The Colonel
- Joined
- 1 Feb 2011
- Messages
- 261
Could someone advise if a Day Return from BZ6 to either Wanborough or Ash is valid via both Aldershot or Guildford please?
Thanks.
The Colonel
Thanks.
The Colonel
Permitted routes from Boundary Zone stations have not been clearly defined so I will not attempt to answer it in an authoritative manner.
What I would say is that both Aldershot and Guildford are reasonable routes for either Wanborough or Ash. I would be very surprised if the guard has a problem with you on either route.
As the boundary in this case is effectively Surbiton what are the permitted routes from there please?
The calculation below shows how Permitted Routes are determined for a Surbiton - Wanborough journey and a Surbiton - Ash journey.As the boundary in this case is effectively Surbiton what are the permitted routes from there please?
Surbiton - Wanborough and Surbiton - Ash: Permitted Routes calculation
Routeing Points (RPs) for Wanborough are Ash Vale, Farnborough Group and Guildford.
RPs for Ash are Ash Vale, Farnborough Group and Guildford.
We need to perform a Fares Check to determine appropriate RPs for Surbiton - Wanborough and Surbiton - Ash journeys.
Comparing Standard Anytime Day Single (SDS) fares, we have:From the Permitted Route Identifier, mapped Permitted Routes
- Surbiton - Ash SDS £9.30
- Surbiton - Wanborough SDS £9.30
- Surbiton - Ash Vale SDS £8.30. Therefore Ash Vale is an appropriate RP for both Surbiton - Wanborough and Surbiton - Ash journeys.
- Surbiton - Farnborough Main SDS £8.30. Therefore Farnborough Group is an appropriate RP for both Surbiton - Wanborough and Surbiton - Ash journeys.
- Surbiton - Guildford SDS £6.60. Therefore Guildford is an appropriate RP for both Surbiton - Wanborough and Surbiton - Ash journeys.
From the maps, these are:
- Surbiton - Ash Vale are on map WW
- Surbiton - Farnborough Group are on map WX
- Surbiton - Guildford are on map PD
In addition, the shortest route, and routes not more than 3 miles longer than the shortest route, are always Permitted Routes, adding:
- Surbiton - Weybridge - (Addlestone or avoiding Addlestone) - Byfleet & New Haw - Woking - Brookwood - Ash Vale - Aldershot - (Wanborough or Ash)
- Surbiton - Woking - Farnborough Main - (walk) - (Blackwater or Farnborough North) - North Camp - (Wanborough or Ash)
- Surbiton - (Oxshott or Woking) - Guildford - (Wanborough or Ash)
- Surbiton - Weybridge - (avoiding Addlestone) - Byfleet & New Haw - Woking - Brookwood - Ash Vale - (walk) - North Camp - (Wanborough or Ash)
