Cannot buy tickets for usual route when engineering work disrupts
suzanneparis
21 Feb 2015
I checked on NRE and discovered that a journey I wanted to make Leicester to London on a Sunday was showing a different route. Leicester to Nuneaton, change, then Nuneaton to London. Due to engineering work on the line between Leicester and London. I was coming back on the following Monday when there was a normal service showing.
I enquired at a ticket office if I could just buy a normal Leicester to London return for that journey. But was told I could NOT ??! Because it was using trains from a different TOC.
Can anyone please comment on this.
FYI after more checking on East Midlands Trains the trains are showing as running as usual directly from L to Lon on the Sunday, albeit with longer journey times. But I would still like the question answered purely out of interest.
Thanks for any help
What is the 'normal' ticket that you intended to purchase?
janb
16 Jul 2008
Leicester to London in the routeing guide is permitted on map MI or map MO, both using the Midland Main Line. So the reason that the off peak return is not permitted on the route via Nuneaton onto the WCML into Euston is that it is not a permitted route (TOC is irrelevant in terms of the Any Permitted Off Peak Return) .
CyrusWuff
20 May 2013
In my opinion (which may not be popular, but it is what it is) if EMT have requested ticket acceptance from London Midland (which I would suggest is unlikely, given the limited capacity between Leicester and Nuneaton) the normal ticket should be sold.
If ticket acceptance hasn't been requested, the appropriate ticket(s) for the alternative route would need to be purchased.
Hadders
27 Apr 2011
I'm out and about so can't check properly.
NRE is probably suggesting that you travel via Nuneaton due to engineering works. It seems this isn't normally a permitted route.
Does NRE say you'll need two tickets to make the journey
Alternatively, there might be a temporary routing guide easement permitting travel via Nuneaton.
John @ home
1 Mar 2008
If the train you intend to use between Nuneaton and London Euston calls at Watford Jn, you could buy:The Excess Fare for one leg only of the journey costs half the difference, that's £14.60, making a total cost of £47.10. An Excess Fare can't be bought online, so you'll need to buy this at a ticket office.
You change from using the outward leg of your ticket as the train stops at Watford Jn. After leaving Watford Jn, you use the return leg together with the Excess Fare voucher.
The outward leg is valid by any train on a Sunday. The return leg, together with the Excess Fare voucher, has the same time restrictions as a £57.10 Railcard Off-Peak Return Leicester - London Terminals.
Problem here I think, is that not every TOC bothers to do the necessary temporary routeing guide updates for engineering works which may only be needed for a single Sunday every now and again. Different if the situation might last for a couple of weeks.
You can see many of these temporary changes in the routeing guide changes thread...
Suppose (as an example near me) you want to travel from Fareham to Winchester, journey planners do not allow this to be done via Southampton, but this is the recommended diversion when the line via Botley is closed. So you just buy the normal ticket from the TVM or office, and the guard accepts it without question. But the journey planner still tells you that you need two tickets because you are off route.
ISTM that your EMT booking office is just applying normal routeing rules too literally, it has been accepted for many years that when planned engineering work diversions are on the normal ticket for the end to end journey should sold.
That's what I thought - hence I was wondering if it was a TOC-specific ticket.
greatkingrat
20 Jan 2011
It's not a diversion though, no EMT services are running to Euston. Presumably there are replacement buses being provided that mean it is still possible to use the normal route.
janb
16 Jul 2008
The OP themselves said,
So no need to invoke any routeing guide easements.
suzanneparis
21 Feb 2015
Many thanks all of you.
I suppose what I was trying to understand was what happens when engineering work obstructs a route.
In particular if someone already had a return ticket that they had bought in London for L to Leicester would they be allowed to use the return section from Leicester to London if engineering works obstructed the main route. Would they have to pay extra to go via Nuneaton??
