Ex LNER (and Grand Central) Mark 4 sets for TfW
berneyarms
26 Nov 2013
Dublin
Exactly - GBP 15 supplement from Cardiff to Shrewsbury or GBP 20 to Chester is very reasonable considering what is on offer.
capital12
20 Aug 2012
That definitely looks white to me:
Class 175 in TfW livery
The repaints are definitely a light grey. I think the first few units that were vinyls were white.
Had a vinyl and painted 175 coupled together last week and when together you can see the difference.
Phil from Mon
28 Nov 2014
Beaumaris, Ynys Môn
Quite. If they're going to do anything to try and increase utilisation it might be to play around with 1st class APs at the moment I believe there is only one tier of 1st AP. For instance Cardiff to Chester is £57. There might be an argument for a slightly lower tier (down in the £40s maybe) which might trigger some more demand. Though if I were TfW I'd probably hold tight on tweaking the fares too much and see whether the existence of more trains offering 1st class might not actually stimulate demand in and of itself at the same price point.
Cheapest by far is to get a standard advance and then upgrade on-train or at a station.
tomwills98
18 Feb 2018
Bridgend
And if you do, make sure you get a seat reservation so you know you have a seat if it's running.
The vinyl should have been the same colour as the paint, however the vinyl is recyclable and the dye colour didn't take as expected. There wasn't enough time or wrap spare before the franchise launch so they had to go into service like that.
But anyway, it doesn't matter if they're white or grey as within two weeks you can't see it through the dirt and brake dust.
Skip 10
30 Nov 2009
Wrexham
Booking offices have been reminded lately that they can only issue upgrades with a reservation, on the day upgrades can only be purchased on the service. Saves the recent issue of too many tickets and not enough seats.
Phil from Mon
28 Nov 2014
Beaumaris, Ynys Môn
Bought a non-reserved same day upgrade at Cardiff central on the 4th of this month. Luckily it was the first day back after the Pontrilas disruption, and plenty of room.
Rhydgaled
25 Nov 2010
New TFW diagrams from December. The Manchester set becomes Mk4s from 16th December.
Are these still just Monday-Friday (minus bank holidays) or is the working week for the LHCS being extended? Interestingly that appears to require the same number of sets (two) regardless of whether each set works just two workings a day (out from its home depot and back, with a long layover in Cardiff) or three workings (alternating between stabling at Cardiff and Holyhead overnight).
If they go for keeping each set based at one end, the set that returns to Cardiff would have no work from 16:15 onwards. Do the crews that work the LHCS sign the GWML to Swansea? Because if they do, and that diagram is going to be four mark 3 TSOs (ie. no first class) that could be a useful peak time capacity help out of Cardiff as an interim measure until more DMUs are available.
FrodshamJnct
14 Apr 2019
Cheshire
Yep from what I saw on Facebook they’re Monday to Friday.
PHILIPE
14 Nov 2011
Caerphilly
It will work the 1716 and overnight at Holyhead
Envoy
29 Aug 2014
Why would they just work weekdays? With the present rolling stock shortages, I would have thought they would also have been out on weekends. Furthermore, the driving van trailer has loads of space for bicycles = ideal for the leisure traffic - which is surely mainly at weekends.
That's a new stop for Gerald southbound at Ludlow then. It was originally non-stop Shrewsbury-Newport.
Also the first northbound is non-stop Shrewsbury-Wrexham and Chester-Llandudno Jn.
OrangeJuice
4 Jun 2018
So does anyone know if there adding a new kitchen car into the Manchester MkIII set to run all 6 services a day with first and catering?
Or are they just keeping the Gerald set on the 5:34 Holyhead to Cardiff and 17:16 Cardiff to Holyhead as currently? This would then mean some units would be required to cover the midday Cardiff - Holyhead and subsequent return.
craigybagel
25 Oct 2012
Which is going to be an interesting challenge as it won't actually fit there. Or indeed on the down (southbound) platform at Abergavenny where the afternoon and evening services are booked to call. They also won't fit in either direction at Chirk and Ruabon which has some services mentioned.
The plan was initially to do the latter - that the diagrams wouldn't be covered in full as yet as there is only one working buffet car at present and that needs to go on the original Gerald services.
sefyllian
14 Jan 2013
I saw a single TfW buffet car being hauled through Crewe station on Monday morning, while I was waiting for a connection. Headed north – possibly to be repaired and joined to the other set?
CaergwrleKen
2 Oct 2019
Caergwrle
Hello forum
Some big gaps there now thanks to them missing vital stops out. They’ll be running round empty..
Ken
FrodshamJnct
14 Apr 2019
Cheshire
The Mk3 Manchester set only runs weekdays at the moment - and I don’t think there are plans to change this when the Mk4s are introduced.
33017
9 Sep 2017
No, it was 10249 going to Crewe for an exam.
33017
9 Sep 2017
The last I heard, Gerald will remain as now until May and the current north Wales rake will do 1W91 and return. A unit will work 1W93 / 1V98 and a rake of Mk4s will fill in on the current Crewe based turn until they are cleared to Cardiff at which point the three return trips above will all go Mk4.
Skip 10
30 Nov 2009
Wrexham
As far as I'm aware no method of working has been agreed so far.......
hexagon789
2 Sep 2016
I don’t think that’s particularly necessary. If it’s a quality product I will quite happily pay the current upgrade, or even a slightly more expensive one, to travel first.
It just seemed a bit of an over-provision of first; if they can fill it then there's no issue
ash39
8 Feb 2012
Apologies if this has been covered up thread and I've missed, but following on from this do you know if that means the Manchester loco hauled will eventually revert to a unit, leaving the mk4's working solely Cardiff-Holyhead diagrams?
PHILIPE
14 Nov 2011
Caerphilly
In May at the moment when the Marches is cleared for Mark IVs
