8X09 Ashfordby-Amersham LU S-stock still running?
Sun Chariot
16 Mar 2009
I've been a bit behind the times on this...
The 8X23 Old Dalby to Litchurch Lane and the 8X09 Ashfordby to Amersham LU 'S' stock moves - are these movements still taking place?
If so, please would a kind soul tell me of any known 8X09 pathing dates & times, over the coming few weeks. I feel the need to see four EE Choppers in action...
Thanks in advance.
causton
4 Aug 2010
Why is this always listed as running to Amersham - when of course it doesn't just sit on the LU boundary and runs to Neasden depot?
Does this happen for the Chiltern services too or do they not because at HotH they (IIRC) re-enter National Rail?
And lastly, are the Chiltern services (and 8X09 and similar runs) assigned a 3-digit train idenfitier?
Boothby97
24 Apr 2011
Grimsby
8X23 09:33 Litchurch Lane(Derby)-Old Dalby TT runs on a Tuesday only but may not always run. 8X09 11:42 Old Dalby TT-Amersham runs on a Wednesday Only but may not always run. It takes for ever to reach North London as it passes Tamworth at 18:20 and passes Hatton at 20:25 and arrives at Banbury at 21:15 and leaves at 22:30. Talk about a long journey.
As far as we are concerned, it ends its trip when it leaves NR territory, what it does after that isnt our concern. We plan Chilterns all the way through as they end up at/from Marylebone.
It's long as it only runs at 40mph and is a swine to path, other trains catch it with ease. It also has to go through the back platform at Dorridge due to clearance issues which doesnt help.
Boothby97
24 Apr 2011
Grimsby
Thanks for the info. I presume 20301/302/304/305 are used as they are in the GBEE pool. When do the locos return light engine to Derby, can't find it anywhere on Freightliner Online or in the books.
DavyCrocket
27 Oct 2006
Chiltern retain their usual reporting numbers. I'm 99% certain that the trains that bring the S Stock have a three digit set number - but I don't have an EWSA to hand.
Old Timer
24 Aug 2009
They return LD off the LUL system asap and before normal running hours as LUL dont like to mix "other" trains with their own.
Boothby97
24 Apr 2011
Grimsby
Do the four 20s stable at Derby from I presume Thursday Morning to Tuesday Morning or do they go elsewhere.
Planner, if it's a) permissible and b) not trouble for you, please could you PM me with principle pathing times. I'll try and catch the movement north of Banbury. May thanks.
If I remember on Tuesday when Im back in the office, i'll stick them on here unless someone else can get a TRUST report off it sooner.
Freightmaster
7 Jul 2009
...please could you PM me with principle pathing times. I'll try and catch the movement north of Banbury.
Code:
 TYSELEY             pass 19:23
 BENTLEY HEATH L.C.  pass 19:35
 DORRIDGE           19:39-20:15
 HATTON              pass 20:27
 LEAMINGTON SPA      pass 20:43
 FENNY COMPTON       pass 21:01
 BANBURY            21:14-22:31
hope this helps,
MARK
