Bridge Strikes
jopsuk
13 May 2008
buried in a consultation for changes to the Traffic Signs Regulations and General Directions is the nugget that in the 2014/15 reporting year there were over 1600 instances of road vehicles hitting rail over-bridges.
That's an average of more than four a day- this seems quite a lot! Especially given that most taller vehicles are driven by supposed professionals.
It strikes me that if a serious safety failing was occurring multiple times a day on the railway itself there would be huge industry efforts made to stamp it out. Yet, as with most road safety issues (something like three pedestrians hit by London buses every day, for example) there seems to be a bit of a "well, what do you expect?" attitude.
Carntyne
8 Jul 2015
The amount of professional drivers who don't report them either is shocking. Total disregard for safety.
21 May 2014
As someone who used to work in a building overlooking a commonly struck bridge, we got very used to the screech of lorry brakes and then the inevitable crunch of metal-on-metal, as the trailer jammed itself tight under the bridge. I'd say it happened once a month on average. So the figure of 4 a day nationwide seems low to me!
(Edit) And surely enough, the bridge I was talking about is on that list of Bridges that were struck more than 10 times last year:
BWJ3/90 - Upper St John Street, Lichfield, Staffordshire
(From Streetview)
Are those signs and marker boards really not enough?
jimm
6 Apr 2012
The number of incidents is coming down slowly but surely. In 2002-3 there were 2,061 incidents recorded, so a 20 per cent cut in a dozen years, which suggests things are moving in the right direction, though as Carntyne says, there is also a problem with drivers just leaving the scene.
You could spend a lot of money on more signs, beams over the road ahead of a bridge, etc, just in case, assuming you had it, but there is plenty of evidence that it doesn't make that much difference even if you do.
Trying to legislate against people who do not know the height of their vehicle, or can't be bothered to get a specialist truckers' sat nav or road atlas, showing low bridges, is not straightforward, never mind the sheer number of bridges there are out there, some of which have never suffered a scratch, while others, with all manner of warnings after previous incidents, continue to suffer.
Whitehouse Bridge in Swindon is probably the most bashed in the country over the years, even though it has a fairly obvious paint job that you might think would serve as a bit of a clue, but people have still tried to take lorries and a double-decker bus (mercifully it was empty at the time) underneath.
http://www.swindonweb.com/index.asp?m=2&s=131
61653 HTAFC
18 Dec 2012
I know of two bridges round West Yorkshire that have infra-red detection systems which cause a large digital display to light up whenever an overheight vehicle approaches the last opportunity for diversion (Gledholt Bank in Huddersfield and Denby Dale Road in Wakefield, the latter being high enough for most double deckers anyway!) but I guess these systems are fairly expensive and only suitable for certain sections of road: probably NOT that one in Swindon due to closeness of junctions.
There's really no excuse for bridge strikes though. It might seem drastic but if the penalty for HGV/PCV licence holders was simply 'If you hit a low bridge, you lose your HGV/PCV entitlement FOR LIFE' I imagine the number of incidents would decrease significantly overnight. Unfortunately the road freight industry lobby would probably try to prevent such a rule being imposed.
JohnB57
26 Jun 2008
Holmfirth, West Yorkshire
They would, because it's a silly suggestion. Are you seriously suggesting that the drivers involved don't care about or try to avoid the damage they do to their own vehicle and the risk to their job from that? These are accidents, pure and simple and the answer is building diversions to such obstacles, or at least better warnings, not depriving normal members of society of living. But this is a railway forum of course, so no common sense on here.
Llanigraham
23 Mar 2013
Powys
Rubbish!!
All bridges have a sign on their approach and any driver who can't read the signs needs taking off the road immediately.
Some might be accidents, but I can assure that a common response when asked is "Oh I thought I might make it!". I know that locally drivers have been prosecuted with Due Care and Attention charges and have lost their licences.
The more NR start not only claiming for the costs of the repairs but also for the Delay Payments caused the better. A claim for several hundred thousand pounds might make them sit up and pay attention.
hwl
5 Feb 2012
(From Streetview)
Obviously not as BTH1/1205 A205 Thurlow Park Road, Tulse Hill in joint 1st is all fluorescent yellow and black stripes and has a yellow banner with black writing "Low Bridge" in 18" high letters as well as diversion and road signs for up to 1km in some directions warning of a low bridge...
https://www.google.co.uk/maps/@51.4...4!1sJedSHb3pNDUJVGRSQY11uA!2e0!7i13312!8i6656
The bridge strike stats for this site going up might have something to do with CCTV to record the culprits being fitted recently...
The CCTV is more to enable the bridge to be examined remotely such that it can be opened at caution very quickly. Normally within 10 minutes of a reported strike.
21 May 2014
I think the obvious question, to any right-minded person, is JUST HOW DUMB do you have to be to drive your truck into that?
jopsuk
13 May 2008
On the roads, far too much is chalked up to "just an accident". In industrial settings, the idea of "just an accident" is generally discouraged. It's really quite astonishing how the attitude to H&S changes at a site boundary.
Llanigraham
23 Mar 2013
Powys
Quite, which is why the Police no longer call them Road Traffic Accidents, but INCIDENTS.
Antman
3 May 2013
Rubbish!!
All the time vehicles are being driven by human beings mistakes are going to be made.
Several hundred thousand pounds? If they had that sort of money laying around they wouldn't be driving trucks or buses in the first place
Llanigraham
23 Mar 2013
Powys
But JohnB57 implied that they aren't mistakes and the bridges should have bigger and better signs.
Yes, several hundred thousands pounds. NR have to pay Delay Attribution to the TOCs if it is deemed their problem the trains are delayed, and a bridge strike is deemed NR's problem. Therefore why shouldn't they claim back those charges from the "person" who hit the bridge? I'm sure the lorry owners have insurance against these matters, so they will pay it and then their premiums will go up, just like if you and I if we have an accident that involves an insurance payment.
Or perhaps you are of the opinion that they should walk away scot-free after hitting a bridge and it is all the railways fault?
TDK
19 Apr 2008
Crewe
A mandatory £25.000 fine may solve charged to the company that owns the vehicle.
mac
15 Dec 2010
A lot seem to think drivers should be banned or heavily fined would you also fine and ban train drivers for going though a red signal or a signal man for wrong routeing
jopsuk
13 May 2008
If drivers pass a signal at danger it is considered a serious matter and will be investigated to determine fault, potentially leading to disciplinary action.
Stand next to any junction in London for an hour or so and you'll see HGVs* go through red lights with no action taken.
*and other road users too, obviously, but 32 tonnes of laden tipper truck, with terrible blind spots, poses far more danger than one tonne of Taxi or 90kg of cyclist...
Antman
3 May 2013
Of course not but I think it is reasonable to assume nobody hits a low bridge deliberately, whether insurance companies would cover such costs is another matter.
If the police witness them going through red lights or they are caught on camera action will be taken. On the railway lights don't change to red as the driver approaches.
Llanigraham
23 Mar 2013
Powys
You obviously don't work on the railway!!
GearJammer
12 Nov 2009
On the Southern
You obviously don't drive a truck!
Well said Sir!
lol, indeed, I certainly wouldn't be. And this sort of retarded suggestion is just what I expect from a rail forum.
Try fining me several hundred thousand pounds (for anything) and see how much of it you get..... can't get blood from a stone, and you can't take what I ain't got.
There was an article recently in 'Commercial Motor' magazine of a foreign registered truck that had hit a railway bridge, the driver was read his rights etc etc......... Then somebody read the sign on the bridge that read 4.1 Metres... Funny, all HGVs that come from mainland Europe can only be built with a max height of 4 metres, a quick bit of investigating showed the truck to be indeed 4 metres high, and the bridge sign was incorrect!
Also, the arch bridge on the A36 at Wilton west of Salisbury (carries the West of England line) marked up as 14ft on the signs, my truck is above that height, when I head north the electronic signs flashes up 'Over height vehicle, turn back' when I head south, the electronic sign flashes up 'High vehicle, use middle of the road' so not even the electronic sign can make its bloody mind up if the truck will fit or not.... oh, and by the way, I routinely use the route, and never once hit the bridge, in fact I stopped under it once and got out and looked...... it had a good 8-10 inch clearance!
So the signs, are useless!
....oh, and by the way, I routinely use the route, and never once hit the bridge, in fact I stopped under it once and got out and looked...... it had a good 8-10 inch clearance!
They aren't useless if they understate the height of the bridge. You might end up having to take a longer route than necessary, but at least you won't have a bridge strike.
455driver
10 May 2010
Don't they?
Would you like to put some money on that?
On the road you are supposed to drive at a speed where you can stop in the distance you can see to be clear, on a diet of traffic lights you have those nice amber lights which let you know the red is coming on next.
L&Y Robert
22 Apr 2012
Banbury 3m South
Somewhere, sometime, I saw a brilliant piece of - er, machinery? well, apparatus, then. On the approach to a low bridge, if driving an over height vehicle, a water curtain (more of a mist than a 'curtain') immediately decscended from the bridge, and ONTO IT was projected the "STOP - you are going to hit a low bridge" message. The driver would be faced with an apparantly impenetrable "wall" of descending water and on it the STOP message, projected at about cab height. Anybody else seen that?
I presume this is what you are thinking of:
[youtube]Dk9DjO-_rT8[/youtube]
dviner
7 Oct 2010
Umm... so you deliberately drove a vehicle that you knew exceeded the height restriction shown on the sign under the structure that displayed the height restriction?
GearJammer
12 Nov 2009
On the Southern
Word it how you like, I drove past a sign that I knew to be wrong, I drove my truck under a bridge that it fitted under.
