maddeningcrowds
- Joined
- 25 Feb 2009
- Messages
- 143
Is a Leeds-->Garsdale day return valid for break of journey on outward and return portions?
It doesn't say that now.On the national rail website under ticket conditions for 'anytime day return' it said most were valid for break of journey, but that i had to check with them for each journey.
National Rail Enquiries
Anytime Day ticket terms and conditions
Break of journey
You may start, break and resume, or end your journey at any intermediate station along the route of travel.
http://www.nationalrail.co.uk/times_fares/anytime_day_conditions.html
[...] in the case of Off Peak Returns it's mainly to prevent people getting on to intercity trains in the morning peak using break in journey loopholes to get around peak restrictions.
It doesn't work particularly effectively.How does that work then?
is not allowed to use a £70.20 Off-Peak Return because the restriction is0758 Preston - London Euston 1012
1630 London Euston - Preston 1830
The cheapest Preston - London Euston walk-on fare available on these trains is the £271 Anytime Return.SVR Preston Lancs - London
ARRIVE: LONDON EUSTON Before 0720 or at or after 1129.
DEPART: LONDON EUSTON Between 0926 & 1500 (inc.) and at or after 1845.
Break of Jrny: (OUT) YES (RTN) YES
SVR Lancaster - London
ARRIVE: LONDON EUSTON At or after 1005.
DEPART: LONDON EUSTON At or after 0905.
No break of journey allowed on outward travel, except to change trains.
Agreed. Hence my first sentence.Of course it could be argued that if you join at Preston on a Lancaster to London then you are not 'breaking' your journey as you can't break what you haven't yet started.........!
And anyhow the return portion would be valid for the journey from Euston to Preston (get off) because the ticket is valid both on the 1630 from Euston and for break of journey.
As an example, a passenger wishing to make this journey on a weekdayis not allowed to use a £70.20 Off-Peak Return because the restriction isThe cheapest Preston - London Euston walk-on fare available on these trains is the £271 Anytime Return.
The break of journey restriction on a £73.20 Lancaster - London Euston Off-Peak Return is intended to deter a passenger making a Preston - London Euston return journey on the above trains from paying £73.20 instead of £271. The restriction is
Surely you could just argue you caught the 0722 from Lancaster to Preston, and thus you are only changing trains not breaking the journey?
