Cardiff123
- Joined
- 10 Mar 2013
- Messages
- 1,429
Thanks for the info, but don't risk your job over it.Well if you’re going off the info I post you can be assured it’s reliwble no as up to date as possible as I’m involved in the planning of it!
HSTs would be fuelled at a Canton every day so would only need a short supply at night at Holyhead. HSTs are not a preferred option due to the amount of training required as additional train crew depots would need to be involved. The bigger probablility would be receiving 170s from Anglia earlier (summer) to cascade 150s off South Wales Mainline work to speed up PRM and WSP fitment. There will also be 8 x 142s moving from northern to TfW however this is dependant on Class 195 introduction which is being delayed further.
The 5 class 153s received from GWR will likely be kept in S Wales (Cardiff Bay and Cheltenham - Maesteg) as they have different lower power engines than the existing fleet which were fitted with updated engines back about 8 years ago (they’re about 80hp better)
Let's hope that if those 8 x 142s do make it to the Valleys from Northern that they are not ex-Merseytravel 142s, which are an abomination.
