....No, you were going on about different TOCs to suit your argument. As I said before it completely falls down when using the TPE example posted earlier. Perhaps you can provide an example on why a Manchester-York plus York-Newcastle AP tickets both on TPE would not be honoured on TPE if their first train was leg? Go on, argue that point. I look forward to a completely different set of arguments being used not mentioning the TOC as it's the same....
Conditions of use for the ticket from Manchester to York....
You have arrived at you departing station in good time....CHECK
You have not missed your first booked train....CHECK
You have missed a connection because of a delay since leaving Manchester....NOT APPLICABLE - DIRECT SERVICE
Conditions of use for the ticket from York to Newcastle....
You have arrived at your departing station in good time....NO, YOU WERE LATE
You have not missed your first booked train....NO, YOU WERE LATE
You have missed a connection because of a delay since leaving York....NOT APPLICABLE - YOU MISSED THE TRAIN FROM YORK
Does TPE have an obligation to get you to Newcastle on your Advance ticket? No, they have not broken any of the conditions of the ticket.
....So? Are you saying a building company that has 2 separate contracts (known as 'work packages') to carry out some work in a project, if they do not carry out the first work package on time, and then say that the 2nd work package cannot be carried out but still has to be paid for, as it was to start on a specific date, and the fact that they did not complete the first work package on time means that they can simply take your money and not do the 2nd work package, and they could get away with that?....
I think we both know that is not the same thing, the train was still provided, it's just that you missed it.
....Yes it is the passengers responsibility to get to the first station on their journey, however if delays occur while travelling then the customer may complete their journey on later trains....
The condition for ticket B is that you get to Station B in good time, you failed to do that therefore you did not uphold the conditions of the contract.
....It is absolutely ludicrous to say that the wording about it being the customers responsibility to ensure they are on the right trains over-rules the wording that says that if you are delayed you can be allowed to travel....
It doesn't, it is a seperate ticket/contract from the previous ticket, therefore you are not actually travelling under the conditions of Ticket B untill you leave Station B.
....It is clear that the easement is saying that you can do it and that you are not at fault for missing trains. If you do not believe this is clear then this applies:....
See above.
....I have read what you have written and I look forward to reading an example of combining AP tickets with the same TOC.
The basis of your argument was two separate TOCs being able to blame each other. However that is ridiculous as you can have one ticket using several TOCs, but if you are going to argue you cannot combine AP tickets then why don't you use an example of combining AP tickets offered by the same TOC, and ignore the TOC blaming TOC argument?....
No, it is about two seperate tickets and how the actions of TOC1 during ticket A-B are seperate from ticket B-C or TOC2 (irrespective of who TOC 1 and TOC2 are, or even if they are the same TOC)
....In the absence of a full definition, we are left with the text "...you can combine two or more tickets for one journey..." there is nothing else to go on. There is nothing to say you cannot combine 2 or more tickets for one journey. You keep saying you cannot, but there is not a shred of evidence that supports that position! It is, frankly, made up. You can say that my quote does not apply but you cannot provide any alternative quote to say that you cannot combine two or more tickets for one journey!....
I had said quite clearly that using two tickets to travel a longer distance is fine, but that you can't mix conditions to suit yourself, each ticket has it's own conditions and they are applied seperately.
....The AP conditions say you can complete your journey in the event of delays. Even people like royaloak now admit that, and he said that what matters now is what counts as "a journey". The key question is "Can two or more tickets be combined to form one journey?" And the answer is "yes". Do you deny that is the key question?....
See above.
....Let's not use the word 'fault' then. You are effectively saying it is the customers responsibility to be at the departure station for each train/ticket during their journey, and that if a train company delays them, the customer is liable?
The customer bought the tickets, by doing so agreed to
ALL the conditions of use, no matter what they are.
....Providing the customer is at the original departure station then they are covered on the line of text that you have not quoted that says that in the event of delays you can complete your journey on later train(s)....
Here we go again! Were they at the departing station as shown on their ticket in good time for the first booked service, no. They can't be delayed whilst travelling if they have not started to travel (on that ticket).
....The condition clearly states you can continue your "journey"! As I said before they DO NOT state that you can only continue to the place printed on your ticket, they say you can complete the JOURNEY. For you to say that it does not apply to the "journey" is plain wrong....
That condition is irrelevant. The first ticket has ended and is no longer important, the second hasn't even started yet and you have failed to adhere to a condition of it's use already.
If you got to Station A by taxi and it was late, is that your fault? No. Would you be allowed to travel on the next train? No.
....Go on then, find an alternative definition of "journey" in the conditions that supports your view....
I don't need to, it is you that relies on it's definition and one no-one can produce one.
....This is just waffle. The key facts are
1) AP ticket conditions state you must be on the booked train however if you are delayed while travelling then you can complete your journey on later trains
2) The question then is what does journey mean, specifically can a journey be carried out on two or more tickets?
3) NCoC says you can combine two or more tickets for one journey
4) Nowhere does it say you cannot combine two or more AP tickets for one journey....
1) I agree, you were on the booked train for ticket A, you missed the booked train on ticket B, but you're not travelling under the conditions of ticket B-C until you have left station B. The conditions of ticket A-B no longer apply as that 'journey' has finished.
2) Yes, but the conditions of use apply to each ticket seperately.
3) It does indeed say you can complete a longer journey on two or more tickets, but it does not say the conditions for one apply to both.
4) Indeed but nowhere does it say that the conditions of one become integral to the conditions of the other, or that events during one affect the conditions of the other.
....Neither! The Anytime is unrestricted and the Advance is restricted....
So you agree that the conditions of one ticket are seperate to that of the other?
....The Advance ticket is only for the booked train(s), not "any" train, however if you are "delayed while travelling" you can "complete your journey on later train(s)". So the Advance ticket is not "open" and only becomes valid for later train(s) in the event of connections being missed....
So when did you start travelling on ticket B-C, it can't be before station B because the ticket wasn't valid.
....So you admit that two or more tickets can be used for one journey?...
I have never denied it, but I accept that the conditions for each must be adhered to.
....It does not need to read "as though they are one ticket". The number of tickets is not really relevant. The fact is if you are delayed on your journey you can complete the journey. A journey can use a combination of tickets....
But you must adhere to the conditions of both tickets, you have failed to adhere to a condition of ticket B-C.
....Here we go again, using separate TOCs to use the blame game argument.
What happens if someone combines two TPE Advances? One from Liverpool-Manchester (on a train toward York) and one from Manchester-Hull? This is a real example as Max did this from the Merseyrail Challenge meet and was delayed. Your argument is that if Max failed to get to Manchester in time for Manchester-Hull because of TPE, that is not TPE's problem, because TPE provided the train for him to use as contracted, and he missed it....
I've answered that already I think.
....Do you still believe that your statement makes sense? Or do you admit that you are playing the TOC vs TOC blame game that makes no sense when you combine AP tickets of the same TOC?....
I'm not blaming anyone, just saying how it is. What I believe makes sense is largely irrelevant.
....Now, in a previous post, which was ignored by you, I did say that Passenger Focus have very few incidents reported to them of AP tickets not being accepted in this way. So it is totally untrue to say that you will "PROBABLY" have to buy a new ticket! In fact the evidence is that you will probably be allowed to travel, however you may be asked to pay again, an act which I believe is contrary to the T&Cs and that Passenger Focus will fight on your behalf, and with a good success rate and it is also contrary to what ATOC would expect, and it is contrary to what guards such as Ferret would do (even though he believes that he could charge for a new ticket) and his Customer Services department are also happy for it to be accepted too. I have had many reports of people being allowed onward travel in the event of delays and, so far, none of anyone being denied onward travel although as I said earlier a few cases do happen (incorrectly) as Passenger Focus do get a few complaints and will chase them up....
How many cases have not been reported to Passenger focus? How many of those were dealt with in a way in which you find unacceptable?
I honestly don't think we will agree on this matter, I can't respond now until atleast Monday, by which time I'm sure an even longer post awaits me and I doubt it will contain anything new to add to the debate. I think the fact that others, not just me, have indicated the same feeling on the matter adds weight to our point of view. You will not accept that, that is your choice, but I will once again say that whilst you believe you are right, it is not right to claim your opinion as truth when there is still doubt.
As a note on BestValueFares, or whatever it is called, that mearly states what Condition 19 already states, it changes nothing.
