Group Bourdon Tool
Discussion in 'Railway Jobs & Careers' started by newlearner, 31 Oct 2017.
  1. Maglev
    Maglev New Member
    2
    7 Nov 2018
    Hi everyone!
    This is my first post, I am not sure if someone has posted this tool for mac users to run the Group Bourdon tool. It is free software just in case someone tries to charge to use them.
    First you will need to download "Wine Stable" Mac OS version
    https://wiki.winehq.org/Download
    Also you might need Xquartz:
    https://www.xquartz.org
    After installing them both, right click on the bourdon.exe file and open it using Wine Stable. It will open a windows like installing interface. Don't worry it won't install the software. You might some icons after the install on your desktop (you can delete them).
    Screenshot added.
    Hope it helps.
  2. johnlh
    johnlh Member
    42
    6 Nov 2018
    Thanks a lot for that mate. I've got a Mac so that saved me some searching!
  3. Caad12
    Caad12 Member
    51
    3 Jun 2018
    Gateshead
    Installed both Wine and Xquartz - when I click on Bourdon.exe file Wine 'opens' along with another window called Terminal and then Wine quits and I'm unable to open the bourdon file - any ideas?
  4. Maglev
    Maglev New Member
    2
    7 Nov 2018
    Hi,
    Did you right click bourdon.exe and choose wine stable? otherwise it might use extractor as default.
    Also what mac version are you running?
    I hope it helps.
  5. Caad12
    Caad12 Member
    51
    3 Jun 2018
    Gateshead
    Hi there
    Yes I sussed it this afternoon - had to enable right click on my track pad so once that was done and Wine had installed some updates it's working perfectly.
    Now I'm seeing dots all over the place though.....
  6. Caad12
    Caad12 Member
    51
    3 Jun 2018
    Gateshead
    First time I've done this test - 8-10 rows with 1-3 omissions/errors. 2 hours practice and this is baking my crust :lol:
    Reckon within a week I'll be seeing polka dots everywhere!
  7. MostlyHarmless
    MostlyHarmless Member
    609
    1 Mar 2018
    2 hours is too long to practise that test in one stint! I did one or two tests a day over a week and that was plenty o_O
  8. Caad12
    Caad12 Member
    51
    3 Jun 2018
    Gateshead
    Too long? I go OCD on tests like this till I’m exhausted. I’ll see if I can scale back.
  9. MostlyHarmless
    609
    1 Mar 2018
    Yeah too long! Your ability to concentrate at that level falls off quite sharply after about 20 mins and you may see your scores getting worse
    You're better of breaking it into smaller sessions with a good interval inbetween.
    Its worth saying that most people seem to find the tests easier on paper than on the screen, so print some out if you can.
  10. Caad12
    Caad12 Member
    51
    3 Jun 2018
    Gateshead
    Good advice. I’ll fire up the printer.
  11. Dynamonic
    Dynamonic Member
    561
    10 Jan 2013
    Nottinghamshire
    The actual tests see you doing five sets of dots timed at 2 minutes for each set. So about 10 minutes for the whole test.
    As others have said, just practice one of these tests (five pages) at a time. I did one in the morning and one in the evening every day in the run up to my tests, which was more than enough.
    Remember, the Group Bourdon is just one test you’ll be sitting on the day! :)
    Good luck!
  12. NorvernRob
    NorvernRob Member
    47
    4 Oct 2018
    One or two practices a day is plenty, I’ve had around 15 attempts now and am averaging 12-13 lines and 1 omission per 60 lines. It’s the perception test I’m not looking forward to, I’ve done ok on the YouTube vids but I don’t like the feeling of not being able to check my work!
  13. Caad12
    Caad12 Member
    51
    3 Jun 2018
    Gateshead
    Well I'll take it easy on the test for now till I get the interview date and see if I pass that. Continue to revise Northern then worry about tests later.
  14. Pete C
    Pete C Member
    174
    8 Aug 2018
    I think I did maybe 8 practice tests in total for the Bourdon and passed at enhanced level. I was averaging 10-11 lines with maybe 1 omission per test.
  15. MidlandsChap
    MidlandsChap Member
    125
    15 Apr 2018
    Evening
    Can anybody confirm if the size of the sheet on this computer program is the same size paper sheets used at assessment days?
    Thanks
  16. martin2345uk
    martin2345uk Established Member
    1,473
    21 Sep 2011
    Manchester
    I think they were slightly bigger on the day. The dots were also finer. No idea if it’s like that for every assessment though.
  17. MostlyHarmless
    609
    1 Mar 2018
    Yes I think you're right, as I can remember thinking that they were when I did the test
  18. MidlandsChap
    MidlandsChap Member
    125
    15 Apr 2018
    Thanks for the advice, how much more work do you think I have to reach the standard? The below is for 5 sheets.
    I feel I can afford to slow down a touch to reduce those I miss.
    Targets Omitted 6
    Marked incorrect 0
    Total cells 1419
    Mean cell time 0.270
    Median cell time 0.230
    Completed rows 54
    Mean row time 6.728
    Median row time 6.505
    Row fluctuation 3.75
    I have printed a few sheets off, and generally find these easier. However hen you say the dots were finer, how do you mean?Are they not as high contrast as the online tool?
  19. martin2345uk
    1,473
    21 Sep 2011
    Manchester
    Just the dots were smaller and spaced a bit further apart than on the practice. If anything I felt it made it easier than the practice :)
    Keep going till you’re getting zero omissions consistently even if it means slowing down a bit.
  20. NorvernRob
    NorvernRob Member
    47
    4 Oct 2018
    I was a bit slower by around 1-2 lines per page on the actual test than the practise sheets, probably because I took it a bit steadier on the day as I didn’t want to go too quickly and mess up.
  21. JDMFTW
    JDMFTW Member
    20
    20 Nov 2018
    Thanks that’s really helpful I’ll be grabbing this on the Mac when I get home :)
  22. N47
    N47 Member
    39
    22 Nov 2018
    Hi is this the practise material for the test you do at opc or cannot also be used for the online assessment at the first stage
    Thanks
  23. N47
    N47 Member
    39
    22 Nov 2018
    Or can it also be used for the prior online VSE assessment
  24. MidlandsChap
    MidlandsChap Member
    125
    15 Apr 2018
    During the assessment test do they tell you when you are half way though the time limit on each page?
  25. J-P_L
    J-P_L Member
    83
    7 Sep 2017
    Middlesbrough, UK
    When I sat it early this year they didn’t tell you when you were halfway, just to change to the next block.
  26. Jord85
    Jord85 Member
    64
    4 Feb 2019
    just had my 2nd shot at the print off tonight
    sheet 1 - 11 lines 1 omission
    sheet 2 - 9 lines 0 omission
    sheet 3 - 9 lines 1 omission
    sheet 4 - 10 lines 2 omissions
    sheet5 - 8 lines 0 omissions
    going to do this twice a day for 2 weeks until my assessment and hopefully get down to 0 omission
  27. Dynamonic
    Dynamonic Member
    561
    10 Jan 2013
    Nottinghamshire
    Hi there Jord85. Good effort for your second attempt. Try and keep a consistent pace going throughout the sheets. You want to be getting more or less the same number of lines done on every sheet with 0 errors/omissions. You can do this by working to a comfortable rhythm. If you find yourself making more than one error/omission, try to slow your pace down slightly, then work on your speed once you stop making errors.
    For comparison, I was getting about 11 lines down every sheet and passed to enhanced standard on the day.
    :) Good luck!
  28. Jord85
    Jord85 Member
    64
    4 Feb 2019
    thanks dynamonic. I will keep at it for 30 mins a day until i go. Is there anywhere i can practise the ( TEA-OCC) part of the assessment?
    thanks
  29. Dynamonic
    Dynamonic Member
    561
    10 Jan 2013
    Nottinghamshire
    Personally, I only used the practice material sent to me to prepare for TEA-Occ, which proved enough, although some people on here have purchased books or software to help prepare them too. :)
  30. GollyDolly
    GollyDolly New Member
    3
    11 Feb 2019
    hello - new to all this so don't shoot me if what I am asking is super obvious. I have my assessment with Southeastern in a few weeks and have been informed I will be expected to sit Group Bourdon, TEA-Occ and Trainability for Rules and Procedures only therefore am only concentrating on practicing those tests therefore can someone point me in the right direction where I can get further practice material on those three - I would rather do paper tests then the computer ones as have been told pencil paper is how it will be done on the day. I have completed all what they sent me in the practice document - just wondering if there is an easy link to print some additional pages off.
    Thanks!
Share This Page
