Joseph_Locke
You'd be right it was a trial, but it wasnt they!!
I thought you lot had gone?
Out of interest, which ones are they? MG30 something?
It's not just about them impinging on the OLE, they can be blown over or branches can fall/be blown into the OLE or pantographs, and more immediately, wheelslip in leaf-fall season at a station as a direct result of trees planed at that station during rebuilding is something only the railway in this country could manage.
It's tiny little things like this that add up to big bills and trip up the railway big style.
Start of the MG30s, You lot? I take it you're referring to the previous mob? It wasnt them or they that did the trial but another outfit![]()
I meant, which OLE structure numbers!
And if it wasn't ***f*** ***t* and it wasn't ********n, that means it can only be *o**** R***?
Do you mean Warren?![]()
But it's good fun when even the Chief Engineer doesn't know which contractors are loose on his property.![]()
Has anybody been for a nostalgic last ride through the mousehole (aka the Down Farnworth Tunnel) before it closes for ever?
Given its shortcomings I think it deserves a decent farewell for performing above expectations for the last 7.5 months.
Hopefully it won't be needed for trains again. Operational 1880-2015.![]()
Has anybody been for a nostalgic last ride through the mousehole (aka the Down Farnworth Tunnel) before it closes for ever tonight?
Not been through for over a week but the tickets for Monday are waiting to be collected at Bolton. According to "Realtime Trains" first train through is (Hope (Earles Sidings) Dbs to New Cumnock U.R.S. Bolton time 0532). I will be on first passenger train (Blackpool North to Manchester Airport 0539 from Bolton to Salford Crec. Returning to Farnworth at 0645. The first stopper at the rebuilt Farnworth and Halshaw Moor! Video and Photo's to follow.Has anybody been for a nostalgic last ride through the mousehole (aka the Down Farnworth Tunnel) before it closes for ever tonight?
The latest picture on the NP Twitter feed shows the down line connected, at least at the Farnworth end, and Joseph's signal in place:
Picture of a 66 in the tunnel.
This is the second weekend running that somebody who posts to the NP Twitter feed has been operating at the weekend.
https://twitter.com/networkrailnp
From this distance, there doesn't appear to much clearance between cantrail level and the tunnel side and the end of a pan on an electric. Has it been finally tamped inside the tunnel or has cant yet to be done?
Wow that is exactly what I was thinking. It does not even bear thinking about the amount of egg on face if it were true. It would make the GWML electrification look like a vicars tea party in comparison.
Trick of the camera and the Class 66s odd roof shape.
Class 66s are a little unusual in their roof shape and height, which is sort of why we've got the isolation requirements for the Paisley Canal electrification.
There, a Class 66 is 40mm away from the contact wire, but the EMU fleet is 167mm, essentially a Class 380's pantograph can be just 40mm higher than a Class 66's roof.
Anyway, the new tunnel is W12 cleared without electrical isolation needed, so it's nothing to worry about. The designers do, in fact, know how much space a train + pantograph needs, including electrical and mechanical clearances.
Yes, I wasn't questioning the professionalism of designers but didn't know if tamping was complete. 40mm is no distance at all for tolerance. Less than the length of a pencil. I watched Borders rail being tamped and the track was being lifted or slewed by much more than 40mm in one grab.
I can't believe electrical clearance can be as little as 40mm without flashover. I remember seeing a flashover to the chimney of a steam loco in Crewe about 1960 at a far greater distance of maybe a metre.
Is the OLE isolated or earthed when the oil trains run?
