xotGD
- Joined
- 4 Feb 2017
- Messages
- 6,102
That's an easy one Rail blue or large-logo blue. Same as every other locomotive.Who can tell , but which liveries do people think these new locos will look good in ?
I didn't realise that. Must have been later than the plan I heard about.It was more than a proposal: they actually hired the flats in. I think they were paired Multifret wagons so it was actually 50 flats, which were permanently coupled in pairs.
I think they would look rather good in Austrian Federal Railways red with a white stripe, as they certainly wouldn't be leased by the other "red" operator.Which liveries do people think these new locos will look good in ?
Which does rather suggest why 75mph is the usual maximum speed for intermodals - it's a good compromise between operating speed, wagon cost, maintenance cost, track forces and ride quality.It ain't quite that neat, unfortunately.
1. The FIAs (Eurotwins) had to run on balanced wheelsets;
2. The payload is markedly less. On class C lines (= 20t axleload) the payload allowed at S speed is 107.5t; at SS it is 99.5t, and at 140kph (BR only) it is 75.5t. (Taken from the data panel on the wagon.) In UK terms 107.5t @ 60mph; 99.5t @ 75mph; 75.5t @ 87.5mph. No idea wher you would be for 100mph.
Pat
That's the type. Caption says Megafret but should be Multifret.Which does rather suggest why 75mph is the usual maximum speed for intermodals - it's a good compromise between operating speed, wagon cost, maintenance cost, track forces and ride quality.
Assuming this is a picture of the correct info panel - https://gingespotting.smugmug.com/Wagons/F-TOPSCode/FIA/i-JBzDsND/A - the tare weight (for the twin set) is 36.55t, so at 87.5mph with 75.5t payload it works out to only 14t axle load (eight axles per set). Basically passenger stock axle load levels, but on probably less sophisticated bogies.
“They are equally suited for freight traffic and passenger services. They could haul TransPennine Express’ Mk.5As without a problem and a number of passenger operators have enquired about the locomotives.” ...
Future options
“It became clear from conversations that the tri-mode option is appealing. In the freight sector there are operators using electric traction but they have to swap traction for ‘66s’, or use ‘66s’ for complete journeys under the wires. This can eliminate that.”
Yes, that appears to be the same Rail Express article I was referring to upthread (I had the paper magazine version of it at the time).Lots of new details in this article in Rail Express
The future of UK traction arrives | The Railway Hub
Richard Clinnick witnesses the arrival of the first Class 93 and provides all there is to know about the new tri-mode locomotive.www.therailwayhub.co.uk
And Scotrail - if the HSTs have failed to deliver? You could then also bring back the Clansman and restore the WCMLs links north of just Glasgow and Edinburgh.Given that “a number of passenger operators have enquired” is a small list considering TPE are binning the MK5a‘s I assume this could only be Chiltern and or GWR?
Yes a '66' might use 3x more fuel but it also has nearly 3x the sustained power on diesel (and I think the last time I looked, the track access charges for a 66 were quite low - and in any case, there will be a lot more axles in the train behind presumably paying track access charges - e.g. 30 x bogie container flats is 120 axles...).ROG claimed the 93s have a third of the fuel costs of a 66, and weigh one third less, so much cheaper track charges too.
Yes, and in any case the 93's on diesel plus battery are nowhere near powerful enough to replace a 68, especially once you take into account the ETS load as well.Chiltern want to get rid of their 68s, not get even more...
you (and others) keep stating that the 93s (and sometimes 99s) are "expensive", but is there any publicly available information suggesting how much they are, or any comparison to other locomotive lease charges / sale prices?Remember that the Rail Ops UK people interviewed in that article have a duty to promote/talk up the company and its services, and 'enquiries' are not 'serious interest'. I wish them well, but these are expensive, complex, locos and that will have to be reflected in the leasing/hire costs somewhere. You can sell almost anything if it's cheap enough, but the skill is in maximising the profit...that's why good sales people and contract negotiators are worth their weight in gold!
93s arent 68sChiltern want to get rid of their 68s, not get even more...
Whether there is or not, it is very worrying that freight operators have reportedly been replacing electric traction with diesels because of the cost of electricity for traction.you (and others) keep stating that the 93s (and sometimes 99s) are "expensive", but is there any publicly available information suggesting how much they are, or any comparison to other locomotive lease charges / sale prices?
93s arent 68s
I'll get my 'wet finger' out and try...you (and others) keep stating that the 93s (and sometimes 99s) are "expensive", but is there any publicly available information suggesting how much they are, or any comparison to other locomotive lease charges / sale prices?
Interesting article but what it doesn't make clear is the capacity of the battery which should be given in Kw/hr rather than just kw.Lots of new details in this article in Rail Express
And given that statement is from ROG, the statement will be being hyped up. Operators enquiring may just be someone asking for the technical specs and nothing more is heard. It may even be an enquiry about using them for stock moves...Given that “a number of passenger operators have enquired” is a small list considering TPE are binning the MK5a‘s I assume this could only be Chiltern and or GWR?
I've not seen any info about the storage capacity of the battery, just its rated discharge power (the 400kW rating).Interesting article but what it doesn't make clear is the capacity of the battery which should be given in Kw/hr rather than just kw.
According to another thread, TP are planning to stop using the Mk5s soon anyway.Re Transpennine pulling mk5s 1600kw plus the diesel may well be enough to get up the hill from Stalybridge to Marsden.
Perhaps the forthcoming class 99 may be a better bet for TP.
The battery capacity is 80kWh, so that's 12 minutes (1/5 of an hour) at 400kW peak load.it doesn't make clear is the capacity of the battery
The diesel is only 900kW. So not best suited to climbing hills off the wires. The battery seems to be for accelerating up to line speed once or twice before recharging.1600kw plus the diesel may well be enough to get up the hill from Stalybridge to Marsden.
I doubt it's capable of more than 400kW output - I think they would be shouting '1600kW' from the rooftops if it was capable of anything like that...
The class 99 is designed as a freight loco with a 75mph top speed and no ETS (as far as I'm aware).
The real performance benefit will come on AC power, where the 93 will deliver over twice the power of a 66 (4000kW vs 1850kW)
Thanks.The battery capacity is 80kWh, so that's 12 minutes (1/5 of an hour) at 400kW peak load.
UK freight locos e.g. the cl. 66 don't have any ETS capability. The wagons don't have the wiring for it either.Isn't an ETS connection still used on freight locos for things like refrigerated containers?
No. Refrigerated containers have built in refrigeration power supplies - for obvious reasons.Isn't an ETS connection still used on freight locos for things like refrigerated containers?
Thank you, that gives a good idea!I'll get my 'wet finger' out and try...
In 2018, when Rail Ops UK first announced they were ordering ten 93s, they said it was "a deal worth more than £40 million" (see https://www.railmagazine.com/news/n...s-fuels-its-ambitions-with-tri-mode-class-93s ). So £4m per loco at 2018 prices from Stadler. It took till 2021 and Star Capital buying a majority share of of Rail Ops UK by before they had the money to order them. Given what's happened between 2018 and 2021, I suspect the price has increased over that period (UK inflation was about 5%, Spain 3% over that period, so index that £4m to around £4.2m).
In 2012, the value of the DRS order for the first 15 class 68s was estimated at £45m (according to https://en.wikipedia.org/wiki/British_Rail_Class_68#Order_and_production ) - so £3m per loco, 10 years ago for a diesel-only equivalent. I can't find any mention of the value/cost of the ten class 88's ordered later, but I'd be surprised if they were cheaper than the 68s.
For comparison, the original EWS order for 250 cl. 66 in 1996 was worth £375m, so £1.5m per loco. From 1996 to 2021 UK & US inflation was about 1.6x-1.7x, so a 66 would in theory cost about £2.5m in 2021 (and might have cost about £2.1m in 2012, for comparison to the cl. 68 price).
So I suspect (a very wet finger estimate!) that a 93 might be 1.5x to 1.7x the cost of a notional new cl. 66 in 2021.
If anyone has better information on the loco prices I'd be very interested to know, but usually it's hard to find because it's (understandably) pretty commercially sensitive information. The same goes for leasing costs.
Are there many trains normally using double-headed 66's (other than maybe standing-in for something else like a 59/60/70 on a heavy bulk freight or 2 x 90's on intermodal)?Sounds like they will be well placed primarily where they can replace 2 other locomotives, such as heavy trains that only need to do low speeds away from the wires that currently would need 2x 66 to have enough power under wired sections
The 93s are more expensive to purchase, but capital equipment is a relatively minor cost for FOCs, since the equipment has amortization measured in decades and relatively high utilization. I've seen the ownership cost per mile for a Class 66 quoted around £1.50, that's fractions of a penny per ton/mile hauled.I'll get my 'wet finger' out and try...
I do remember that the container terminal at Wilton was built there because ICI wanted the ability to load their containers beyond the Road limit at the time. The destination would also need to be somewhere that didn’t need to involve road haulage or a break-bulk centre like Daventry.Key takeaways:
- Container trains are not really very heavy because the box payload is limited by the road limit of 40 tons
The more important takeaway is that this is a presentation by a company desperate for someone to hire these locos. There is going to be a huge amount of ’spin’ put on their capabilities. As yet, there is no real world data to support any of these assertions.The 93s are more expensive to purchase, but capital equipment is a relatively minor cost for FOCs, since the equipment has amortization measured in decades and relatively high utilization.
The dominant costs are staffing and fuel, so I guess ROG thinking is that quicker journeys without traction swaps (as done frequently by FL with their 90s) can significantly reduce staffing costs, and the 93's are much more fuel efficient too.
There's some very interesting performance comparisons with other Locos in this presentation by Karl Watts of ROG:
Key takeaways:
- On diesel, Class 93 is not far off a Class 68 performance wise, albeit it seems to be geared a bit higher, so it will accelerate faster with a lighter load
- Modern traction controls obviate the need for six axles on all but the heaviest trains
Higher gearing results in slower rate of acceleration.Key takeaways:
The gross weight of a current HGV is 44 tonnes, giving a payload of 29-30 tonnes. Having successfully lobbied for longer HGVs, the road haulage industry is now seeking even longer 62 tonnes HGVs, capable of carrying 1 x 40ft plus 1x 20ft container, and is quietly receiving support from the DfT.Key takeaways:
