cjohnson
- Joined
- 3 Sep 2009
- Messages
- 597
Spotted two 4-car units at Wimbledon this morning (didn't get the numbers) - one with barrier vehicles and a Colas loco, the other by itself.
4 Cars... Have they given up...?
They have just arrived from Doncaster (I believe?)
I would think that 4 car units are 458/0s ready to send back to Donny.
Or they are a 377 that got quite lostIf they are white and 4 car they haven't been
Can anyone provide a full list of the sets converted or in the process of being converted. Here is what I have but I am not sure it is correct:
458501 Doncaster
458502 Doncaster
458503 Doncaster
458531 In service
458532 Testing at WCD
458533 Testing at WCD
458534 In service
458535 Testing at WCD
458536 Doncaster
Which route are the 458/5's being run on, is it the route to Windsor?
Yes, Waterloo-Windsor & Eton Riverside and back. Can't remember now what the exact departure times are now though.
They have been listed earlier in this thread:
0558 Waterloo to Windsor
0723 Windsor to Waterloo
0828 Waterloo to Windsor
0953 Windsor to Waterloo
1058 Waterloo to Windsor
1223 Windsor to Waterloo
1328 Waterloo to Windsor
1453 Windsor to Waterloo
1558 Waterloo to Windsor
1723 Windsor to Waterloo
1828 Waterloo to Windsor
1953 Windsor to Waterloo
2058 Waterloo to Windsor
2223 Windsor to Waterloo
As seen here: http://www.railforums.co.uk/showpost.php?p=1729168&postcount=672
What's the cost of the 485's compared with a new build of class 450s?
When the 3rd rail lines get converted to overhead, how much work is involved in converting the 485's to overhead? I've read somewhere that the 450s have got all the wiring needed for overhead in place and would presumably just need a transformer bolted onto the underside, a pantograph bolted into the pantograph well (both connected to the wiring), possibly a new panel in the cab and a software update.
Been reported elsewhere that 458003 has been either out of service or on restricted duties, unable to couple to other units, for a while now. The only place it would have been used recently is on the Guildford-Ascot line so that would probably explain why you hadn't seen it.
For the first part, with all the delays I imagine SWT management will be asking themselves the same question!
As for the other, I vaguely remember that when they were previously planned to go off-lease from SWT, one possibility mooted was sending them to Glasgow to work alongside the 334s- the only AC 'Junipers'. Then again, it's also been said on here that converting the 458s is likely to be a bit trickier than it would for the 450s, though I'm not a fitter/mechanic so I wouldn't know the details!
8003 had been stopped since August. It never even got out of the depot.]
How did it get to Wabtec then?
Brian
Brian
Slightly related to the thread... anyone know whether the platforms at Feltham will be extended?
Not in the current phase of work.
However the latest description of the future CP6 scheme (i.e. by 2019), to allow for 10 car services to Reading now mentions a requirement to 'review the options' to allow 10 car services to call at Feltham, but it is will be included in the already planned Feltham re-signalling scheme.
I suspect SN would've preferred to keep the 460s (they were designed for GatEX)
