Signal Head
- Joined
- 26 May 2013
- Messages
- 407
It does make interesting reading. The vertical 'misalignment' of the JI is, I think, shocking, when you look at where most of the light is going, I'm not surprised it didn't stand out sufficiently to get the driver's attention.Interesting to note pages 45/46
They go into a lot of detail about the alignment of the signal aspect and the associated junction indicator.
The Junction indicator is pointing far too high and as everyone will know with LEDs, they have a much smaller viewing angle than filament lamps - just look at a motorway VMS sign next time you pass under it, they almost disappear when you get close.
I have noted this myself on occasion at some signals where the JI is much harder to see than the aspect itself. More needs to be done to ensure proper alignment of signals!
The comparison between filament and LED JIs is also interesting. The comparison was between a 'modern' filament JI using SL18 (or SL35) lamps. An SL35 is the type used in main aspects and is provided with dual filaments, one acting as an auxiliary for when the main fails. The SL18 is the same rating but without the aux filament.
Older JIs used a different lamp, from memory SL33, which were a 110v lamp with a similar rating but, being 110v (SL18/35 are 12v) the filament is longer and not straight, a bit more like those in domestic lamps. This means much less of the filament is at the focal point of the lens and the beam is therefore less concentrated. I remember the first time I saw an SL35 type how much brighter it was than the old one it had replaced, and this was reinforced at another location where old and new were positioned side by side, the older 1960s vintage JI was very much less visible at distance than the newer one, which actually tended to 'drown out' the main aspect below it when first sighted, especially when displaying a Green, exactly the opposite of what appears to have happened here.
