Class 810 for East Midlands Railway Construction/Introduction Updates
fgwrich
15 Apr 2009
Hampshire
Quite a good design decision there to have the doors open into the vehicle end and thus the bit taken off the passenger saloon length is the bad bit by the door pocket with no armrest or window!
Yes, it’s a shame that the original issue made it into production for the large bulk of the 80X fleet, when this shows what could have been done almost from the start. Though it’s a shame to see Hitachi still using their somewhat annoying pocket doors - they have long had an aversion to the “unreliable European plug doors” which was briefly broken on the 385 order.
Ethan1852
10 Jul 2020
Leicestershire
Found this picture on LinkedIn, not sure if it shows anything we didn’t already know..
IMAGE: Purple 810 bodyside being assembled inside of the factory. Several trains are visible.
Nice to see progress. It is worth mentioning however EMR have seemed to have delayed the introduction yet again. On there website under Intercity Fleet it says they will begin mainline testing in Late 2022 with introduction in Early 2024 instead of 2023.
Coming soon - Aurora InterCity trains​
The new state of the art Aurora train fleet is financed by Rock Rail East Midlands and will be built by Hitachi Rail UK in County Durham. They can run using electric overhead lines wherever possible, taking advantage of the £1.5 billion Midland Main Line Upgrade and will replace the diesel train fleet.
As a result, they are quieter and greener, meaning lower carbon emissions and a better environment for passengers, stations and communities along the route. Passengers will also see major improvements, including more seats and fresh, modern interiors alongside air conditioning, free WiFi, plug sockets and better passenger information screens.
Construction is underway with the first units due to start Main Line testing in late 2022, with the first entry into passenger service due in early 2024.
Is there some kind of 'big bang' switchover plan from 222s to 810s? A whole year from mainline testing to service introduction seems somewhat long if it is then followed by a phased introduction.
800001
24 Oct 2015
As it is a new type of the 80X fleet, it need full testing unlike previous batches of the fleet.
As it is a shorter carriage with various other alternations it needs full type acceptance, this will be why it is longer than previous batches.
Mikw
20 Apr 2022
Leicester
I'm so looking forward to trying one of these out!
I've been on the Azuma unit's they're nice but i found them a bit "bumpy". How do you think these will cope with the EMR with all it's bends and curves?
800001
24 Oct 2015
Maybe different as EMR will be 23 meter coaches versus 26 for LNER.
Nicholas Lewis
9 Aug 2019
Mechanically and electrically its the same and thats where a lot of the acceptance testing time goes so a year is just too long but if they achieve that they will doing better than several of their peers.
800001
24 Oct 2015
That maybe the case, but several of This class will go to Old Dalby test track as it is classed as a new fleet/build. That is where the time length comes from.
Plus, how do you do mechanically and electrically it’s the same? How do you know nothing has changed?
AM9
13 May 2014
St Albans
Don't they have much higher power engines than even the class 802s, and hasn't that power been accommodated under a shorter car length. That could certainly result in different failure characteristics.
800001
24 Oct 2015
I know they are definitely a shorter vechicle length, couldn’t tell you anything more.
gingertom
19 Jun 2017
Kilsyth
I'd read a somewhere that there are to be 4 engines, which are uprated versions of those fitted to the 80x, and only 2 vehicles are to be fitted with traction packs, 4 bogies/ 8 motors, each motor being 330kw instead of the 300kw of the 80x.
43096
23 Nov 2015
No, they have four out of five cars engined, rather than higher power per engine.
AM9
13 May 2014
St Albans
So in approval terms that are quite different beasts. Given the problems associated with the introduction of some of the class 8xx trains, why are some here so desperate to rush them into service?
QSK19
29 Dec 2020
Leicestershire
Indeed. Given that there seems to be no home lined up for the 222s, it’s not like EMR will be at risk of having no stock - and in any case, as EMR well knows from the ongoing 196 introduction fiasco having knock on effects on their Regional stock shortage, the TOC will keep their existing stock until the new ones are ready. So, even if there were a new home for the 222s, EMR would keep them for as long as needed.
As much as I’m really looking forward to seeing the 810s too, I’d rather they take a little longer (though not to the 196 extent!) to ensure everything goes smoothly as opposed to rushing them into service and then having endless teething problems.
Wyrleybart
29 Mar 2020
South Staffordshire
Whilst the 810 might have much the same kit as the earlier AT300 series, don't forget it is a new length of bodyshell with no previous history of dynamics - the flexing, twisting and general crashing around our railway at up to 125mph. Mechanical vehicles can be influenced by vibration harmonics so these need to be established and understood before being signed off fit for use.
I remember the first time I rode in a class 47 cab and the rattle from the cooker whilst the engine was idling. As soon as the engine increased it's RPM the rattling stopped but it made me wonder why it has been a rattle for the last sixty years. The technicalities of railway engineering were perhaps in a different place back then.
XAM2175
8 Jun 2016
The major structural differences are the shorter cars and the new front-end profile.
There will indeed be one extra traction genset, for 4 in total, and they have been uprated to 735 kW each from the Class 802's 700 kW (939 to 986 hp). The "much higher" might be a confusion with 800's engines, which are 560 kW (750 hp) each.
The formation will be DPTS-MS-TS-MC-DPTF, where all cars bar the TS carry a genset and the TS has the transformer instead. This is also a change from the five-car 802s, where the centre car is an MS instead, but I don't know the reason for or the significance of the change other than perhaps the shorter cars have forced a redistribution of equipment.
AM9
13 May 2014
St Albans
OK, maybe 'much higher' was a not quite true, but given the shorter car length*, all of that power is packed into a smaller space possibly bring with it a different temperature curve.
* unless the difference in length is wholly taken from outside the bogie centres, thereby reducing the overhang and need for accentuated tapers at the car ends.
Speed43125
20 Jul 2019
Dunblane
The requirement for 125 mph running while in diesel mode necessitated an extra Genset over the 802s and their implementation in pantograph cars.
XAM2175
8 Jun 2016
You'll note that I said I can't advise on why they've gone from three to two cars fitted with powered bogies, not why they've added an extra genset. Besides which, the 802s can achieve 125 mph, can they not? My understanding was that the extra genset was the result of a need to keep or better Meridian timings.
Energy
29 Dec 2018
The 802s can do 125mph on diesel. The extra genset is to match the 222s acceleration.
I'd imagine they were redistributing the equipment anyway and the centre car just makes the most sense for the pantograph.
Remember that being coupled together they need to have a certain distance between pantograph for the OHLE, going by the spacing for the class 360s the 810s can operate fine either if one of them is facing the wrong way.
They are Lumo ones :)
Thanks but that post is from November 2019 :D
XAM2175
8 Jun 2016
Indeed you do need to allow adequate spacing*, but my understating of the formation is that the pantographs are going on the driving cars, in standard AT300 fashion. I say again that the unexplained change is that the centre car in an 810 is a trailer whereas in all five-car 802s it carries traction motors.
* = I've got the delayed trips on loco-to-loco-coupled ICE 2s to show for it :{
RailWonderer
25 Jul 2018
All around the network
The IETS will be an inferior train to the Meridians they replace, the only thing they have going for them is the increased legroom in the airline seats. The Meridians improved on the Voyagers shortcomings and are a fine train all around It will be a huge loss to see them go.
