animationmilo
- Joined
- 29 Mar 2011
- Messages
- 764
Is this still happening on weekend 5th April? As the nationalrail times seem to suggest not.
Surely discretion should be given when the service is diverted?
So they are hourly on the down and one every 2 hours on the up!
How does that work then?
Anyone know when FGW are going to release Advance fares during the disruptions? (specifically 7th of April). I note that XC and ATW have already released A-P tickets for this date. Thanks
Advance fares will be available and has been available for the first weekend for nearly 2 weeks now! 7th April should be out tomorrow.
The SSL carriages are a right mix. Last time a number of the Waterloo-Penzance services were high density sets and even sets with micro-buffets.Does anyone know if the trains from Waterloo via Basingstoke, which have to have Short Swing Length (SSL) bogies, will be high density sets, low density sets, or a mixture? (In other words, are all the SSL sets a particular density?)
Also I note the public timetable from Waterloo to be typically xx59 but the WTT timetable has them departing after the xx05 Bournemouth services.
This leads to the odd situation of some passengers being advised to change at Basingstoke (e.g. Brighouse to Basingstoke on the morning Grand Central). Presumably the HST will still be available to board up to departure, or will people who arrive between xx00 and xx05 need to take the earlier departing SWT and change at Basingstoke?
As far as I am aware the services will drop off the departure boards on the concourse 2 minutes before departure, and the possibility of an early departure by WTT is always possible. I can't see there being a problem boarding onces it has dropped off the departure board, but I would not guarantee it.
London Paddington to Exeter, Plymouth, Paignton / Newquay / Penzance: Trains are diverted to run to and from London Waterloo and will not stop at Reading, Newbury, Bedwyn or Pewsey.
This will be similar to the diversions over the festive period in 2010. Some trains will go via Basingstoke (Amazingstoke) and into Waterloo, whereas others will go up through Oxford, reverse at Banbury then down the Chilterns and into Paddington. In the latter case, I am not sure of the exact route into Paddington; when I did it we went via Castle Bar Park but I am sure someone said when they did it the train went along the New North Main Line all the way.
As with last time, there are some trains from Paddington to Paignton via Banbury.London Paddington to Exeter, Plymouth, Paignton / Newquay / Penzance: Trains are diverted to run to and from London Waterloo and will not stop at Reading, Newbury, Bedwyn or Pewsey.
Just seen on wnxx that FGW have put out bulletins to staff about the diversions during the next blockade at Reading in spring 2013.
http://www.wnxxforum.com/interactive/viewtopic.php?f=9&t=26983
I would like to know however where the 3 carriage class 150's are going to come from since FGW only have the two that operate around Bristol and 150001 & 150002, perhaps during the diversions there maybe some additional class 165's available to use on the Reading - Bassingstoke route allowing 150001/150002 to work the Didcot - Cheltenham shuttle.
Class 165/166's at Westbury although its a pity they cant run them up to Bristol TM or something it would certainly have added some more variety.
However I guesing staff will have to be trained and the route between Westbury and Bath cleared for use by the Class 165/166's
As you say, 150001 & 150002 Will be doing the Didcot - Cheltenham shuttle, and will likely work alongside 150921 & 150927. As for the Turbos, they are cleared to run along the Berks & Hants - a trail was run yesterday with 166211 to Castle Cary and back to Reading, this for a combination of future services.
Night Riviera will unfortunatly be formed of a HST and will run from Waterloo.
Unless there have been some very recent changes, they are only cleared as far as Castle Cary and so wouldn't be able to be used on any future stopping service between Reading and Taunton/Exeter without further clearance. I had read that the plan was to cascade them onto the Cardiff to Portsmouth route after electrification but could Weymouth be another possibility?a trail was run yesterday with 166211 to Castle Cary and back to Reading, this for a combination of future services.
Would it not be possible to run round at Banbury if the sleeper stock can't run into Waterloo for some reason?Night Riviera will unfortunatly be formed of a HST and will run from Waterloo.
