleigh via Southampton Central under its own power to enter Eastleigh Works, so I'm assuming NR grants dispensations for special occasions.
Lrd
26 Jul 2010
I heard they went via Romsey, and remember reading a comment on another thread that it took a lot of paperwork.
ValleyLines142
25 Jul 2011
Gloucester
143s work Cardiff services. I've never seen or heard of a 142 making it to Cardiff or even Bristol. They all seem to be confined in the Exeter area.
heart-of-wessex
11 Jun 2005
Trowbridge
I've heard about the 142 that went to Exeter via Westbury or something, but otherwise I have seen a 142 at Bristol but was in Middle Siding 1 (or could have been 2), but don't know what it's next turn was, but it obviously made it to Bristol on something...
TEW
16 May 2008
143s don't work to Cardiff any more, they had a few runs until December but since 2008 most of the 143 diagrams were around Exeter, now they all are. 142s were always diagrammed to be around the Exeter area but they strayed from time to time, fairly sure one has reached Cardiff. Bristol has been reached many times in service, Swindon has a few times as well. Of course, no 142s now.
Schnellzug
22 Aug 2011
Evercreech Junction
there was an incident fairly recnetly when, I think it was 142+150 worked Exeter-Swindon, was it, vice HST (I love jargon), on an early morning Paddington serbvice.
