BestWestern
- Joined
- 6 Feb 2011
- Messages
- 6,736
Hi all,
For those who are into the finer details, and following on from posts elsewhere about the missing seatback tables, here's a list of all current or planned modifications to the FGW DMU fleet:
158's - all 'currently ongoing':
Refitting of seatback tables where needed; mods to cycle storage bays and wheelchair/catering ramp facilities; mods to air-con cabinets, cab seating, Alternator Charge Fail lamps (LED's to be fitted) and auxiliary heater fuel pipes; weather testing and re-sealing of cab roofs; new High/Low horn labelling; replacement of all electrical relays with a more reliable type; replacement of windows with 'unbreakable' laminated glass (as per current guidelines); and a deep clean of all seat covers and carpets - not before time!
Additionally the 3-car 'Hybrid' sets and 749 are also to have a second emergency equipment cabinet reinstated. All of this was due to commence mid-January, but I'm unsure as to how much, if any, of the work has been completed so far.
A couple of trial mods were carried out last year on 769, with an emergency door release plunger fitted to the bulkheads above the sliding vestibule doors, and a switch fitted outside the disabled toilet allowing the door to be easily opened or locked out of use with a carriage key. None of this has appeared anywhere else on the fleet so far though.
150/1's:
These are to be fitted with intermediate door controls located within the saloons in order to bring them into line with the 150/2's. Currently the doors can only be operated from either end of a set from behind the cabs. This was initially mentioned some time ago when the units first began arriving, and no date appears to have been set for the work taking place. The recently refurbished 121 & 127 have not been fitted so far. The 'Door Interlock' indicator lights currently fitted to the door control panels are also to be removed, as they are a non-standard fitment (they were also originally fitted to the 150/2's but appear to have been abandoned years ago!). The repaints to these sets do not include the usual 'Local Lines' placename vinyls, just a coat of navy blue with pink doors and FGW branding.
And finally....
153 373 has had a trial mod to the cab droplight windows on the No.2 (small) end, as crews have compained that they are too stiff to operate. The new mechanism fitted has required the crew door controls on the Second-man's side (Open/Close push buttons under a locked flap) to be moved from beneath the window, and they are now down at solebar level slightly further forward.
All very exciting stuff, of course! I hope it's of interest to the 'teccies out there LOL
150/1's:
And finally....
