Arriva Trains Wales- Trainee drivers
NX
6 Jan 2014
Hold out for Carmthern mate! Cardiff will be at least five years of Valleys work all day every day!
NX
craigybagel
25 Oct 2012
Although you could ask is a job on the valleys better than a place in the talent pool? Jobs at Carmarthen don't come up very often (usually they're filled by transfers), and between the two sides of Cardiff depot there's 3-4 times as many drivers as Carmarthen.
Work at Carmarthen is definitely more appealing though!
headshot119
31 Dec 2010
Dubai
How often do jobs at Cardiff (mainline) come up, and how long do you have to do before they'll consider you for a transfer? (To any depot doesn't have to be Cardiff Mainline if there's any difference)
craigybagel
25 Oct 2012
It's meant to be 2 years before you can apply for a transfer between depots but some in the north have been known to move a lot sooner than that if there's a vacancy going and no one else wants it. I know down south guards have been able to make the jump from valleys to mainline within a couple of years but I I've heard anything from 5 to 10 years as a driver.
On the guards side the Valleys depot is bigger than the mainline, so I would assume the same is true for Drivers, so that does explain part of the wait. It's also worth mentioning that within the mainline depot there are numerous links for drivers; even if you did make the transfer, don't expect to be going to Milford Haven or Chester on Class 67s any time soon. You'd be spending a lot of time doing the VOG, Maesteg and Ebbw Vale lines which aren't much different from the Valleys really!
I suspect Cardiff is fairly unique on the railway in being a half way point between 1 depot and 2. They share management and booking on points, but are treated as two different depots for rostering purposes; other than shunts around Canton and Cardiff Central, they don't share any work. They also have slightly different T&Cs, for example Mainline is a 5 day week, Valleys are 4.
The only similar situation I can think of in Britain is XC for Senior Conductors vs TMs at Birmingham and Bristol, but even then the drivers at least do mixed work, and XC recruit directly for both sides whereas anyone starting in Cardiff for ATW is put straight on the valleys.
TDK
19 Apr 2008
Crewe
There is a rule in place so that any new driver cannot transfer whilst PQ and that is usually 3 years normally. It is possible to have an immediate transfer before your training is completed as this will not affect the driver or the business if there are vacancies available, in the past it was common but I am sure now this new rule is adhered to.
Bluebird83
22 Jul 2015
How likely/unlikely is it that I'll get a call do you guys think? Some threads suggest probably not. Others suggest I'm in but just a matter of time. They're offering redundancies at work and not sure wether to take it and wait or just forget about it and move on! Nightmare!
craigybagel
25 Oct 2012
I'd say its really hard for anyone outside of the HR department to say to be honest. It's very hard to predict when and where vacancies will come up. It might not do you any harm to ask the HR team yourself though? They're a nice group of people at ATW and if anyone's able to give you a straight answer it'll be them.
HSTfan!!!
11 Jun 2005
I know a former colleague at ATW who passed as a driver and moved to mainline from the valleys within a year. I also know a conductor who did the same.
