Greater Anglia Bombardier Aventras (Class 720): Technical discussion and introduction
Discussion in 'Traction & Rolling Stock' started by absolutelymilk, 22 Dec 2017.
  1. samuelmorris
    samuelmorris Established Member
    4,486
    18 Jul 2013
    Brentwood, Essex
    Any links to that? I find that a little difficult to believe, but would like to know more and it ought not to be discussed here.
  2. eastdyke
    eastdyke Established Member
    1,759
    25 Jan 2010
    East Midlands
    I remember GA stating a milestone of 100 x 720 carriages completed.
    Reference made in BBC Look East can be found here [BBC sign in required, available to 18.55 10/12 only]:
    https://www.bbc.co.uk/iplayer/episode/m000c78m/look-east-evening-news-09122019
    The rail issues feature starts around 5 mins in, the reference to Bombardier around 7 mins.
    The presenter quoted Bombardier as having said that the 720s would be delayed from January to Spring, reason 'software'.
  3. St. Paddy
    St. Paddy Member
    71
    11 Sep 2019
    Hitchin
    Just stories circulating on the GN at the moment. Class 700 are only doing just over 10,000 miles between failures apparently against a planned 40,000+, so there have been cancellations due to the shortages. With the Cambridge-Maidstone service not happening anytime soon, this could be a short term solution. Also, may be more 365s coming back on lease. Just rumours at the moment though
  4. Class 170101
    Class 170101 Established Member
    5,701
    1 Mar 2014
    The Class 365 rumour seems more plausible than the Class 379 rumour particularly as GN still has Class 365s and drivers that sign them so no training required as well as fitters and fleet teams that are familiar with them unlike the Class 379s which whilst similar to Class 387s would still probably need conversion training for crews and maintainers.
  5. samuelmorris
    4,486
    18 Jul 2013
    Brentwood, Essex
    This probably needs its own thread if it hasn't already got one...
  6. 365 Networker
    365 Networker Member
    89
    19 Jul 2019
    If that turns out to be true I'll be very happy!
  7. 47421
    47421 Member
    488
    7 Feb 2012
    london
    AFAIK no 720 has turned a wheel on normal NR track. They have moved under own power at Old Dalby but apparently were taken there by road. Speculating, but presumably NR are not satisfied they are safe cus software is defective.
  8. ashkeba
    ashkeba Member
    1,036
    13 May 2019
    Reintroducing old replaced trains would be embarrassing and further increase the feeling that Cambridge GTR services are a specially unloved bit of a sin-eater franchise.
  9. 59CosG95
    59CosG95 Established Member
    4,488
    18 Aug 2013
    WIM/PBO
    You'd be surprised how many people seem to prefer the 365s, with their hopper windows, comfortable seats, and better seating plan than the 700s...
  10. 43096
    43096 Established Member
    6,510
    23 Nov 2015
    I cannot see the 360s being retained much beyond the current lease end date. There is just no way DfT will be embarrassed by having no trains available for a newly electrified railway in 12 months time. It would be a national press issue, whereas some short-formed trains on GA wouldn’t.
  11. hwl
    hwl Established Member
    5,328
    5 Feb 2012
    Better for Bombardier to sort the software issues on the LO 710s (just multi working left as major issue?) then effectively be able to use a lightly modified version for 720s and 701s hence the rate of delivery / entry into service could be quite rapid as soon as the software is sorted.
  12. hwl
    5,328
    5 Feb 2012
    They wouldn't necessarily need all of them to begin with e.g. just run 8 car on the EMR Corby services initially?
  13. Astro_Orbiter
    Astro_Orbiter Member
    56
    8 Nov 2019
    AFAIK the 379's are being shipped to Gautrain in SA when they come off lease in August 20. Should be all if not most of the Stansted 745's in service by then
  14. Failed Unit
    Failed Unit Established Member
    7,493
    26 Jan 2009
    Central Belt
    They have some (700s) running between Cambridge and Kings Cross that don’t need to be as the service is unlikely to ever go through the core. Bring the 365s out of retirement. Interesting however.
  15. Failed Unit
    7,493
    26 Jan 2009
    Central Belt
    Me for one. Only issue is the shacks between Royston and Cambridge.
  16. James321
    James321 Member
    11
    26 Jan 2018
    If possible renatus class 321 to cover class 360 when go to off lease in August 2020?
  17. 47421
    47421 Member
    488
    7 Feb 2012
    london
    Thats a new one, mind if I ask why you think they are going to South Africa?
    Yes in theory the 745 should be in service by then, but very likely that GA will still be short of PRM-TSI compliant units, as they have not done the mods they promised to on 27x317s (only 2 or 3 done so far) and no one knows when the 720s will be available. Also assumption is that GA will continue to operate 4car units UFN on Hertford East services as 10car 720s wont fit.
  18. Astro_Orbiter
    56
    8 Nov 2019
    I'm sure I heard that on here somewhere, because they run electrostars over there and are in need of additional units. Not sure if they're taking all 30 units though. Also, I'm sure they will continue to run 8 car 317/379 on Hertford trains until the platform works are done next summer (?) I'm sure Hertford's will probably be the last GA services to run with legacy stock because of the issues there.
  19. 47421
    47421 Member
    488
    7 Feb 2012
    london
  20. Astro_Orbiter
    56
    8 Nov 2019
    Its just what I heard mate, I don't claim to know more than what I hear roundabout.
  21. Chris125
    Chris125 Established Member
    2,513
    12 Nov 2009
    I've only ever seen it suggested as a possibility.
  22. Fincra5
    Fincra5 Established Member
    1,880
    6 Jun 2009
    I believe it was looked at but nothing more has been done :s
  23. St. Paddy
    St. Paddy Member
    71
    11 Sep 2019
    Hitchin
    720509 moving to Ferme Park today according to Richard Clinnick on Twitter, topped and tailed by 47727/47749, the first move of one of them on the main line. Are they going to be testing on the GN or is it just for storage?
  24. hwl
    5,328
    5 Feb 2012
    Ferme Park could be for testing though southern ECML may not be the best choice given how packed it is/upcoming engineering work., but Hertford Loop for ETCS test facility? or a good hand over point on the way to Ilford? (Given plenty of GA stuff going to wheel lathe across the tracks already).
    GA have very virtually no spare space currently so Ferme Park may be a sensible local sort term storage location no GTR have have finished the 313 to 717 change over.
  25. 59CosG95
    4,488
    18 Aug 2013
    WIM/PBO
    Well, this is the path: https://www.realtimetrains.co.uk/train/K00018/2020-01-13/detailed
  26. youngiecj
    youngiecj Member
    163
    26 Feb 2012
  27. Minstral25
    Minstral25 Established Member
    1,193
    10 Sep 2009
  28. Murray J
    Murray J Member
    279
    10 Aug 2019
    yes it is, showing up on railcam as operated by the same units.
  29. noodlepoodle
    noodlepoodle Member
    13
    5 Mar 2018
  30. samuelmorris
    4,486
    18 Jul 2013
    Brentwood, Essex
Share This Page
