Jim said:I better tell Steve as I have forgotten to tell him![]()
wumpty said:Lol, Do you want me to update the page on TSC then? I can provide some self-installers for the updates if needed.
lankylancaster said:2. What does the sign that is like a yellow arrow with a black arrow in it mean?
Nick said:lankylancaster said:2. What does the sign that is like a yellow arrow with a black arrow in it mean?
It's a perminantly fixed caution signal. Based on the semaphore design, it's picture tells the driver the next signal/sign will be at danger normally this is before a main line connection like in Dennis's route. You then reach teh stop marker warning you, that you are no longer on private rail track, but on National Rail.
Dennis said:Both of the above are correct; the sign with the yellow arrow is a fixed distant - treat as a normal distant signal. It was placed there because of the main line connection ahead which has poor signal sighting (and a PSR is also there to help protect it).
On the freight route, the stop & whistle board was put in as because it is private siding at that point, normal railway rules regarding access by people to the line did not apply, so this stops trains going through the tunnel at high speed and ensures a warning is given, so no one is killed!
The rain in the tunnels is indeed leaky roofs - do heads out through a tunnel and you'll know why it is like this.
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(256) : Unable to find the specified file.: Structure.Beacon(0) brsigs\aws_null_0.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(257) : Unable to find the specified file.: Structure.Beacon(1) brsigs\awsmagnet_1.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(258) : Unable to find the specified file.: Structure.Beacon(2) brsigs\aws_tsr_2.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(513) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal2g.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(513) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow2g.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(514) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal2y.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(514) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow2y.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(515) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal3.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(515) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow3.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(516) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal4yg.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(516) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow4yg.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(517) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\repeat.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(517) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glowrepeat.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(518) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal3featherl.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(518) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow3.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(519) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal3featherr.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(519) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow3.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(520) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal4ygfeatherl.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(520) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow4yg.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(521) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal4ygfeatherr.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(521) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow4yg.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(522) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal2callon.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(522) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow2g.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(523) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal3callon.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(523) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow3.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(524) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal4callon.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(524) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow4yg.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(525) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\signal2gy.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(525) : Unable to find the specified file.: c:\program files\mackoy\bve4\Railway\Object\brsigs\glow2gy.x
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(555) : Structure reference is not defined: Track.Beacon 44003;0;0;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(751) : Structure reference is not defined: Track.Beacon 44002;0;1;60
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(755) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(764) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1171) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1209) : Structure reference is not defined: Track.Beacon 44002;0;1;45
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1213) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1231) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1329) : Structure reference is not defined: Track.Beacon 44002;0;1;100
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1353) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1414) : Structure reference is not defined: Track.Beacon 44002;0;1;120
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1424) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1444) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1526) : Structure reference is not defined: Track.Beacon 44002;0;1;100
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1533) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1562) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1652) : Structure reference is not defined: Track.Beacon 44002;0;1;100
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1654) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1667) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1771) : Structure reference is not defined: Track.Beacon 44002;0;1;100
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1773) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1787) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1872) : Structure reference is not defined: Track.Beacon 44002;0;1;100
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1874) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(1894) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2015) : Structure reference is not defined: Track.Beacon 44002;0;1;100
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2017) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2030) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2129) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2134) : Structure reference is not defined: Track.Beacon 44002;0;1;100
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2147) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2275) : Structure reference is not defined: Track.Beacon 44002;0;1;100
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2290) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2295) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2315) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2368) : Structure reference is not defined: Track.Beacon 44002;0;1;100
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2370) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2385) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2465) : Structure reference is not defined: Track.Beacon 44002;0;1;100
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2468) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2482) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2508) : Structure reference is not defined: Track.Beacon 44002;0;1;100
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2511) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2527) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2841) : Structure reference is not defined: Track.Beacon 44002;0;1;70
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2843) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2860) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2891) : Structure reference is not defined: Track.Beacon 21;0;0;3
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2893) : Structure reference is not defined: Track.Beacon 21;0;0;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2895) : Structure reference is not defined: Track.beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2902) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(2985) : Structure reference is not defined: Track.Beacon 44000;1;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(3080) : Structure reference is not defined: Track.Beacon 44002;0;1;20
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(3102) : Structure reference is not defined: Track.Beacon 44003;0;1;0
C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(3108) : Structure reference is not defined: Track.Beacon 44003;0;1;0
Simming said:what am I doing wrong, as I get this error on all the route files
Code:C:\Program Files\mackoy\BVE4\Railway\Route\Clarendon for BVE4\Clarendon_158_day_fine.csv(256) : Unable to find the specified file.: Structure.Beacon(0) brsigs\aws_null_0.x C:\Program Files\mackoy\BVE4\Railway\
