MatthewRead
This is why Great Western Railway should never have gone back on plans to use them because now there is going to be a lot of perfectly good EMU's in storage!
Perfectly good units the 365s and not just for commuter services a lot more of the more of the modern units seem far less suitable.It would be a a crime to scrap the 365s, which (before their ill-advised refurbishment) I've long regarded as the best units on the railway - comfortable, roomy and far preferable to their successors on the GN or the 700s.
I think they really should go back to SE. To replace the 376’s and provided stock continuity on the SE metro fleet. As they can work with 465’s.
No one said they're to be replaced in the next franchise. And it would be rather silly to replace the networkers as they're still getting their PRM mods done.376s are far more modern and suited to their roles than grotty 465s, anyway, there would be no point as the Networkers are scheduled to be replaced off of that line within the next franchise.
Nothing concrete has yet been said about Networker withdrawal down SE's way, but it's being very strongly hinted at...No one said they're to be replaced in the next franchise. And it would be rather silly to replace the networkers as they're still getting their PRM mods done.
Scrapping seems very unlikely given the recent refurb; I suspect (blindfolded, and taking a stab in the dark here) that if SE would take them on, minimal work to get the DC networkers & dual-voltage networkers talking to each other would be needed. Perhaps storage until such time as the MML wiring to Corby is complete, then use on services from Corby to St. Pancras?
Personally, I think these units look pretty tired and grubby inside. The interiors are fundamentally sound but could definitely do with a deep clean and moquette change at the very least. Agree that reliability is good and don't see any reason to scrap them but I don't think the average commuter has the same affection as some forumers do.
I agree with @bramling The passengers on the 0656 from Peterborough would welcome it being operated by 365s rather than 700s.
Also worth noting that the refurb done a couple of years ago was a clear dumbing down to get us ready for the introduction of the 700s.
Sorry, but how can you 'dumb down' a train interior?
Loss of carpets, cheaper finishes, and an interior layout that most people regard as inferior.
The change to the interior layout, however, I believe it more to do with accessibility requirements and the need to create priority seats with enhanced legroom. A stupid thing to do, because commuters quickly notice which seats have the extra legroom, so guess which seats now become first to fill, and are thus now *less* available to those they are intended for? Also the reduction in table seats has tended to mean squabbles over tables can be more likely - particularly evident at weekends or days like today when the "I only travel once in a blue moon but expect everything to revolve around my needs" brigade are out in force.
But that's not "dumbing down" - dumbing down suggests there was intelligence there before, which as train interiors are inanimate means they can't be made 'dumber'.
Unless you're au-fait with the costs of materials, then you can't state the finishes were 'cheaper' - they may actually be more expensive, but equally more robust. Which means they are lower cost, but not cheaper.
The reality is, train interiors need to be functional and easily cleaned. Carpets don't lend themselves to that, particularly on suburban stock where there is a high-footfall. So some kind of 'solid' finish material makes far more sense.
365s have always been good units IMO, it's sad to see some of them going. Having two relatively small fleets at Great Northern (20 or 30 units) doing the same thing instead of one larger fleet was always ridiculous, especially as 387s are most certainly a downgrade from the 365s. A better compromise would have been to keep all 40 365s at GN, and order a few additional 717s to make up the numbers required to cover the diagrams, perhaps for the proposed Royston - Kings Cross peak trains (and to avoid the semi-permanent Hertford to Stevenage bus )
Apparently GN 387s are routinely running around without the ability to walk through the whole train when in 8- and 12-car formations, can anyone confirm or deny whether this is the case?
Think they be more better to replace 455’s on southern.Cascade the 376s to Southern to replace the ageing 313s. They would make a good use there.
You can’t couple a networker and 376 together.
There’s no reason why they can’t come to SE to replace certain 465/9 workings so the /9’s can return to Metro.Neither can you couple and operate a 465 and 365 in passenger service; they're not electrically compatible, both the 465 and 365 have to have the coupler selection switch in the "other" or "319" position which removes some functionality (I seem to recall you get a permanent pass comm alarm or something similar, it's been about 15 years since I coupled the two together). They are also geared differently, a 365 is geared to accelerate at a peak of 0.77ms2 and a 465 at 0.88ms2 so there would be problems with performance and reliability.
365's cannot, for all intents and purposes, return to DC operation, both due to certification issues surrounding 50Hz tripping timing for the line breakers opening and the singular lack of the DC equipment to refit (one complete set of shoe gear, cables, connection boxes, arc shields etc. was supposed to have been kept for pattern purposes after AC conversion but after both Doncaster and then Crewe works were closed/down sized these could not be found).
A lot of work regarding 365 future deployment was done both in the early 2000's, when the 16 DC units were coming off lease with Connex SE, and in the last 5 years, when it became certain that the GN route did not need the whole fleet; all kinds of options were considered and some pretty outlandish ideas were given serious scrutiny (365's on HS1 for example) but the potential for deployment off the GN was limited, either for physical, both operational and maintenance, or financial reasons.
Removal of carpet and replaced with vinyl that's difficult to keep clean
Fewer bay seats and more airline seats
Harsher lighting
We had a thread about it at the time. They are still excellent trains but to regular users the refurbishment appeared to be a downgrade to get us used to the bargain basement interior of the 700s.
I think your right here replacing networkers is not going to be a easy job its such a large fleet been servicing a large area for a long time.No one said they're to be replaced in the next franchise. And it would be rather silly to replace the networkers as they're still getting their PRM mods done.
