Adding Announcements
Jordy
9 Jun 2005
WCML South
Hi
Would it be possible, for someone like me (with no BVE coding knowledge) to add announcements to a route, to be played when the train has stopped at a station (IE This station is ________) ? And if so, how can I do it.
Thanks!
Jordy
Nitro
20 Nov 2005
Well the 95TS uses horn 2 to say "The doors are now closing" or something like that as I forgot what it actually sais but I think the train has to have the "This station is ..." thing and not thre route. Hope this helps.
devon_metro
11 Oct 2005
Don't quote me on this but i beleive it is something to do with the beacons, take a look at the Nrothern Line route files and see what you can gather!
Edit: after looking at the codes in certain route it appears this is the code needed: .announce route example\v3\example.wav
Dennis
8 Aug 2005
Trowbridge
Playing a sound on arrival is possible from the .sta command;
(in BVE 4)
.Sta Name;Time 1;Time 2;BLANK;Door;Stop;BLANK;Sound 1;Halt;Jam;Sound 2;timetable Index
Time 1: Arrival time(HH.MMSS or P = pass)
Time 2: Departure time(HH.MMSS or T= terminates)
Pass Alarm: NOT used in BVE 4 *** LEAVE BLANK ***.
Door: Door opening -1: Left 1: Right or 0 if doors don not open
Signal at station: 1: shows Red 0: Shows Green
Safety System: NOT used in BVE 4 *** LEAVE BLANK ***.
Sound1: Arrival Sound (filename.wav)
Halt: minimum stop time in seconds
Jam: how full the train is (0-250)
Sound2: Departure sound (filename.wav)
Timetable index of timetable Index:Train.Timetable
or if an announcement is required before entering a station use the announce command.
Tom B
27 Jul 2005
"This train is about to depart. Please mind the doors"
Derek Kaye
9 Jun 2005
Loughborough
You can also play an announcement while moving
use .announce path,
where path is from bve\railway\sound
e.g.
2000,.announce barrow-carlisle\sprinter_pass.wav,
Jordy
9 Jun 2005
WCML South
(in BVE 4)
<snip>
Thanks! Now I have 'installed' sounds to Maybank lol :lol: :lol:
Jordy
Nitro
20 Nov 2005
:oops: :oops: And I call myself a LU fan :lol:
T
Tom
Guest
It's a bit like how you know if a train is refurbished by a number of facts, and that the 72TS is really a 67TS hybrid.
class 313
10 Dec 2005
St Albans
This would be good for the MML route as i have a anoucment at st albans saying "The train on platform one is the 11:47 to haywards heath calling at....."
Tom B
27 Jul 2005
I do have the unfair advantage of having recorded the aforementioned sound ;).
The Snap
10 Jun 2005
Hi Jordy,
If you look on Damon's guide, find the station section,
.Sta x1;x2;x3;x4;x5;x6;x7;x8;x9;x10;x11, Places a station.
x1 = Station Name
x2 = Arrival time in HH.MMSS
x3 = Departure time in HH.MMSS
x4 = Pass alarm. 1 will alert the driver when he or she has passed a station he or she was supposed to stop at and 0 will disable the alert. Can be left blank.
x5 = Sets which side of the track the platform sits on. (-1 for left, 1 for right)
x6 = Sets a signal at the station. 0 will show green, 1 will show red until the train is near the stop marker or there is 23 seconds to departure.
x7 = Can be used to activate a safety system, or left blank. 0 will activate ATS, 1 will activate ATC.
x8 = Plays a sound when arriving at the station (after the doors open). Format: Directory\x.wav. Default directory is BVE\Railway\Sound.x9 = Minimum stop time in seconds. This will only come into play if the stop is longer than that specified by the arrival and departures or if the train is running late.
x10 = Determines how full the train will be upon departure from this station. Use 0 for empty and 250 for full. 0-100 is best because a more full train (150+) means the passengers are unhappy to begin with and thusly make a very hard job for the driver.
x11 = Sound to play before doors close to depart. Format same as above.
Right, if you find x8, it tells you how to do it. So, the station command would be .sta Example Station;;17.20;;1;0;;Example_Route\Example_Station_1.wav;15;5;,
Does this make sense? :D ;)
