Let me ask this question then, if the drivers route knowledge tells him that the corner is there, then why has there been possibly previously two non fatal incidents of speeding on that bend, before the most recent fatal incident? Unless all three incidents are down to drivers blacking out, I would say that there is a need for some drivers to get a better idea of what point to be slowing down before the corner in question and as such place warning speed signs plus safety braking equipment like TPWS prior to the car to make sure that the driver is putting on the brakes of the tram in time and not just at the end of the tunnel, just prior to be going round the bend. That way you can make sure as you state. that the the curve is driven appropriately.
There are numerous reasons why a driver might not reduce speed in time for a speed restriction.
First of all, the driver could brake in the normal place but be caught out by low rail adhesion. Since this incident I've been surprised to learn that the hazard brake on trams can be more badly affected by poor rail conditions than I previously thought. It's worth noting from photos that the immediate approach to the curve from the Lloyd Park direction seems to be very prone to leaf-fall, and bear in mind the morning concerned was also raining. Nothing has been released officially which confirms or denies whether poor rail conditions may have played a part. Obviously it's part of a driver's skill to anticipate poor rail conditions, but humans make errors of judgement ...
Then the driver could be incapacitated by some kind of medical issue. Remember this has been postulated as a possible cause of the Moorgate accident. History and experience shows a deadman device can't always be relied upon to be effective.
You can also add fatigue to the last possibility.
Then some kind of distraction, either a device like a mobile phone, or even something simple like reading a book (personally I find the latter unbelievable, but where I am drivers openly talk about reading books or newspapers whilst driving trains so never say it doesn't happen), even looking at a duty book at an unfortunate moment, perhaps distracted by something going on inside the tram, something unusual going on outside, or a personal issue weighing on the mind. All it takes is the mind to veer off-task for a few seconds and an error can happen.
Finally it's possible to simply have a good old-fashioned lapse of concentration. Anyone who performs a repetitive task (and driving a tram on a fairly limited selection of routes, stopping at every station and where all of the stations look pretty much the same must rank pretty highly for boredom) will tell you that it's quite possible to lose concentration for seemingly no reason. There is a particular "trap" on the railway where a driver can see a yellow or red signal, one which they normally see showing that colour, then have a lapse of concentration and make no further reaction until the last minute. This has been a factor in many SPADs which I have investigated. One can only conclude that the mind normalises a situation where a reaction (i.e. braking) is normally/always required, and allows itself to switch off, without actually making the correct reaction. If you add in the possibility of confusing one's location, again quite likely to happen when performing a repetitive task, and it's again easy to see how errors can occur.
The above list is in no way exhaustive.
You can have all the warning signs in the world, but it doesn't necessarily prevent any of the above from occurring.
Whilst it's good to know the root cause of an incident, when it comes to devising preventive measures it can be irrelevant -- you simply devise a mitigation which covers all the possibilities you possibly can, within the budgetary and technical constraints imposed upon you. This is what was done after Moorgate, and I suspect is what will happen here.
