450 desiro stopper
Discussion in 'Traction & Rolling Stock' started by NSE, 3 Nov 2011.
Thread Status:
  1. NSE
    NSE Established Member
    1,238
    3 Mar 2010
    Hello all, at 19:45 today (3rd November) I pulled into Raynes Park platform 4, to see a Cl 450 stopping at platform 2, letting passengers off and everything. What was this doing on a stopper? I know a few stop at Wimbledon late at night on Basingstoke runs, but not this early or at Raynes Park.
    Thanks.
    Rail Forums
  3. Matt Taylor
    Matt Taylor Established Member
    2,287
    31 Aug 2008
    Portsmouth
    That would be 2H62 1906 Shepperton to Waterloo, formed of the stock off the 1813 Waterloo to Shepperton via Richmond. It's a booked 450 job every night.
  4. Norman
    Norman Member
    43
    20 Mar 2011
    That reminds me of when i got on a 2 x 450 from Tolworth to Motspur Park a couple of years ago!
  5. Matt Taylor
    2,287
    31 Aug 2008
    Portsmouth
    They do sometimes turn up vice 450 following disruption. Incedentally I'm the guard on 2H62 tonight!
  6. NSE
    1,238
    3 Mar 2010
    Ahhhh interesting stuff, thanks mate
  7. 455driver
    455driver Veteran Member
    11,332
    10 May 2010
    I have had 8x450 on Waterloo to Guildford via Cobham a couple of times.
  8. Ivo
    Ivo Established Member
    7,307
    8 Jan 2010
    Bath (or Southend)
    :shock:
    That's a long train!
    [​IMG]
    If I was at very close proximity to Shpperton or similar, say if I was visiting my father [which ironically I did have the chance to do], I would have gone on it to give Mr Taylor a nasty surprise.
  9. 455driver
    11,332
    10 May 2010
    8 COACH 450! :roll:
    But then you knew that really! :lol:
  10. Schnellzug
    Schnellzug Established Member
    2,926
    22 Aug 2011
    Evercreech Junction
    Some would say that that's the best use they could make of them.
  11. Matt Taylor
    2,287
    31 Aug 2008
    Portsmouth
    I think there is a corresponding working in the morning at 0800 from Shepperton but that is just a one way working.
  12. 455driver
    11,332
    10 May 2010
    Yes its-
    2H94 0730 Shepperton to Waterloo via Richmond, (I think, its been a while ;)).
    Interestingly the 455 that works 2H96 0800 SHP-WAT (0904 platform15) then works-
    2R17 0915 Wat-Wat (1041 plat 16) (via Richmond and Hounslow) giving the unusual sight of a 455 around the Hounslow loop on a weekday.
  13. ChampsRacing
    ChampsRacing Member
    256
    10 Jun 2007
    As does the 08:02 arrival from Shepperton via Richmond forms the 08:15 Hounslow via Richmond from platform 16 in the mornings which ive worked quite a few times.
  14. Matt Taylor
    2,287
    31 Aug 2008
    Portsmouth
    I think you were doing that one last week when I was on the train just in front of you.;)
  15. ChampsRacing
    ChampsRacing Member
    256
    10 Jun 2007
    Thats right was empties behind you and had to wait for you to leave lol. ;)
  16. hmp455
    hmp455 Member
    51
    16 Jul 2011
    As near as possible to Waterloo East...
    There's a often a Desiro at about at Hampton 18:21, suppose this a is ex-Richmond service?
    P.S. it always seems to be a low-capacity one (i.e. not 450541-570) What are the First Class arrangements on these services?
  17. 455driver
    11,332
    10 May 2010
    Yes that is 2H93 1743 Waterloo- Shepperton via Richmond.
    Standard class only so the First class is declassified, it can be any unit depending what has been under maintenance at Strawberry Hill (its ECS to WAT to form 2H93).
  18. Matt Taylor
    2,287
    31 Aug 2008
    Portsmouth
    Incorrect, 5H93 is a pair of 455s and is worked by Strawberry Hill crew. Probably it is the return working of the 1713 Waterloo-Shepperton, the 1806 from Shepperton.
  19. 455driver
    11,332
    10 May 2010
    Its changed since I last worked it then, apologies.
  20. NSE
    1,238
    3 Mar 2010
    Its a shame they don't use the 450 Desiros on the stopper routes more often, they're quite nice units :)
  21. Matt Taylor
    2,287
    31 Aug 2008
    Portsmouth
    They are on the Hounslow and Weybridge routes all day long, the Sheppy line will have 455s at least until the end of the SWT franchise as far as I can see.
  22. swt_passenger
    swt_passenger Veteran Member
    21,497
    How about swapping some 450s for 455s to overcome the people of Portsmouth's hatred of 'blue trains' with 2+3 seating?
    Red trains with 2+2 seating - job done... <D
  23. Robbies
    Robbies Established Member
    1,997
    20 Sep 2009
    Berkshire
    I notice at times that Class 450's appear on the London Waterloo - Reading Service and the service from Ascot to Guildford is now sometimes worked by Class 458 rather than a class 450??
  24. swt_passenger
    21,497
    The Ascot - Guildford service has been diagrammed for a while for 5 units on weekdays, of which 3 x 450 and 2 x 458. The Sat and Sun services are all 450.
    However Waterloo - Reading is almost all normally 458, with a single return 450 in the early evening on weekdays some time IIRC.
  25. 455/8
    455/8 Member
    144
    15 Nov 2005
    You say that but the last couple of days there have been 3 458 sets and only 2 450 sets on the Ascot branch. I have heard about the depot (now this is just a rumour) that soon it will only be 458's operating on the Guildford - Ascot Branch.
  26. NSE
    1,238
    3 Mar 2010
    Ahh its white trains they want isn't it? Mind you I wouldn't mind swapping a 455 for 450, however my swt useage genrally only stretches to Raynes Park, so even if they arrive on some slower routes, I doubt I'll be in luck :P
  27. Lampshade
    Lampshade Established Member
    3,565
    3 Sep 2009
    South London
    If they want white trains then... 458s? :D
    I'd happily do Portsmouth Harbour - Waterloo on one, as long as I have a backwards facing window seat on the 3 side.
  28. swt_passenger
    21,497
    It is 2 x 458 and 3 x 450 that is in the CWNs, (and in next year's as well). But depending on unit availability on a day to day basis it is possibly one of the easiest routes to swap around, as it only uses single 4 car units. What I'm thinking is that if they need a spare 458 for Reading they'll pull it off Ascot/Guildford and sub a 450, basically because a single 450 is no use to the Reading route...
    However I've also heard the rumours about it becoming a 458 only service. This was with respect to the proposed 458/460 merger - and was supposedly because there will be half a dozen 4 car units left unchanged, and these will become the dedicated units for that route on a 5 + 1 spare basis.
  29. Matt Taylor
    2,287
    31 Aug 2008
    Portsmouth
    Sadly for the 455 fans they are barred south of Haslemere, and the 75mph speed limit of 455s would be a problem too!
  30. Robbies
    1,997
    20 Sep 2009
    Berkshire
    But if the 458/460 merger goes ahead what route will they be used on?
    Does that mean that we might see Class 450's be put back on the Waterloo - Reading route?
  31. swt_passenger
    21,497
    5 car units would be used in pairs to provide for the 10 car strengthened suburban routes that currently use 450/5s; Windsors, Hounslow loop, Weybridge etc.
    So as you've surmised 450s would have to transfer to the Readings - it isn't clear yet if they'd be reverted to the normal 450 layout, but it seems likely if there's any sort of First Class usage on that route.
Thread Status:
Share This Page
