Anonymous10
or plan b is hire a van while hiring the replacement busMaybe they've a van or two on standby!
As long as the brakes etc don't fail I'm guessing dragging it to the destination and trying to batter it or dump it would be the idea (or maybe they simply haven't got a plan and will improvise). Cue some struggling/late services whenever one shuts down and won't restart as a 3 car dmu with only 2 working engines wouldn't enjoy that route (good job the 156s were very reliable really). There's no way you can get shut of the vehicle en route though without riots breaking out with the cyclists being turfed off or told to dump their bikes. At least in the old days it was just another carriage dragged by a loco and had to be in the consist. OK so long as it didn't fail.
Not sure even 3 cars running off two engines would cope very well between Oban and Glasgow Queen Street.
Plan c: call out the Network Rail 'Hilux'* road/rail pickup and throw the bikes in the back. Fit some wooden benches and the owners can be accommodated alongside.or plan b is hire a van while hiring the replacement bus
Heading out of Glasgow, it would be lucky to get halfway along the tunnel before rolling back to the platform again.Not sure even 3 cars running off two engines would cope very well between Oban and Glasgow Queen Street.
Surely it would be more like 4 engines out of 5 cars running out of Queen Street?Heading out of Glasgow, it would be lucky to get halfway along the tunnel before rolling back to the platform again.
Even so, that tunnel is a challenge.Surely it would be more like 4 engines out of 5 cars running out of Queen Street?
I have faith in the Scotrail mechanics, they've dealt with the 156's for many years and the 153's are mechanically very similar so they will get on top of it.
Is baselining not a thing during refurbishments?The 153 is a very different beast to a 156 in a lot of ways. I'm sure things will improve as they get used to them but it basically used to be a facet of 153 operation that the training manuals were a guide - things would be in different places, set up differently, or have different reactions when you used them and the wiring was basically bespoke to each unit. Not so much "this will happen if you do x, y or z", more "this might/should happen if you do x, y or z but something completely different might happen instead".
The odd bits are done to Standardise during refurbs and modifications but by and large they seem to be left as they are.Is baselining not a thing during refurbishments?
As in making all units the same wiring spec etc.
Absolutely- of our 158s, there's 2 different types of data recorder, 2 different types of air con controller, different types of toilet, different engines, different PIS screens in the saloon (even though they were installed during the same program), different cab desk styles and probably more besides.Even the same fleet running on the same Toc but belonging to a different leasing company can have their own differences too.
Surely, 153s and 156s have operated together on numerous occasions in some TOCs ?I suspect the problems will start when coupled up to the 156s, pretty much as we see almost daily with 170/170 and 158/170 couple ups. Who knows what’s going to happen when your driving a DMU combo. They’re becoming a nightmare to be honest (in my experience)
AIUI there won't normally be any need to couple/uncouple.
Ever had a 156/153/158 combo. Now that is fun!I suspect the problems will start when coupled up to the 156s, pretty much as we see almost daily with 170/170 and 158/170 couple ups. Who knows what’s going to happen when your driving a DMU combo. They’re becoming a nightmare to be honest (in my experience)
This is why I don't have much time for those "we should have one coupling standard" threads!Ever had a 156/153/158 combo. Now that is fun!
Starting to get a bit OT here, but on the continent consists with 3 different manufacturers don't seem to be an issue (now they don't do that in regular service, but a mix of 2 manufacturers is common in service): https://www.flickr.com/photos/165942775@N07/50317354292/This is why I don't have much time for those "we should have one coupling standard" threads!
really is a questionable decision you take wales for example atm all trains except the 170 and 175 can couple together in a emergency the 170s work on a line where many others pass so conceivably if one got stranded either another tfw 170 or a cross-country could rescue it for the 175 again they work lines where others do alot too but still makes you wonder but lets get back to the scotrail 153'sIt does generally help if a set needs rescuing even if it's not a daily occurrence. Yes the trains are mostly more reliable than in BR days, but now trains failing en route will sometimes sit for hours blocking platforms or lines with greater knock on effects. It makes the railways look incompetent and useless when it does happen. Thank goodness these 153s were built in era of some degree of sense when second generation DMU's could all couple together in an emergency. The last 20 years has seen us re-enter the selfish era with individual fleets built without serious consideration of trains being left stranded. It isn't like it would have been a great cost to keep standard couplings, but it would be now to fix the issue.
170s can an do couple to the 15x fleet regularly, almost entirely for moves to and from Canton but its a booked daily occurance.really is a questionable decision you take wales for example atm all trains except the 170 and 175 can couple together in a emergency the 170s work on a line where many others pass so conceivably if one got stranded either another tfw 170 or a cross-country could rescue it for the 175 again they work lines where others do alot too but still makes you wonder but lets get back to the scotrail 153's
apologies i dont know why i thought the 170s couldn't but the 175s work where they can be rescued by eachother usually the 769 well we shall leave that for its own thread170s can an do couple to the 15x fleet regularly, almost entirely for moves to and from Canton but its a booked daily occurance.
The 175s are the ones that can only multi amongst themselves
To be fair, the fact they don't like coupling to other units very much is just one part of a very large list of problems with 153s. Even when working by themselves they're still problematic at the best of times.
Sadly I fear that's going to be the case. I hope I'm wrong as it's a innovative idea, but like the HST project I fear more of an appealing idea that a successful reality.This is starting to sound like another of those ideas that sounded good when someone mentioned it at a management meeting but in reality is anything but!
Sadly I fear that's right, and it may have been predictable.This is starting to sound like another of those ideas that sounded good when someone mentioned it at a management meeting but in reality is anything but!
