I was at Chippenham at half term and walked straight on to the out of use platform because it was the logical platform for trains to Bath. It looked 100% like the real thing until the realisation of there being no tracks!
Precisely. If you go in through the side gate rather than the ticket hall, there's no indication that this is anything other than a regular platform. I didn't twig until after I'd spent about a minute looking for the train indicator. There really ought to be some sort of sign there.
It seems it may be unique.
Maybe that's why there's no decent term for the thing! Perhaps we should call it a "Chippenham platform".
The other factor is that you can't see there are no tracks until you go onto the platform as you approach the platform at right angles through the doors.
It's not even obvious that there are no tracks when you're
on the platform, unless you're specifically looking for them - and I don't normally check to see if there's a track every time I walk into a station! I suppose it'll be a bit more obvious when the line's electrified...
The sign could be clearer - "All Trains" might be better for the first line rather than "Platforms 1 & 2".
I agree. And the sign shouldn't say "This platform not in use", because it clearly
is in use! How about "No trains depart from this platform"?
It does raise the question of why they took out that platform and not the one on the north side - track alignment to enable a higher through speed?
Good question.
As for the yellow lines, on the basis they've been painted since the track was removed then I reckon it was a contractor who got a job to paint yellow lines on the platforms at the station and did precisely that!
The platform was closed to trains in 1976 - I think anything painted on it before then would have worn away by now! I don't think they even had yellow lines at platform edges then - the Inter-City 125 (High Speed Train) didn't start running until later in the year, and I'm fairly certain they were introduced after that, as a safety measure.
