1992 stock Refurbishment?
Dstock7080
17 Feb 2010
West London
I wonder how real this is?
Because this unit (with PIS) sounds normal.
The trial interior fitted trains are not yet fitted with AC motors, the AC motor fitted trains don’t yet have the trial interior.
These will be married together in the next stage.
9 Dec 2012
Has a specific Barman moquette design been done for the central line refurbishment, the Piccadilly/Jubilee blue version never did sit well in the 92 stock against the red and grey interior.
Nym
2 Mar 2007
Somewhere, not in London
No doubt it will be, need to keep all the graphic designers in work while the rest of the workforce are out on their backside with pay cuts and conditions loss.
Goldfish62
14 Feb 2010
The Piccadilly line version isn't the standard version. It's quite a bit different.
I look forward to seeing the Central line version, although I'm not a Barman moquette fan.
Recessio
4 Aug 2019
Are those the same displays on the Northern 95 + Jubilee 96 units? Surprised they haven't gone for full screens like on Overground 710s.
It doesn't like it has much of an interior at all at the moment, what with half the panels and seats missing!
Seen worse interiors in revenue service on Southeastern :lol:
JaJaWa
14 Feb 2013
They look like the ones from the 2009 stock (which also use the digital version of the TfL font)
rebmcr
15 Nov 2011
St Neots
There is a global semiconductor shortage. The integrated circuits that drive LCD panels are a lot more intricate and can be manufactured at a lot fewer locations, compared to older, simpler technology that can drive an LED matrix.
Mikey C
11 Feb 2013
Would the bigger screens, as with the 710s, fit a tube train anyway?
py_megapixel
5 Nov 2018
Northern England
They're present in the mockup videos for the new Piccadilly Line stock. Central line trains have absolutely enormous windows, so covering a bit of the window would be no real issue and as someone mentioned a few posts back would probably be an advantage as it would keep it cooler in the summer!
357
12 Nov 2018
What's the power consumption difference between LED and LCD? I seem to remember they only found the extra power for these screens by converting the internal lighting to LED.
Lewlew
15 Oct 2019
Thats the 1972 stock on the Bakerloo
rebmcr
15 Nov 2011
St Neots
The light source in modern LCD panels is LED, so no great difference.
Older LCD panels used cold-cathode tubes (like flourescent strip lighting) which consumed more power, but still not nearly as much as incandescent bulbs.
Nym
2 Mar 2007
Actually is quite a big difference in driving an LCD screen compared with a dot matrix indicator. It's not just the backlight that's the issue.
321over360
17 Jul 2015
Will be interesting to see a full complete train in due course, although not as clear to tell from the video, will the central line fleet have external viewable displays to show the destination of the train like on the 2009 and S Stock trains?
Dstock7080
17 Feb 2010
West London
The displays aren’t double-sided, so no
Railperf
30 Oct 2017
Is there still a plan to allow these to run at 100kph once remotored? I can't remember if new bogies were also required.
Dstock7080
17 Feb 2010
West London
100kph is not in the current plan, new bogies are not being provided.
Once line voltage has increased to 750vDC and regenerative braking fully implemented then things may progress.
Railperf
30 Oct 2017
what are the planned timescales - if any - for that?
rebmcr
15 Nov 2011
St Neots
Presumably there are efficiency benefits for spares and competence once all the LUL lines are using the same 750V design. -210V is rather uncommon after all!
Lockwood
4 Apr 2013
Will they go +750 or +500/-250?
I'm guessing that some of the reasons for the negative voltage still exist?
