- Joined
- 15 Apr 2008
- Messages
- 15,971
Reassuring thank you very much. W12 is excellent
Rare for anything new to be built to less than W12 now.
Brilliant set of "Last Day" working photo's on Farnworth Tunnel/Station from Joe. Must get to bed for my early trip though... excited, great Crimbo present!
I'm a wee tiny little bit disappointed at the wooden shuttering going up over the proper fencing, and the state of that piling around the new signal. This to be sorted over Christmas, along with removing the track from the old tunnel ?
The designers do, in fact, know how much space a train + pantograph needs, including electrical and mechanical clearances.
That's the first train through then. Welcome to your new #farnworthtunnel!
The Class 185 photograph gives a great demonstration of the amount of space available between the roof of a unit and the tunnel lining for the impending OLE installation (and the tunnel's W12 gauge clearance).
Oh ye of little faith, indeed. .
In one of the videos, in which a Manchester-bound train goes through the station and into the tunnel, Joseph's signal remains green for an awful long time after it's passed.
Obviously there is a tsr on at the moment and I heard 100mph is unlikely even after introduction of 319s. Does anybody know what is the likely linespeed please?
That was the first thing I noticed when I saw the photo ----
.... then 100mph one way and 95mph the other through Farnworth Tunnel.
All the platform PIS displays say "10M more seats annually on Northern services from 14 December. "
Anyone know if that is true?
Why the 5-mph differential between the two directions?
Signalling I guess on the down line to Moses Gate
Im guessing the 95 is towards Bolton? Even if you weren't stopping at Bolton I guess that very gentle curve at the end of platform 4 might be an issue
What will the method of electrification be through the tunnel?
Overhead wiring or Overhead conductor bar fixed to the roof?
The speed limit through Bolton is 15mph isn't it?
40 through the platform, 20 for Bolton West Jn on the down, 20 rising to 30/40 on the Up.
Ironically from Farnworth - Moses Gate it is 4-aspect signalling, and only 3-aspect on the Up.
But I also guess the curve might be a tad harsher as the down line rejoins its former alignment?
I noticed a new banner repeater on the Up yesterday (for MP620, between Moses Gate and Farnworth). Maybe this helps the speed limit.
I didn't notice is there was one on the Down.
I'd bet on wiring rather than conductor bar, in the same way that I disagreed with those who said concrete slab track would be used.
I imagine each support point will have a central "downpipe" from the crown of the roof with registration arms sticking out to each side.
I would assume that the transitions between normal OHLE and conductor bar also introduce extra potential failure points?
There would be little point in fitting conductor bar unless absolutely necessary, there are existing methods of running the contact wire and catenary much closer together within tunnels (gradually reducing the height of the droppers on approach). The same technique is used under some low bridges.
Is any work planned between Salford and Euxton over the Christmas - New Year break? Bolton perhaps?
