I'm sure someone else will be able to download the photo and put it up on here soon....
(second image)The gantries as seen from Basildon Park house, before the trees get their leaves and obscure them completely.
Previously on here I suggested a similar T-shaped arrangement for the Thames bridge at Maidenhead so perhaps that will happen too.
With Theresa May as the local MP and the zillionaires who live on the adjacent river bank in full view of the bridge, I'd suggest there's a better than even chance....
Like this? It appears to be 2 centrally mounted TTCs made out circular steel and finished in Brown. It only really works when there are larger gaps between the tracks. Whilst browsing that page, I found the following quote which made me chuckle a bit
HILARIOUS !!
To be expected, I suppose, that the irony would be lost with someone on here....
The trees are actually Basildon Park's own trees which managed to be far enough away from the line to escape NR's deforestation of trackside trees....
Next joker / sarcasm non-expert please....
Voila.
To be fair, the Basildon Park shot looks fine to me. I don't see what the problem is.
HILARIOUS !!
Is it just me, or are the angles a bit weird on this? I would have expected the cross-pieces to be in line with the middle pier of the bridge - i.e. going high to low from right to left (assuming that the difference in height is due to perspective).
The viaduct itself is skewed so that the railway goes on it's path but the piers lie parallel to the water flow (to prevent damage occuring from the currents hitting the bridge side on as at Lamington viaduct). As for the placing, it'll have been placed where it needs to be placed to fit in with the rest of the electrification (or where it can be mounted with the surrounding masts adjusted to fit, ISTR that there is a limit on how much the spacing between masts can change by per mast) - in this case, it'll probably have been mounted on one of the cross links between the 2 decks that can be seen in the satellite image.
I don't think the "keep off the grass" hoops are in keeping with the architectural theme set by the stone balustrades.
You cant see the masts. I had to look at that picture for about 5 minutes to see them!
The visual impact is simply hideous though. Wont someone think of the children/horses/house prices etc (Is that enough sarcasm? I have more if you like )
I remain convinced that if this line being built though any number of northern hell holes ( like ooh Darlington or Middlesbrough) not only would the ohle equipment not be changed but the trains would be running already.
Odd that the good people of Yorkshire are not being offered a vast number of tunnels and cuttings to screen their view of the HS2/3/4 line. I wonder why? I guess that is what being a loud, rich, plummy, southern Tory voter with a vastly expensive pad buys you!
btw that isnt sarcasm - that is aggressively northern chippiness
There won't be any chance if the bridge at Maidenhead isn't wide enough. Moulsford is two separate parallel bridges, and the dual cantilevers are fixed to mounting plates on the inside faces of the two bridges, well out of sight from a distance.
The Gatehampton Viaduct is just south of Goring....No idea what OLE has been installed there and not sure if that is a 'double' bridge or a 'single' bridge, if you know what I mean...
I'm told that either side of the Moulsford Viaduct is the usual OLE and just half a mile further north from there are several much higher masts alongside the electrical sub-station ( is it ? ) which nobody knows what they're for...Any ideas ?
So are we back to using Headspans? I really don't see what alternative there is, maybe run the bi-modes in diesel between Reading and Didcot?
JIMM....
Whatever, the OLE which has appeared at Moulsford really does look quite elegant in the photos and as I said, kudos to NR even if the end result came about by circumstances rather than by deliberate design....
There is also a portal version of this tubular mast design. And more metalwork at Moulsford than just that T shape with more at the bride ends, as Mt Phlopp suggested. As I said back up the thread, the same design is being used at Gatehampton bridge, just to the south of Moulsford, so some version of it will doubtless appear at Maidenhead.
Diesel might be fine for the bi-modes, but the electric-only 387s are going to be a bit stuffed if there's no electrification.
But worryingly there is talk about DaFT changing the order for Hitachi to provide bi-modes rather than electrics.
The travelling public could be paying for all this by riding in non-ideal trains for 40y.
