Displaced 185s..
Discussion in 'Traction & Rolling Stock' started by Flywaver, 18 Nov 2011.
Thread Status:
  1. Flywaver
    Flywaver Member
    190
    10 Nov 2009
    Purely gossip. There is some sort of talk of 185s replacing 170s on XC...
    How would this happen? Ordered 350s and a cascade or lighter 170s?
    I know the 185s are heavy but much of XCs 170 routes are being upgraded for heavy freight so i can see it would work. Plus XC has 29 170s so not all 185s would be needed... Just wondered if anyone knows anymore?
    Cant say i believe it. XC arent in any hurry pushiong Voayagers to Stansted...:roll:
    Rail Forums
  3. gordonthemoron
    gordonthemoron Established Member
    5,809
    4 Sep 2006
    Milton Keynes
    the times I've used XC from Stansted to Peterborough, the train has been fairly lightly loaded, esp. south of Cambridge
  4. DarloRich
    DarloRich Veteran Member
    20,031
    Work - Fenny Stratford(MK) Home - Darlington
    Cant see TPE wanting to give them up any time soon!
  5. jopsuk
    jopsuk Veteran Member
    11,820
    13 May 2008
    Surely before any 185s go walkies from TPE they'll get rid of their small fleet of 170s?
  6. aformeruser
    aformeruser Veteran Member
    30,637
    23 Jan 2009
    If North TPE is electrified then maybe in 8 years time they'll be the possibly of a 170 and 185 swap. However, 185s will be more suited to Manchester Airport to Cleethorphes and Blackpool to Scarborough than 170s.
  7. Schnellzug
    Schnellzug Established Member
    2,926
    22 Aug 2011
    Evercreech Junction
    Why not transfer them within forstGroup to Portsmouth_Cardiff, thus allowing the 158s to revert to 2-car and be used to augment other services?
  8. Royston Vasey
    Royston Vasey Established Member
    1,404
    14 May 2008
    Cambridge
    Always full to rammed west of Peterborough though. Through the Midlands I've never seen it lightly loaded
  9. ChrisCooper
    ChrisCooper Established Member
    1,787
    7 Sep 2005
    Loughborough
    Can't see what the point would be anyway. A 3 car 185 isn't going to give a capacity boost compared to a 3 car 170. Performace would be better, but the 185s are designed to run over the Pennines where there are steep gradients, wheras the Cross Country 185 routes are fairly level, other than the Lickey Incline, so 185s wouldn't really have a great advantage. Stopping patterns are such that I doubt the acceleration would give a real advantage either. On the other hand there would be higher fuel costs, higher access charges, and there are a lot of SP90 speed limits where the 185s would be restricted to 75mph unless there were upgrades to allow them to also do 90 or 100.
  10. ainsworth74
    ainsworth74 Moderator Staff Member Moderator
    19,149
    There is only going to be around ten 185s freed up in the next few years anyway (going on the size of the 350 order) that's such a small fleet it seems like it would be virtually impossible to send anywhere else. Far better to use it to double up existing TPE services than move them anywhere else in the country. If the 185s are to be moved then lets move them as one large class of 51 units not split them up into small groups.
  11. DarloRich
    20,031
    as you say - much better just to whack them onto the exisiting services
  12. aformeruser
    30,637
    23 Jan 2009
    First Group may not be running either franchise in 2019, which is the earliest any 185s will be available. The ones released off Manchester Airport to Scotland and Blackpool are going on to other TPE services for strengthening.
  13. swt_passenger
    swt_passenger Veteran Member
    18,714
    Using them within TPE is surely DfT's published policy?
    In their paper from Jul 2009, Britain’s Transport Infrastructure - Rail Electrification:
    "Electrification will enable diesel trains to be transferred onto other
    TransPennine Express routes, delivering much-needed additional capacity
    with many trains able to operate as six-carriage trains instead of threecarriage trains today."
    http://webarchive.nationalarchives....t.gov.uk/pgr/rail/pi/rail-electrification.pdf
  14. Schnellzug
    2,926
    22 Aug 2011
    Evercreech Junction
    Oh yes, that's all depending, of course.
  15. aformeruser
    30,637
    23 Jan 2009
    After doing some fishing it sounds like you got half the rumour story.
    The full rumour seems assume the North TPE routes will go to XC (which is one proposal in to the review in rail franchising) then the 185 fleet will go to XC leaving 170s for the remaining TPE routes. This will mean some of the current 170 XC services will see 185s.
  16. MidnightFlyer
    MidnightFlyer Veteran Member
    12,793
    16 May 2010
    I'd go for either Stansted Airport-Birmingham New St or Portsmouth Harbour-Cardiff Central personally.
  17. aformeruser
    30,637
    23 Jan 2009
    I don't get why people keep saying 185s should run that route. The 185s have less capacity than 3 car 158s and other people are saying they need 4 car units on that service.
  18. MidnightFlyer
    12,793
    16 May 2010
    No reason they couldn't be doubled up though.
  19. aformeruser
    30,637
    23 Jan 2009
    If the capacity given by 6 cars isn't utilised effectively, they will be extremly expensive to run doubled up.
    Also when I said capacity previously I just meant seating capacity. A 3 car 185 fits over 300 passengers on TPE - 180 seated and 150 standing.
  20. MidnightFlyer
    12,793
    16 May 2010
    Fair enough. What about SSD-BHM or Inverness / Aberdeen-Glasgow / Edinburgh then?
  21. aformeruser
    30,637
    23 Jan 2009
    What I don't get is why people are saying 4 car units are needed for a route and then other people are recommending 185s for the same route. That would be like saying 5 car DEMUs should replace FGW HSTs.
    At present any plans for 185s to go to another part of the country needs to be done in conjunction with other units going in the opposite direction or an order of new trains.
    I prefer 170s to 185s as they provide a more comfortable environment to travel in for longer distances. So if Scotrail want to swap their 3 car 170s for 3 car 185s I'd be more than happy to see 3 car 170s on TPE.
  22. ainsworth74
    19,149
    You are of course correct. It seems that somewhere between my brain thinking up the post and my fingers typing it out the part that said "as far as I'm aware the DfT are planning to use them to double up existing services anyway" got lost :oops:
    In my defence I was rushing as I had to be in Uni for a seminar...
  23. 350401
    350401 Member
    135
    5 Feb 2009
    If that is true, I'd assume that TPE are getting more 170s and/or 350s? Running the entire South TPE and NW TPE with 8 2car 170's and 10 4car 350's doesn't exactly seem feasible - more like a recipe for overcrowding!?
  24. aformeruser
    30,637
    23 Jan 2009
    The assumption is that Manchester Airport to Blackpool will get 319s.
    I guess 185s on XC 170 routes means XC 170s on current TPE routes. Although, if TPE gets split between different franchises I can see a much more complex cascade. If Manchester Airport-Cleethorphes goes to EMT I can't see them having a small 170 fleet and the future Northern franchise getting a small 170 fleet for the North West - more likely that Liverpool-Norwich will go over to 170s and 158s will be used on North West routes.
  25. Flywaver
    Flywaver Member
    190
    10 Nov 2009
    Well it's not bad if i got half the gossip right. The Stansted route has its climbs where the power could reduce times. Namely Arley. 170s struggle to get to 70mph and there's talk of line speed change which wouldn't be achievable. I've just worked a packed 1500 off Cambridge to Brum.. I had a 3 car..
    South of Peterborough it's only lighter loads off peak but it varies..
  26. tbtc
    tbtc Veteran Member
    15,027
    16 Dec 2008
    Sheffield
    The Lancashire electrification will free up about fifteen DMUs (assuming nobody bothers reintroducing a Windermere - Manchester service 95% under the wires of course....).
    I expect that this will see the nine 170s heading off elsewhere and some of the busy services through Leeds getting six coaches for part of the journey (whilst Manchester gets doubled up 185s on most peak services from Preston, the significant flows from Huddersfield/York into Leeds don't get this luxury on anything like as many services).
    I don't see any leaving TPE any time soon (as I think that TPE North electrification is unlikely in the next decade, especially as its an inefficient way of getting rid of Pacers)
  27. sonic2009
    sonic2009 Established Member
    4,071
    19 Jan 2010
    Moulton nr Winsford
    If the 185s do move to Portsmouth - Cardiff or Scotrail. Your going to have to build or.enhance depots because Adwick and York were built for the 185s by Siemens, a bit like at Northampton with the 350s and Northam for 444/450, there's nothing like that in the South West. Although dont Siemens have a depot at Polmadie for 380s?
    Personally i reckon 185s should stick with TPE.
  28. DanTrainMan185
    DanTrainMan185 Established Member
    5,357
    25 Jul 2011
    Cardiff/Bristol
    The 319's that are planning on moving up north are going to be used on Manchester Picc/Victoria - Liverpool via Newton-le-Willows, not on Blackpool services, according to Wikipedia anyway.
    Personally that seems like a bad idea, because although the 185's are crammed they're actually very stylish, the 319's are older stock, so Blackpool services would have the standard of train decreased. Liverpool services are currently Sprinter operation, so a 319 would be quite a nice 'electric' stylish unit.
    I hope to dear god that 319's do not go on Blackpool services. In fact, I don't know why they're on Thameslink services, one of they key services hitting central London, I personally think they should work services that are no longer than an hour.
  29. aformeruser
    30,637
    23 Jan 2009
    Ignoring the Blackpool and Scotland services there's 35 diagrams for the current TPE timetable:
    South TPE: 7
    Middlesbrough: 6
    Hull: 4
    Newcastle: 6
    Scarborough: 6
    Barrow: 5
    Windermere: 3
    If the Manchester-Leeds semi-fasts get added in then we've got another 5 diagrams.
    So that'll be 40 diagrams with no strengthened services and no other service enhancements. I think 60 units could easily be utilised effectively given Liverpool-Scarborough will ideally be 4/6 car operation as well as some of the South TPE, Newcastle and Barrow services.
  30. Nym
    Nym Established Member
    8,038
    2 Mar 2007
    Somewhere, not in London
    Thats because wikipedia is woefully out of date, and was posted before the entire Lancs triangle was approved.
    And at the moment, no-one knows what will get used on any of the services, the 319s aren't appropriate for Manc - Preston - Blackpool via Bolton as the're just not long enough, or too long to be doubled up, it needs 3x23m long units (323s or 380s), or major platform alterations.
    And if you care more about style than function, I'd be glad you're not in charge of rolling stock allocations...
    And yes, to agree with jcollins, the 185s are going nowhere fast, even if TPE N gets electrified, theres plenty of routes the 185s are suited for around the North...
    If they were to be moved, it would be an end of all TPE Diesel stock IMO, and should go somwhere like SWT or Scotrail, in exchange for one of their diesel fleets.
  31. Flywaver
    Flywaver Member
    190
    10 Nov 2009
    Wishful thinking from many. There are always ideal routes. Personally if XC have made a deal then live with it... Must admit though having a small fleet will be a maintenance nightmare.. Can they be coupled to 170s in emergency?
Thread Status:
Share This Page
