Yeah, maybe 'we' are.Or maybe it doesn't happen very often and we're getting this out of perspective.
Maybe the lessons of continuous brakes were learned. In which case it's a shame that the railway is still being let down by basic eqiupment failures now. Ever heard of engineering tolerances? or brake valves/regulators set up wrongly?
no confirmation of the cause on that thread...
Just saying that in the last 20 years or so I can't remember a journey spoilt by brake problems. Maybe I've just been lucky, or maybe it's that dragging brakes are very rare in a railway that is remarkably reliable in the first place.
I will dig around for accident enquiries that put the cause down to dragging brakes.
Aren't they powered to come off as well as on (even if only by a spring return?)
Maybe I ought to patent a stronger spring.
That's my understanding as well. If they were spring released then they could get stuck 'off'! hock:I thought they were "spring applied, air released"
Assuming that a wheel set change is required along with repairs to the brakes is this something that could be carried in Wembley Yard with the train then being sent on its way? Or will the wagon have to be unloaded and sent away to a repair facility? Just curious that's all
So a train will roll if it loses air pressure?definitely applied by compressed air pressure...
Maybe it's because most of my journeys nowadays are on Pendolinos, a few Voyagers, LM EMUs on the WCML or EMUs and DMUs in the west midlands.
Dragging disc brakes don't damage the tyres in the same way tho.Bearing in mind this is still subject to investigation dragging brakes can happen on any stock at any time no matter how many pre-departure checks one does.
Yes, hence handbrakes. See the Lac Megantic crash for a classic example.So a train will roll if it loses air pressure?
Yes which is why they have handbrakes or parking brakes.So a train will roll if it loses air pressure?
Sorry, I didn't make it clear that I meant a train in service, rather than when stopped and parked (using the handbrake).Yes, hence handbrakes. See the Lac Megantic crash for a classic example.
They are air applied AND air released. Thus, when required, the release cords can be pulled to completely release all the air and the wagon becomes unfitted.
See the Wikipedia page and the Westinghouse / triple valve bit.
Perhaps I ought to be glad that most of the trains I travel on don't suffer dragging brakes, but I thought this problem had been sorted out several times since the invention of continuous brakes...
We shouldn't have an intensively-used 21st century network stitched up by what sounds like a basic technical failure.
The railway's problem is that the whole system (and all customers) get stuffed by almost any lack of attention to detail by any one of the thousands of people who have to "do it right." On the road network there are a million potential culprits and no single participant gets the blame; On the railway no-one really gets blamed but the system suffers a serious reputational blow every single time.
Sorry, but blame is apportioned where due on the railways....or are you after a public flogging?
My understanding is that air pressure is used to release the brakes against the spring force that would otherwise apply the brake. A train that loses pressure while in service would stop rather than roll, would it not?
Yup, like I said - I was being stupid. This is what happens when you think out loud.No springs involved. Initial air pressure charges up the reservoir on each wagon. Once each reservoir is full, reducing the pressure in the train pipe allows the reservoir air to apply the brakes. Increasing air pipe pressure blows the brakes off again.
A wagon disconnected from a train will initially have a full brake application. Over time, the reservoir air will leak off releasing the brakes which is why there is a separate handbrake fitted.
Indeed. I would be shocked if the railway (which prides itself on safety) had anything other than a fail-safe mechanism on brakes.
As others have explained, the various braking systems are fail-safe in as much as that they should stop a train if there's a loss of air pressure, using the air pressure in the brake supply reservoir to do so. On a single-pipe air system, where the reservoir is charged from the brake pipe, the loss of air in the brake pipe will (through the distributor, as though it was responding to a brake application initiated by the driver) cause the brakes to be applied. On a twin-pipe system, where the reservoir is normally charged from the (higher pressure) main reservoir pipe, a loss of pressure in that pipe will effectively (and automatically) make the system revert to single-piped by a couple of non-return valves. On an EP system, where the air pressure to apply the brakes is controlled by electrical signals along the train, a drop in main res pressure below a certain level is detected, causing the brakes to apply along the length of the train (again using the air in the brake supply reservoir that's charged from the main res). In all cases, that'll at least bring the train to a stand.Sorry, I didn't make it clear that I meant a train in service, rather than when stopped and parked (using the handbrake).
I don't know what traction that is, but it'll be very different to the system on wagons such as these! As above, the brakes are applied using air pressure, with a 'fail-safe' system to bring the train to a stand if the air supply is lost. Once it's at a stand, with no main res (or brake pipe) air to recharge the system, the brakes will gradually leak off. That's where the spring applied parking brake on units comes into play - normally held off by main res pressure - on units, once the main res drops below a certain level. I doubt it'd be strong enough to bring the train to a stand from any sort of speed though (hence the 5mph restriction in the Rule Book for any movement with the brakes on the leading or trailing vehicle isolated, with certain exceptions, where you'd be relying on the application of the parking brake to stop the vehicle in an emergency, i.e. if the train becomes divided). There's no such thing on wagons, coaching stock etc. though, hence the reliance on a handbrake or otherwise securing the train.My traction manual is very wrong then because it states that the brakes are spring applied. Dumping all the air out the system in the event of a failure applies the brakes.
As I understand it the current system uses a series of electrical wires to do all the magic jiggery pokery with valves and governors etc working along side.
Again, I'm getting confused. Aren't we using Westcode EP brakes ?
Interesting that it wasn't a handbrake left on. Also interesting comment by Doningtonphil that faults in brake distributor valves are often the cause, in which case you would hope that technical investigations would manage to find the underlying problem and get it sorted.
Public flogging? I think that the railway industry generally tries to discover the root cause of a failure and ensure it is not repeated. Delay attribution (blame) may be a new industry in its own right, but prosecutions and punishments are rare.
Of course, now that we have so many separate businesses involved and hence potential compensation claims, there is less chance of full and open participation. (Unlike the time when there were only the Chief Mechanical and the Chief Civil Engineers' tribes blaming each other!)
