Still dominant in former Russia countrys i believe
And available for tours around the former East Berlin!
Can you actually get a car that is as slow as a top speed of 62.5mph?
I had a courtesy car daewoo matiz a few years ago which was only an 800cc engine, and that could do 80+mph, and i'm sure was one of the slowest cars available in britain,
Probably the most likely would be an early Land Rover (series' 1 2 and 3), there a quite a few others, but they are classics/vintage now, and rarely seen at all, and if they are, are unlikely to be driven by a learner tbh.
I think compulsory tests every 3 years for the over 60's is in order.
I'd go further than that and say all drivers should be required to re-take their test every few years. (In fact why not make the driving test as stringent as a train driver's assessment).
Remember bus drivers too would be in the same catagory, which would cause bus fares to shoot up due to increased training costs and higher wages.
They already are, sort of - the driver CPC requires 35 hours of training every 5 years. While this may not sound like a lot (7 hours per year), it soon adds up.
GearJammer will know more about it I'm sure.
Here's a perfect example of severely bad manners ...
I was cycling into Sheerness this morning along the A250 (the only road from Halfway to Sheerness) - coming up to the junction with St George's Avenue, I'm cycling along nicely, about 10 minutes to get my train, no rush, I see a car approach the junction turning right from St George's Avenue, he slows down a touch, sees me, then as I vastly approach the junction, decides to pull out in front of me! I nearly brake hard, he got so close to me I felt like hitting his car as I could reach it! I slow down a little bit, look behind and shout at him - he just carried on, I was a little shaken but otherwise ok.
I dread to think what might've happened if I was late and was going faster and the same thing happened ...
There's nothing to stop you passing your test and not driving for 20 years during which time rules may have changed.
Only the photocard needs renewing, not all of the licence unless a short licence has been issued. This does not stop you passing the test and not driving for 20 years.There is... every 10 years you need to renew the licence, if you dont drive or intend to, is it worth renewing, No testing required just a new photo,and about £20 fee
Is that bad manners. Or just rubbish driving
What does that have to do with the fact that you can pass the test and the not drive for 20 years?You have to send the photocard and paper bit back, If you dont drive though, would you deem it worth spending money doing that?
What does that have to do with not driving for 20 years?
No you would not, the licence is valid until you are 70 unless for some reason you have been issued with a short licence, this is not what you are renewing. You are renewing your photocard and it is actually an offence not to renew your photocard so you would be breaking the law by not doing so.so would have to be retested after 20 years of not driving
No you would not, the licence is valid until you are 70 unless for some reason you have been issued with a short licence. It is actually an offence not to renew your photocard so you would be breaking the law by not doing so.
Both ... he saw me, he braked a little, then decided to nearly cause an accident ... surely the Highway Code says to give way to the right at junctions?
Your licence though is still valid until you are 70, this would still be on record so when you applied for a photocard it would still be a full licence.You do not have to renew it after 10 years, however you can no longer drive if you dont renew it.
It is an offence if you don't update the photocard. If after 10 years you are not going to drive and you do not want to renew the photocard then you should surrender the licence or you could be charged with "Failing to surrender licence."No your only breaking the law if you drive with an out of date photocard, therefore if your photocard is out of date, you have an invalid licence. You do not have to renew it after 10 years, however you can no longer drive if you dont renew it.
Failing to keep your licence up to date is an offence, this also includes change of name/address.
No, not renewing the photocard does NOT remove the entitlements, not doing so is an offence. If you don't renew your photocard you can be charged with "failing to surrender licence" if you really don't want to drive then you should surrender the licence.However if your photo is over a year out of date, they will revoke your licence and you have to retake tests. if you dont drive for 20 years, this will apply for you unless you renew your licence on time.
You give way to whichever way has priority.
I hear new truck drivers saying they can't get any work though as the companies will only employ drivers with experience.Roll on 2014 i say, because if the driver shortage is as bad as predicted you may all realise how much your lives depend on trucks being on the road, .........unless some of you are still living on cloud cookoo land thinking the train can take the strain!
