Ethiopian Airways flight crashes (10/03) + 737 MAX grounding
robk23oxf
30 Jul 2017
Bloomberg is reporting that Garuda Indonesia is cancelling an order for 49 Boeing 737 MAX following these two crashes and the subsequent groundings. Other airlines are also re-evaluating their orders for the 737 MAX.
rebmcr
15 Nov 2011
St Neots
https://www.bloomberg.com/news/arti...-seeks-to-cancel-4-8-billion-boeing-max-order
They should suffer severe penalty clauses for that.
Exercising such market power before anything conclusive has been determined only serves to encourage companies like Boeing to cover-up future safety incidents.
robk23oxf
30 Jul 2017
I don't see why. Lion Air cancelled all their 737 orders after the first crash.
Strictly speaking they haven't cancelled their order but have refused to take delivery of any new aircraft. Relations between Boeing and Lion Air have been strained since the accident and Lion Air have already been evaluating alternative aircraft.
A poorly written piece of software that seems to have a propensity to nosedive the aircraft.
Not only that, but to do so with such force that the pilot can't hope to counter it by pulling on the column, but instead has to go and find a breaker and trip it (despite in some cases not even knowing it exists) while plummeting to the ground.
The mind utterly boggles.
cjp
28 Jan 2012
In front of a computer
And to omit mention of it in the original flight manual rather than overburden the pilots. Crazy just crazy.
By now (post Lion) all pilots should know where it is but recognizing the problem is another thing.
It is one thing not being allowed to do something stupid but an entirely different thing to make the aircraft fly into the ground which seems to have happened here.
TheEdge
29 Nov 2012
Norwich
I think this may boil down to being the issue. As a layman with a vague understanding of flight physics, pilots suddenly having their aircraft adopt a nose down attitude, not realising this is (apparently) MCAS working as intended, trimming to attempt to fix the nosedown attitude then suddenly finding themselves nose up and stalling.
As an aside how different is this to the issue with the Airbus flight laws?
Which specific issue? The one involving the pitot tubes?
I think a fairly key difference is that the Airbus flight laws won't actively counteract what the pilot is doing, they just keep it within an envelope. Loss of that envelope can cause confusion, which I think was the root of that crash.
TheEdge
29 Nov 2012
Norwich
That makes sense and is a fairly critical difference
cjp
28 Jan 2012
But it was not working as intended. The aircraft was climbing normally and Boeing's software decided it was a approaching a stall and trimmed it nose down as a stall recovery or stall prevention maneuver. The pilot who sees the aircraft climbing normally can override this on the column and use the stick to raise the nose but 5 seconds later the the Boeing gimmick cuts in again and down goes the nose.
There is a manual trim trim wheel which need a lot of turning to make much difference and I do not know if in the 373 max they could even get a hand on it as in normal use it spins like mad when auto trim is taking place and I do not know if the Boeing gimmick would be disconcertingly moving the trim wheel.
The other thing is to recognize what is happening and to turn the beast off.
Have a look here
https://theaircurrent.com/aviation-...aracteristics-augmentation-system-mcas-jt610/
for a clearer explanation.
Boeing's software appears to be imperfect to put it mildly.
Thanks for that link - explains better how they deactivate it - it's not as bad as I thought as it can be deactivated from their seat - but that does rely on them having the time and wherewithal to do that (and manually re-trim) while under a lot of pressure and experiencing a lot of G-forces.
rebmcr
15 Nov 2011
St Neots
Or maybe Boeing could fix problems properly rather than bodging on a poorly-written piece of software?
Hindsight is nice, but no substitute for handling subsequent events in a safety-positive manner.
I believe your quote would better begin "And maybe [...]", at which point I would agree 100%.
cjp
28 Jan 2012
I would not think G would be significant but lack of knowledge or practise on a sim or for real would be the issue. For example if I get into a spin I do not think about it I recognise it and automatically carry out spin recovery action. It is programmed in just, for example, once you have learned you do not think how to change gear in a car- you just do it.
Now the process will be in every 737 Max8 pilots mind but perhaps not yet instinctive and in the circumstances no time for a check list. This means because of the way Boeing introduced the gimmick it is basically an unstable machine kept "safe" by a pilots skills.
Trying another analogy how happy would you be to travel in a train knowing the brakes might or will fail but it will be ok provided the driver realises they have failed and they remember how to apply a special emergency brake they have been told about but never practised with?
Tetchytyke
12 Sep 2013
Isle of Man
That issue was with a specific manufacturer of pitot tubes, and Airbus had already told airlines to replace the Thales tubes with Goodrich tubes. The flight control on AF447 worked correctly, unlike, it appears, with the B737-8MAX.
ian959
9 May 2009
Perth, Western Australia
One thing that puzzles me greatly: how come this defect in the software was not discovered during the flight test program? Would I be right in presuming that because this is a development of an existing plane, its flight test requirements are no where near as extensive as they would be for a wholly new plane before issuance of the type certificate? If so, this has now highlighted a major problem with type certification regulations. Also given that the Lion Air crash was 4 months ago and Boeing have still not been able to produce software that fixes the problem, how sure are we that the problem can be fixed given the inherent design issues with the aircraft that created the need for the software in the first place?
AM9
13 May 2014
St Albans
This has parallels with many other avoidable disasters, e.g., wasn't it deemed OK to do a 'desktop' fire risk assessment on cladding of the type used on Grenfell Tower.
I think it's very similar to Grenfell indeed - a bodged solution on the cheap failed and killed a load of people as it did.
There has to be some level of trust between the regulator and the supplier - if there was none then taken to the extreme the regulator would have to examine every part of every plane to make sure the supplier hadn't decided to build something different without telling them! But there is a risk with self-certification, unless it's against a set of very clear measurable criteria set by an external body, that people just look at the last job and say "well we can be a bit more clever this time" and the things just creep until what is being produced bears no resemblence to the initial standard.
I think that's what happened at Grenfell but protecting against it is a lot easier for something relatively straightforward like a building cladding than for something as complex as a plane. There may also be the difference between European ("you need to comply with all these standards") and American ("you can do what you like but if you mess up someone will sue you out of existence") safety management principles, although I'm not sure how much that applies to aviation.
AM9
13 May 2014
St Albans
... There may also be the difference between European ("you need to comply with all these standards") and American ("you can do what you like but if you mess up someone will sue you out of existence") safety management principles, although I'm not sure how much that applies to aviation.
The European (note 1) ethos, as you have indicated is, with ensuring compliance with rules and standards that have been evolved over decades (in some non-aviation spheres - centuries), where compliance generally takes priority over profit/political ambitions. In theory, the US has a similar aim, however the shadow of affordability, (in the commercial sense) is omnipresent and frequently raises its head to cloud the due process of ensuring compliance with legal (and certainly moral) safety obligations.
My experience is mainly with the avionics industry (which is the nub of the 737 MAX issue) and as far back as the mid '80s, I was surprised, to say the least, that it was considered OK to put a label on the back of cabinets that contained high RF power and high voltages (note 2) said "Danger of Death" as the only deterrent to any would-be tinkerer or other person (officially) opening the doors. The attitude of the engineers and their managers was that 'you have been warned!' so the manufactuere's obligations were completely discharged and there was no point in wasting money on more effective measures. At that time, we were streets ahead of that, we had the Health and Safety at Work statute in 1974 which outlawed such practices.
note 1 - the greater Europe, not just the EU.
note 2 - these were 'medium voltage' in the context of the current Low Voltage directive.
Yes, we moved on, for very good reason, from just warning people that something might kill them and towards the idea that we should do our utmost to make it impossible for that to actually happen. Though the standards do vary massively between European countries.
WatcherZero
25 Feb 2010
Now both criminal and civil investigations launched into the FAA approval of the 737 Max. Principally investigating whether Boeing and the FAA were too close and the FAA rushed approval to give Boeing a commercial response to the A320 Neo, secondly the fact that the approval was granted on a false or fraudulent safety case with the MCAS capable of commanding maximum rudder moves when it was supposed to be limited to only one quarter moves and also the safety case put forward having no corroborating data.
rebmcr
15 Nov 2011
St Neots
Oh dear! There are of course many paths this could take, but I think some of them begin to point at the end of Boeing.
